Existe uma maneira de modificar os endpoints do Discourse através de um plugin?
for example, I want to change the result on /latest.json endpoint,
and I found the controller is list_controller.rb,
is there a way to modify related functions through plugin?
There’s almost nothing a plugin can’t do. The question is generally more: is it a good idea ? is it maintainable?
What have you tried so far ?
A good starting point it to look at our all-the-plugins repo and search for similar patterns.
It’s best to look at an example, I believe you can amend the serialisers:
Consider this:
With, for example, the Topic List Previews Plugin edits, from here:
https://github.com/angusmcleod/discourse-topic-previews/blob/master/serializers/topic_list_item_edits.rb
This appends a load of extra attributes. Try it and take a look.
ok, thank you so much!
