We set Nginx has a front-end proxy for discourse docker (with sock Add an offline page to display when Discourse is rebuilding or starting up).
Then we set HTTPS Lets’ Encrypt outside the container (acme.sh) and everything works fine except onebox for internal link.
Onebox is not able to show the preview of internal links. They are as external links
Just made a backup, we will try to check the “force_https” setting. Do you confirm that even if discourse runs through sock, and so the “ssl template” is commented out, everything should work fine?
Our reverse proxy is configured to redirect all http traffic to https.
