בעיית בסיס נתונים לא נמצא בעת ביצוע משימה ב-Discourse
סיכום מבוסס בינה מלאכותית
evenlo reported a background job error in Discourse stating “We could not find your database: community,” despite the frontend working normally. The error suggests the database may not exist or the name in config/database.yml is incorrect, with a suggested fix: bin/rails db:create. pfaffman asked if this was a standard install and how Discourse was launched. evenlo confirmed following the official INSTALL-cloud.md guide. pfaffman shared a similar multisite issue, possibly caused by duplicating a site in multisite.conf. evenlo later resolved the issue by killing a duplicate Sidekiq process — possibly left over from a prior upgrade — which had been interfering with job execution. The root cause appears to be stale or conflicting Sidekiq workers rather than a missing database.
Hello Discourse Community,
I am experiencing an issue with my Discourse setup, specifically when executing background jobs. The error does not affect the frontend of the forum, which continues to operate normally.
The error message form /admin/logs is as follows:
Message
Job exception: We could not find your database: community. Which can be found in the database configuration file located at config/database.yml.
To resolve this issue:
- Did you create the database for this app, or delete it? You may need to create your database.
- Has the database name changed? Check your database.yml config has the correct database name.
To create your database, run:
        bin/rails db:create
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:81:in rescue in new_client'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:77:in new_client'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:37:in postgresql_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:656:in public_send'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:656:in new_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:700:in checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:679:in try_to_checkout_new_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:640:in acquire_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:341:in checkout'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:181:in connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_handler.rb:211:in retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_handling.rb:313:in retrieve_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_handling.rb:280:in connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/core.rb:433:in cached_find_by_statement'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/core.rb:317:in find_by'
/var/www/discourse/app/jobs/regular/export_user_archive.rb:120:in execute'
/var/www/discourse/app/jobs/base.rb:305:in block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-6.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in with_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-6.0.0/lib/rails_multisite/connection_management.rb:21:in with_connection'
/var/www/discourse/app/jobs/base.rb:292:in block in perform'
/var/www/discourse/app/jobs/base.rb:288:in each'
/var/www/discourse/app/jobs/base.rb:288:in perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:202:in execute_job'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:170:in block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:177:in block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:132:in call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:179:in block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:182:in invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:169:in block in process'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:136:in block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:113:in local'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:135:in block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq.rb:44:in block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:131:in block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:263:in stats'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:126:in block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:13:in call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:125:in block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:80:in global'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:124:in block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:39:in prepare'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:123:in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:168:in process'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:78:in process_one'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:68:in run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:8:in watchdog'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:17:in block in safe_thread'
In the frontend the database is working well:
The community uses a separate PostgreSQL server.
How do I fix this issue? Thanks.
I guess this isn’t a standard install? How are you launching Discourse?
Hi @pfaffman
I’ve followed this official guide to install discourse: INSTALL-cloud.md
Hmm. I have a multisite instance that I set up yesterday that is working fine but seems to be using the wrong username when running a backup.
EDIT: I think it was because I duplicated a site the main site with a site in the multisite.conf file.
What actions are causing problems?
Hi,
I found there is a depulicated process in /sidekiq
I killed old process and now the job is working.
I dunno why there is a depulicated process in the sidekiq. (I’ve did upgrade discourse version before, maybe is it caused?)
