« post » est-il le bon sérialiseur à utiliser pour accéder à des données supplémentaires via decorateWidget avec post-avatar:after ?
I was hoping to add information to posts in the plugin.rb file using add_to_serializer, and then access that data in my plugin’s default initializer file using decorateWidget from the api.
My plugin.rb contains
after_initialize do
  add_to_serializer :post, :foo do
    return "bar"
From what I understand, the code should be adding a ‘foo’ attribute (with a value of ‘bar’) to each serialized post.
My only javascript initializer contains:
import { withPluginApi } from 'discourse/lib/plugin-api';
export default {
  initialize() {
    withPluginApi("0.8.23", api => {
      api.decorateWidget('post-avatar:after', helper => {
        console.log(helper.attrs);
The admin plugins page shows that my plugin is installed, but when I view the output in my browsers console, I do not see the ‘foo’ attribute. Obviously, I’m doing something wrong, and I would greatly appreciate some knowledge.
5 « J'aime »
I think you will need:
api.includePostAttributes('foo');
7 « J'aime »
Thank you! That absolutely did the trick!
4 « J'aime »
