Is there a user level explanation of how to use search?
Continued from: Search tips and tricks 🔎
Can anyone provide the link to a description of the search function used by discource in English - IE not the ruby code!
Also @ mentions would appear to be have been enabled since the posts in this topic were written - a search for “@canapin Search” - without the quotes - found just canapin’s posts
It seems to me that rather than (just?) stemming an implicit AND is inserted between all search terms provided but no explicit OR is possible - so “improv topi” Will find improve and improving but only if it is in a post with topical or topic or topiary!!
Thanks in advance
PS I tried searching for documentation on the search but was rather snowed by â„– of results!
Is there a user level interpretation of how the discourse dialog box interprets the tokens and results returned EG it seems that words entered getting implicit and there is no way to generate an or but search terms seem to form a fuzzy match not always standing stemming fuzzier
Using @mentions to search users’ posts has been available for a long time. I believe the tip in Search tips and tricks 🔎 is to find when people have @mentioned someone within a post itself rather than posts by them.
That’s right. :+1: The search will look for posts with all the search terms in. Currently there is no OR function for it.
For the regular search, it works on stemming, though if you’re using the AI semantic search it will find more topics based on a similar function to the Related Topics you find at the bottom of topics.
