¿Hay alguna comunidad basada en Discourse que utilice la integración de chat de Telegram?
Hello members,
Is there any Discourse based community which is using Telegram chat integration?
Thanks!!
4 Me gusta
One of my (now defunct) community depended heavily on using telegram integration. I’ll be able to answer any questions that you may have.
5 Me gusta
Nice to see your reply member @itsbhanusharma :slight_smile:
How was your experience with Telegram integration with Discourse forum? I want to experience something similar. Can you suggest me some community where Telegram integration is active?
Thanks!!
1 me gusta
Telegram integration is very finicky to set up and an average user is usually not bothering enough to take all the steps that are required to enable telegram notifications on their account.
I’d recommend not to use it unless you have a community that uses telegram as their primary mode of communication.
4 Me gusta
I think @Systmyz is talking about Set up Telegram integration using the discourse-chat-integration plugin, which is an official plugin for a very common need, while @itsbhanusharma is talking about Telegram Notifications Plugin (discourse-telegram-notifications), a very niche and strange use case plugin.
3 Me gusta
@Falco & @itsbhanusharma both are right. Actually, I want to experience LIVE example of TELEGRAM integration. Kindly suggest some community which has already integrated Telegram with their Discourse based community. Thanks!!
2 Me gusta
He integrado mi sitio web de Discourse con Telegram, utilizando ambos complementos: Telegram Chat Integration (que envía notificaciones de cualquier publicación a un canal de Telegram predefinido) y Discourse Telegram Notifications, que, cuando se integra correctamente, me envía mis notificaciones personales a Telegram (incluso puedo ‘dar like’ y ‘responder’ a esas publicaciones directamente desde Telegram). El segundo es para notificaciones/actividad personales, mientras que el primero sirve para recibir casi todas las publicaciones creadas en tu sitio web en un canal o grupo de Telegram.
2 Me gusta
¿Es posible hacer lo contrario? ¿Que todos los mensajes de un canal de Telegram se publiquen en un tema de Discourse?
6 Me gusta
Es algo interesante de explorar, pero no sé nada sobre esta función.
2 Me gusta
+1, también se me ocurren algunos casos de uso para esto.
¡Ahora puedes usar chat directamente dentro de Discourse, así que realmente no hay necesidad de chat de Telegram en absoluto!
4 Me gusta
