Can this be allowed at a per-instance level?
סיכום מבוסס בינה מלאכותית
The discussion addresses whether social logins can be used with two-factor authentication (2FA) enabled in Discourse. roke_julian_lockhart references a previous statement by codinghorror noting that enabling 2FA typically disables social logins, and asks if this behavior can be adjusted on a per-instance basis. awesomerobot confirms that this is possible by adjusting the Enforce second factor on external auth site setting. When this setting is disabled, users can log in using social providers (such as Google or GitHub) without 2FA, while 2FA remains enforced for local account logins.
There’s a site setting called Enforce second factor on external auth — when it’s disabled you can log in using a social provider without two factor auth while still having 2FA enabled for local logins
