Issue for q2a import
Users are facing issues importing data from Question2Answer and vBulletin5 into Discourse using Docker. sat cannot connect to the MariaDB database, receiving an ‘Access denied for user root@localhost’ error despite having imported the data successfully. pfaffman suggests checking the MySQL connection and hostname settings. INSTAR encounters the same problem and later resolves it by updating the plugin for the root user in MariaDB to mysql_native_password, allowing the discourse user to connect. INSTAR confirms the script now runs, though further vBulletin5-specific errors remain.
I’m importing question2answer site and followed below steps. Script is not able to connect to db. anyone please help me on this.
I took ref from vBulletin thread
Docker install Server
Steps:
  1. Installed discourse using 30 min guide and it worked perfectly fine.
  2. entered app using below commands
cd /var/discourse
./launcher enter app
  1. Installed Mariadb as I was not able to install mysql:
apt-get update && apt-get install libmariadb-dev mariadb-server-10.3
  1. After finishing installing Mariadb check its status and started:
sudo service mysql status
sudo service mysql start
  1. Install dependencies
echo “gem ‘mysql2’, require: false” >> /var/www/discourse/Gemfile
echo “gem ‘php_serialize’, require: false” >> /var/www/discourse/Gemfile
cd /var/www/discourse
su discourse -c ‘bundle install --no-deployment --without test --without development --path vendor/bundle’
  1. Imported database
mysql -uroot -p -e ‘CREATE DATABASE q2adb’
mysql -uroot -p q2adb < q2a-old-db.sql
  1. exported below variables, I dont have any attachments so not exported that variable. also not set password for root user.
export DB_NAME=“q2adb”
export DB_USER=“root”
export DB_PW=“”
export TABLE_PREFIX=“qa_”
export TIMEZONE=“America/Los_Angeles”
su discourse -c ‘bundle exec ruby script/import_scripts/question2answer.rb’
This is the error I’m getting now after running below command.
/var/www/discourse# su discourse -c ‘bundle exec ruby script/import_scripts/question2answer.rb’
root:@localhost wants q2adb
Loading existing groups…
Loading existing users…
Loading existing categories…
Loading existing posts…
Loading existing topics…
Access denied for user ‘root’@‘localhost’
Cannot connect in to database.
Hostname: localhost
Username: root
Password:
database: q2adb
Edit the script or set these environment variables:
export DB_HOST=“localhost”
export DB_NAME=“”
export DB_PW=‘password’
Exiting.
Either you need to set a password or maybe a host name? You installed mysql inside the container?
Can you connect to mysql from the command line and see that there is data there. (Show tables :wink:
@pfaffman
I’m inside container.
I tried setting Hostname to localhost, ‘127.0.0.1’, ip-171-22-11-150 (this is shown as a hostname when I issue command >hostname) and with actual IP address of server.
I also set password for a root users. I do see tables in db got imported correctly from q2a.
Am I missing any step?
discourse experts, please help me on this. I dont know how to proceed at the moment.
Thanks for your help in advance!
The traditional way to incentivize people to give you extra help is to pay money for it, you could post in Marketplace with a budget.
Hello Discourse Community,
@sat have you found a solution for this yet ?
I ran into the same error while trying to migrate from vBulletin5 using the Docker part of the same thread.
I also installed MariaDB instead of MySQL:
I imported my SQL data and I am able to connect to the database and see that the tables are created:
mysqlcheck -c vb5  -u root -p
At first, I used the default login (root / blank) and in a second attempt I set a password for the root user:
export DB_NAME="vb5"
export DB_USER="root"
export DB_PW="password1234"
export TABLE_PREFIX="vb5."
export ATTACHMENT_DIR='/vb5-attachments'
export TIMEZONE='Europe/Berlin'
su discourse -c 'bundle exec ruby script/import_scripts/vbulletin5.rb'
I am not sure about the TABLE_PREFIX here. But all table names start with vb5. in my default installation - so I guess this should be ok (I also tried leaving it empty).
But the main issue is that I cannot connect to the MariaDB database with the discourse user:
Loading existing groups...
Loading existing users...
Loading existing categories...
Loading existing posts...
Loading existing topics...
Traceback (most recent call last):
        5: from script/import_scripts/vbulletin5.rb:632:in `<main>'
        4: from script/import_scripts/vbulletin5.rb:632:in `new'
        3: from script/import_scripts/vbulletin5.rb:27:in `initialize'
        2: from script/import_scripts/vbulletin5.rb:27:in `new'
        1: from /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mysql2-0.5.2/lib/mysql2/client.rb:90:in `initialize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/mysql2-0.5.2/lib/mysql2/client.rb:90:in `connect': Access denied for user 'root'@'localhost' (Mysql2::Error)
su discourse
Enter password: #password1234
mysqlcheck: Got error: 1698: Access denied for user 'root'@'localhost' when trying to connect
Ok I am now a step closer into getting this to work. I was able to get the discourse user to connect.
  1. Connect into the Discourse container as root.
  2. Connect to the MariaDB Database
mysql -u root -p
*enter your password*
update mysql.user set plugin = 'mysql_native_password' where User='root';
FLUSH PRIVILEGES;
EXIT;
Then switch to the discourse user and try to connect to the database with the root account:
su discourse
mysql -u root -p
And you should see the SQL shell, when before you were getting an access denied.
Now exit the discourse user and try to run the migration script again:
exit
Now the script is running (but I am getting a vBulletin5 related error I have to figure out next)
