Ruby mysql2 error on migration
Users are troubleshooting a mysql2 gem error when running a Discourse import script. kodab initially faced issues with the gem not being found, which was resolved by installing libmysqlclient-dev and running bundle install with the IMPORT=1 environment variable. gerhard provided the solution, and kodab confirmed it worked. pgr encountered a password prompt when using su discourse -c, which was resolved by using the correct ./launcher enter app command. pgr also noted that tiny_tds could be commented out if not needed. CarlosDaniel faced a similar issue, which was resolved by installing libmariadb-dev and following the same steps, confirming the solution works on a fresh setup.
Hi guys,
I’m trying to ue the vanilla_mysql.rb importer script to migrate my shitty forum to the awesome discourse platform. :slight_smile: However, when I execute the commands this happens:
root@discourse-app:/var/www/discourse# gem install mysql2 --platform=ruby
Building native extensions. This could take a while…
Successfully installed mysql2-0.4.6
1 gem installed
root@discourse-app:/var/www/discourse# bundle exec ruby script/import_scripts/vanilla_mysql.rb
script/import_scripts/vanilla_mysql.rb:1:in require': cannot load such file -- mysql2 (LoadError) from script/import_scripts/vanilla_mysql.rb:1:in ’
What am I doing wrong / how can I fix it? :frowning: I’m using the default docker container on a clean ubuntu 16.04 vps.
Try this inside the docker container:
apt-get update && DEBIAN_FRONTEND=noninteractive apt-get install -y libmysqlclient-dev
su discourse -c 'export IMPORT=1; bundle install --no-deployment --without test --without development --path vendor/bundle'
su discourse -c 'export IMPORT=1; bundle exec ruby script/import_scripts/vanilla_mysql.rb'
Thanks for your reply. Here is a short version of my output:
**root@discourse-app:/var/www/discourse#: su discourse -c 'export IMPORT=1; bundle install --no-deployment --without test --without development --path vendor/bundle'**
An error occurred while installing mysql2 (0.4.6), and Bundler cannot
continue.
Make sure that `gem install mysql2 -v '0.4.6'` succeeds before bundling.
**root@discourse-app:/var/www/discourse#: exec ruby script/import_scripts/vanilla_mysql.rb'**                               Could not find gem 'mysql2' in any of the gem sources listed in your Gemfile.
Run `bundle install` to install missing gems.
**root@discourse-app:/var/www/discourse#: bundle install**
Bundle complete! 96 Gemfile dependencies, 175 gems now installed.
Gems in the group development were not installed.
Bundled gems are installed into ./vendor/bundle.
**root@discourse-app:/var/www/discourse#: su discourse -c 'export IMPORT=1; bundle exec ruby script/import_scripts/vanilla_mysql.rb'**                               Could not find gem 'mysql2' in any of the gem sources listed in your Gemfile.
:confused:
You need to install a dependency for it to work. I guess it’s missing.
Thank you so mutch Gerhard! :slight_smile: It worked, I owe you.
Hi
I am facing this same situation but I am having trouble issuing these su discourse -c commands, they ask me for a password. I don’t think I created this user, it comes with the Docker container, so how do I get its password? Or how do I avoid being asked for one?
Thanks!
Is this a development install, an install from the standard guide, or something else?
If it’s from the standard guide you shouldn’t be prompted for a password when using su discourse -c from within the container.
Thanks, your confirmation that I “shouldn’t be prompted” sent me searching again, this time in a slightly different direction…
And I solved it! I was using a scripted command to enter the container that had slightly different options than the standard ./launcher enter app. One of them (maybe the absence of the --login option?) was causing this difference in behavior.
Anyway I am going to make sure I always use ./launcher going forward, there’s lots of stuff in there. Once again, thanks for your answer.
Another tip that might be useful for anyone else coming into this thread:
Using that command given above with IMPORT=1 will trigger this part of your Gemfile:
if ENV["IMPORT"] == "1"
  gem 'mysql2'
  gem 'redcarpet'
  gem 'sqlite3', '~> 1.3.13'
  gem 'ruby-bbcode-to-md', github: 'nlalonde/ruby-bbcode-to-md'
  gem 'reverse_markdown'
  gem 'tiny_tds'
I ran into problems with the installation of tiny_tds, and then with another thing it depends on called FreeTDS. After some wasted time on this I realized these are useful only for MS SQL imports, which I won’t be using, so I simply commented out the tiny_tds line in my Gemfile.
(it would be nice to have a comment in front of each of those packages saying what they are used for, if anyone knows)
Ciao. Sto riscontrando lo stesso problema qui durante l’esecuzione di questo script, ma questi comandi non stanno aiutando… Questo è l’output che ottengo quando provo a eseguire su discourse -c 'export IMPORT=1; bundle exec ruby script/import_scripts/vanilla_mysql.rb':
root@ip-xxx-xx-xx-xx-app:/var/www/discourse# su discourse -c 'export IMPORT=1; bundle exec ruby script/import_scripts/snuffhouse.rb'
Stai cercando di installare in modalità di distribuzione dopo aver modificato
il tuo Gemfile. Esegui `bundle install` altrove e aggiungi
il Gemfile.lock aggiornato al controllo di versione.
Se questa è una macchina di sviluppo, rimuovi il blocco /var/www/discourse/Gemfile
eseguendo `bundle config unset deployment`.
L'elenco delle origini è cambiato
Le dipendenze nel tuo gemfile sono cambiate
Hai aggiunto al Gemfile:
* mysql2
* redcarpet
* sqlite3 (~> 1.3, >= 1.3.13)
* ruby-bbcode-to-md
* reverse_markdown
* tiny_tds
* csv
Ciao, ho risolto e ho dimenticato di rispondere qui. Il fatto è che stavo cercando di eseguire uno script di migrazione per un forum che utilizza mysql e stavo riscontrando alcuni errori. Ma ho appena seguito i seguenti passaggi e ha funzionato bene:
  • All’interno della tua docker-machine dove è in esecuzione Discourse:
# Entra nella directory del progetto
cd /var/www/discourse
# Installa le dipendenze MySQL
apt-get update && DEBIAN_FRONTEND=noninteractive apt-get install -y libmariadb-dev
# Installa le gemme MySQL (export = 1)
su discourse -c 'export IMPORT=1; bundle install'
# Esegui il tuo script (vanilla_mysql in questo caso)
Ho appena fatto questo su una nuova macchina che ho dovuto avviare e ha funzionato bene.
