Was ist dieser add_to_serializer Code in all diesen Plugins
I have seen this code in discourse_signatures plugin
User.register_custom_field_type('see_signatures', :boolean)
User.register_custom_field_type('signature_url', :text)
User.register_custom_field_type('signature_raw', :text)
if SiteSetting.signatures_enabled then
  add_to_serializer(:post, :user_signature, false) {
    if SiteSetting.signatures_advanced_mode then
      object.user.custom_fields['signature_raw']
    else
      object.user.custom_fields['signature_url']
  # I guess this should be the default @ discourse. PR maybe?
  add_to_serializer(:user, :custom_fields, false) {
    if object.custom_fields == nil then
    else
In discourse national flags plugin
User.register_custom_field_type('nationalflag_iso', :text)
if SiteSetting.nationalflag_enabled then
  byebug;
    object.user.custom_fields['nationalflag_iso']
  byebug;
    else
I am not able to understand what is add_to_serializer is doing.
I checked in def add_to_serializer
def add_to_serializer(serializer, attr, define_include_method=true, &block)
  klass = "#{serializer.to_s.classify}Serializer".constantize rescue "#{serializer.to_s}Serializer".constantize
  klass.attributes(attr) unless attr.to_s.start_with?("include_")
  klass.send(:define_method, attr, &block)
  return unless define_include_method
  # Don't include serialized methods if the plugin is disabled
  plugin = self
  klass.send(:define_method, "include_#{attr}?") { plugin.enabled? }
I understand that User.register_custom_field_type('signature_raw', :text) will register a custom field type to User object. But what is add_to_serializer doing? I am not able to understand, can you explain me in plain english?
It’s essentially adding to the information that Discourse serializes out when sending that model to the client. For example, you may see a request to this endpoint when loading up a topic page:
http://meta.discourse.org/t/2349082394.json
which returns some payload like this:
  title: "Some topic title",
  archetype: 'regular',
  category_id: 7,
  post_stream: { posts: [...] },
  posts_count: 15,
  (etc etc.. lots more info about the topic in question)
Which is the json representation of a Discourse topic.
If I want to know more about the topic because of additional ‘stuff’ I do in my plugin, I can put in a line like
add_to_serializer :topic, :flag_name do
  object.flag_name # <- NB that 'object' here is the topic being serialized
(Also, by default, this method simply sends the specified message to ‘object’, meaning that
is the same as
  object.flag_name
Once I’ve added the method to the serializer, I can end up with JSON output which includes that additional info
  category_id: 7,
  posts_count: 15,
  flag_name: "some flag name"
Also note that you could achieve the same thing by overwriting the TopicSerializer class (which is exactly what the code snippet you’ve provided is doing)
# plugin.rb
TopicSerializer.class_eval do
  attributes :flag_name
  def flag_name
    object.flag_name
Hi,
When running the following code,
  def flag_name
    object.flag_name
I was getting the error “block in activate!': uninitialized constant TopicSerializer (NameError)”. I think I have to “import” or “require” the TopicSerializer dependency. Can you please tell me what would be the dependency, as I am not able to figure it out.
Add this directly above your code require_dependency 'topic_serializer'
class ::TopicSerializer
  def flag_name
    object.flag_name
Hi thanks, but I got the error " `load’: No such file to load – topic_serializer (LoadError)". Does it pull from the app/serializers folder? I checked in that folder, I could find topic_list_serializer.rb, and many other related to topic, but couldnt find topic_serializer.rb
Right! Try TopicViewSerializer.
require_dependency 'topic_view_serializer'
class ::TopicViewSerializer
  def flag_name
    object.flag_name
Heyy, ich habe ein benutzerdefiniertes Feld zu meinem Kategorie-Bearbeitungsfeld hinzugefügt.
Wenn ich das Formular absende, sehe ich im JS-Console, dass diese Felder so übermittelt werden:
custom_fields[default_tag][]:good-feedback custom_fields[default_tag][]:one-more-tag
In meiner Haupt-Plugin-Datei mache ich folgendes:
add_to_serializer(:basic_category, :default_tag){object.custom_fields[“default_tag”]}
Meine benutzerdefinierten Felder werden nicht in der Datenbank gespeichert.
funktioniert das jetzt, wenn man:
add_to_serializer(:basic_category, :default_tag, false ){object.custom_fields["default_tag"]}
ausführt?
Ich habe das damals gelöst, indem ich eine Funktion zum :before_action-Event hinzugefügt und das Array in eine durch Trennzeichen getrennte Zeichenkette umgewandelt habe – und umgekehrt beim Abrufen.
Ich habe mich nicht wirklich damit beschäftigt, warum ein Array nicht von Haus aus als benutzerdefiniertes Feld gespeichert werden kann.
Das könnte den Code also potenziell vereinfachen?
Ja, das wäre der Fall, wenn es in diesem Szenario funktionieren würde. Ich werde das in Kürze ausprobieren und mich dann bei dir melden.
Das tut mir leid, das muss damals schmerzhaft gewesen sein :wink:
Es war ein Sonntagabend und die Neugier übermannte mich. Es war etwas schmerzhaft, aber auch spaßig.
Das war etwas, was @pfaffman zu tun versuchte.
Kein Schmerz, kein Gewinn :wink:
haha, so wahr! …
Hallo, ich habe das gleiche Problem (custom_fields werden in der JS-Konsole übermittelt, aber nicht in der Datenbank gespeichert). Ich habe in meiner Haupt-Plugin-Datei die Methode add_to_serializer(:basic_category, :default_tag, false ){object.custom_fields["default_tag"]} verwendet.
Würdest du diese Lösung immer noch empfehlen?
Hier tauchen viele Fragen auf. Welche benutzerdefinierten Felder sind vorrangig gemeint?
Ich arbeite an einem Plugin, um die Synchronisierung von Discourse-Gruppen mit LDAP zu automatisieren. Ich habe ein benutzerdefiniertes Feld namens ldap_dn zur Gruppe hinzugefügt, um den LDAP-Gruppennamen darin zu speichern. Ich versuche, den Wert des benutzerdefinierten Felds aus einem Eingabefeld abzurufen, das ich im membership-plugin-outlet hinzugefügt habe, und diesen dann in der Datenbank zu speichern, um ihn später zu verwenden.
Dafür habe ich Folgendes in meine plugin.rb-Datei aufgenommen:
Group.register_custom_field_type('ldap_dn', :text)
Group.preload_custom_fields << "ldap_dn" if Group.respond_to?(:preloaded_custom_fields)
if SiteSetting.groups_sync_enabled
add_to_serializer(:group_show, :custom_fields, false) { object.custom_fields }
Ich bin neu in Rails und Ember und bin mir nicht sicher, ob es noch einen weiteren Schritt gibt, den ich durchführen muss, um die benutzerdefinierten Felder in der Datenbank zu speichern, oder wo das Problem liegt.
Ich denke, wenn du
`register_editable_group_custom_field ‘field_name’
zu deiner plugin.rb hinzufügst,
sollte das den Job erledigen.
Hinweis:
Der Serializer wird verwendet, um Daten an den Client zu senden, nicht um sie zu empfangen.
Ahh, okay! Ich bin noch neu hier, also ist das vielleicht eine ziemlich offensichtliche Frage, aber um die Daten zu erhalten, mache ich das über die API, oder?
Meine Lösung gibt deinem Feld ein grünes Signal, sobald die Daten auf dem Server ankommen. Es geht also um den Empfang der Daten.
