peternlewis plans to perform server maintenance, including upgrading the OS and Discourse to 2.8.0, and intends to use read-only mode during this time. They note the odd placement of the read-only toggle under Backup settings and question why enabling restores is required to activate read-only mode, pointing out that read-only may be needed for reasons beyond backups. pfaffman advises against upgrading the OS in-place, recommending instead spinning up a new VM to minimize downtime and avoid risk of breaking the forum. They acknowledge the placement of read-only mode under backups is unusual, but suggest it’s typically used just before migrating to a new server — hence its association with restore functionality.
I plan to do some maintenance to the server, including updating the server and the server OS, as well as updating Discourse to 2.8.0 from 2.7.x. So I want to set it in to read-only mode for the duration of that process.
I saw the method is oddly in the Backups settings as described:
Firstly, I presume read-only mode does not affect an upgrade process?
Also, it is really weird that Enable read-only is in the Backup settings, and even more weird that it requires restoring to be enabled in order to set the site in to read-only mode. There are other reasons for wanting to set a site in to read-only mode.
If your plan is to upgrade the OS, I’d recommending instead that you spin up a new VM and move to it. Down time will be much less and there is zero chance of ending up with a broken forum.
It is a little strange that read-only is on the backup page, but the time that most people put a forum in read-only mode is just before making a backup to move to a different server.
