I was thinking of a method of creating a footer on the home page (and on all pages) and in that footer having icons for accessing other options, is there a way to do this with a script? css? or some component theme?
סיכום מבוסס בינה מלאכותית
A user, danielabc, wants to create a footer with icons on the home page for mobile users. matenauta suggests adding code to a specific CSS section and finding a way to display it only on the homepage. danielabc finds a suitable component but asks if it’s the most current one.
Canapin offers a custom solution by creating a theme component with HTML and SCSS code to create a sticky footer. However, danielabc finds a suitable component from the Discourse Tab Bar for Mobile and is now looking to add an option to the last button to display more buttons.
Yep, you can add code in specific section from CSS and then figure out how to display only at homepage (probable there are some tips around).
I found this wonderful component that will serve me! Do you know if he is the most current of all?
Or is there another newer component?
If you don’t find exactly what you need by entering terms such as “footer”, “sticky footer”, etc, it’s likely you’ll have either to pay someone to do it or do it yourself.
If you want to try creating a custom footer yourself, here’s a starting point.
Create a new theme component in your forum. In Edit CSS/HTML,
Mobile tab → Body, put this HTML code:
<div id="footer-test">
test footer
</div>
In
Mobile tab → CSS, put this SCSS code:
#footer-test {
position: sticky;
bottom: 0;
z-index: 2;
height: 80px;
background: red;
text-align: center;
body[class=""] & { // prevent the footer from being displayed during the splash screen
display: none;
Result:
thanks for helping me, but I found this component here that worked
now I just need to know if there’s a way to add an option to the last 'button that leaves more buttons
