Issues with Embeding Comments
Hello All, I am trying to use Discourse for commenting on my website and I have set it up in a dev environment but having issues. For some reason it looks like Discourse can you read my website on port 5000 (not sure) as I run it locally on my machine. I am getting the error below
INFO:
Job exception: Connection refused - connect(2)
Backtrace
/usr/local/lib/ruby/2.0.0/net/http.rb:878:in `initialize'
/usr/local/lib/ruby/2.0.0/net/http.rb:878:in `open'
/usr/local/lib/ruby/2.0.0/net/http.rb:878:in `block in connect'
/usr/local/lib/ruby/2.0.0/timeout.rb:52:in `timeout'
/usr/local/lib/ruby/2.0.0/net/http.rb:877:in `connect'
/usr/local/lib/ruby/2.0.0/net/http.rb:862:in `do_start'
/usr/local/lib/ruby/2.0.0/net/http.rb:851:in `start'
/usr/local/lib/ruby/2.0.0/open-uri.rb:313:in `open_http'
/usr/local/lib/ruby/2.0.0/open-uri.rb:709:in `buffer_open'
/usr/local/lib/ruby/2.0.0/open-uri.rb:210:in `block in open_loop'
/usr/local/lib/ruby/2.0.0/open-uri.rb:208:in `catch'
/usr/local/lib/ruby/2.0.0/open-uri.rb:208:in `open_loop'
/usr/local/lib/ruby/2.0.0/open-uri.rb:149:in `open_uri'
/var/www/discourse/lib/freedom_patches/open_uri_redirections.rb:70:in `open_uri'
/usr/local/lib/ruby/2.0.0/open-uri.rb:689:in `open'
/usr/local/lib/ruby/2.0.0/open-uri.rb:34:in `open'
/var/www/discourse/app/models/topic_embed.rb:79:in `find_remote'
/var/www/discourse/app/models/topic_embed.rb:106:in `import_remote'
/var/www/discourse/lib/topic_retriever.rb:56:in `fetch_http'
/var/www/discourse/lib/topic_retriever.rb:43:in `perform_retrieve'
/var/www/discourse/lib/topic_retriever.rb:10:in `retrieve'
/var/www/discourse/app/jobs/regular/retrieve_topic.rb:16:in `execute'
/var/www/discourse/app/jobs/base.rb:154:in `block (2 levels) in perform'
Env
hostname	ubuntu-app
process_id	[92, 88, 157]
application_version	992386b22e59758411215b37d66eab445d1060b1
current_db	default
current_hostname	gist.domain.com
job	Jobs::RetrieveTopic
problem_db	default
opts
user_id	1
embed_url	[http://dev.domain.com:5000/567270/nigerianwedding/nigerianwedding-yorubabride, http://dev.domain.com:5000/370252/nigerianwedding/edobride-nigerianwedding, http://dev.domain.com:5000/539986/nigerianwedding/nigerianwedding-yorubabride, http://dev.domain.com:5000/115693/realmichellew/melangemode-peplumblazer-michellewilliams]
current_site_id	default
Just to add, I can ping in both directions - gist.domain.com <> dev.domain.com
I will appreciate any suggestions. Thanks
I am now using a live server and this issue seems to be resolved. It seems like the parser did not like port 5000 “:5000”
