Issue about X preview
There’s an issue with the preview when sharing X posts. What could be the cause?
The previews are not loading at all. There was no such issue 1-2 days ago.
Thanks!
Yea I noticed x oneboxes seem borked. Not sure what the issue is.
https://x.com/discourse/status/1891885982833692805
this theme component works as a fix
Is there no other way? I mean, on your end.
Okay it is not just twitter. All links have the same problem.
Are you sure? Do you have an example of another link that fails?
:arrow_up: that one works well here, from Mastodon.
It’s fixed now. There’s no issue with the websites, but the Twitter issue persists. Isn’t there a way for you to fix this?
we’re still investigating the issue and will update you when we have more info. thank you for your patience. :pray:
Hello! The issue is still not resolved.
Test:
https://x.com/everlyn_asiko/status/1896469056150245494
https://x.com/asmartbear/status/1897763624602513628
Confirmed we have a issue here and will be working getting it sorted within the next weeks.
Thanks for your patience here.
We have identified and fixed the issue:
Example from Sam:
We will be rolling out the fix to our hosting in the coming days :slight_smile:
@baronesh your site has been deployed now, please let us know if you still have any issues.
This has been rolled out to most of our hosted sites now, will set a topic timer to close this 1 week from now.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
