Issues with CPT lessons (using Learndash Plugin) sync to Discourse
Hey guys,
I have been running into an issue with a CPT created my Learndash LMS plugin Learndash plugin disables custom fields by default. I used a plugin to basically enable and add those CFs to learndash’s post types and gave them same labels/names
While the post content is added successfully to discourse, the discourse link is not written into the CF’s and not saved.
How could I troubleshoot this?
Hey @jrgong,
Why does Learndash disable custom fields? Have you talked with Learndash about this?
Ah never mind, the setting to enable Custom Fields in Learndash’s post types was a bit hard to find.
If anyone else has same issue, you can enable them here: Global Lesson Settings - LearnDash Support
