Is there a way to Search by Posts with No Staff replies on it
Searching for Posts with No Staff Replies
There is no built-in search feature to find posts with no staff replies. To achieve this, jomaxro and James_Anderson suggest using the Data Explorer plugin.
tshenry provides a SQL query to find the desired posts:
SELECT t.id topic_id, category_id
FROM topics t
WHERE t.deleted_at IS NULL
  AND t.category_id IS NOT NULL
  AND t.id NOT IN (
    SELECT p.topic_id
    FROM posts p
    JOIN users u ON p.user_id = u.id
    WHERE  u.admin = 't' OR u.moderator = 't'
      AND p.post_number > 1
Mittineague attempted to use the moderator_posts_count field in the topics table but found inconsistencies in the results compared to the more complex query.
Is there a way to Search by Posts with No Staff replies on it.? It would be helpful to find posts easily that way!
Thanks so much
I’m pretty sure you’re going to need to use the Discourse Data Explorer. I’m not aware of this being surfaced via search in any way.
Thank you so much I’ll go check it out!
This should give you what you what you are looking for once you get the Data Explorer plugin installed.
I was playing with some queries using group_users, topic_users and topics when I noticed a topics field moderator_posts_count and got excited!!!
I tried
SELECT topics.id as topic_id
FROM topics
WHERE topics.moderator_posts_count < 1
:sadpanda: not so lucky, there was a lot of difference from the results I got with the more complex query.
