Is there a way to display a banner when the server is updating
Hi everyone.
When the server is updating, it’s no longer available for the user for a while and, when the update is done, then the server is available again (fortunatenly :slight_smile: )
Is there a way to display a kind of banner to show the server is updating and try later ?.
Thanks for your help
Hi!
Try this:
Thanks for your reply.
I will test it.
That reverse proxy solution is much more complicated than a two container setup, which lets you build a be container while the old one runs (if you have enough ram). The downtime then is under a minute. How to move from standalone container to separate web and data containers.
Thanks for your information.
