Rails-code van Discourse-applicatie aanpassen
I want to modified the code of discourse from backend and change scope of some model but it will not reflect on UI, how can I modify the backend code of discourse application.
Like I want to change the scope of some models based on my requirement want to change queries from backend, I am able to do on rails console but not able to implement on code base.
Guide my the steps.
You should create a plugin (look at example repos linked in #plugin) so that core upgrades work as normal. Do not modify the source code ‘directly’ as that will make maintenance a total pain. Use the guides in #documentation:devs to get going. Rails Serializers will need expanding if you want to bring down more data. However consider Custom Fields if your needs are light.
