Problemen met Theme Components [JavaScript]
I have a problem with JavaScript. When I upload it, it doesn’t work. If I write everything into an HTML file and open it locally, it works fine. But when I put it into a theme component, it doesn’t work.
The button doesn’t work when clicked.
It works fine when opened locally using HTML.
The close button in the top right corner behaves the same way.
Combine CSS and JavaScript in HTML
<html>
	<head>
		<meta charset="utf-8">
		<style>
			/*右侧悬浮box和赞赏码*/
/* 悬浮盒子 */
.guigui_xfkp {
	position: fixed;
	right: 120px;
	bottom: 50px;
	box-sizing: border-box;
	padding: 18px 10px 22px 20px;
	width: 400px;
	height: 175px;
	border-radius: 20px;
	background-color: #ffffff;
	background-position: right 50%;
	background-repeat: no-repeat;
	background-size: 130px;
	box-shadow: 0px 0px 8px rgba(236, 59, 136, 0.35);
	/*background-image: url(https://cache.cenguigui.cn/images/loginee.png);*/
	transition: right 1s linear 0s;
	z-index: 3;
	animation: jinru 2s;
	-webkit-animation: jinru 2s;
	--guigui_right: -500px;
	--guigui_right_go: 120px;
@keyframes jinru {
	0% {
		right: var(--guigui_right);
	100% {
		right: var(--guigui_right_go);
.guigui_biaoti {
	margin-bottom: 10px;
	color: rgb(0, 0, 0);
	font-weight: bold;
	font-size: 20px;
#guigui_jzsc {
	color: #000000;
.guigui_text {
	margin: 15px 0;
	color: rgb(255, 127, 227);
.guigui_zanzhu {
	width: 100px;
	height: 35px;
	text-align: center;
	line-height: 35px;
	border-radius: 10px;
	background-color: #ffb5c3;
.guigui_zanzhu p {
	color: #ffffff;
	font-weight: bold;
	display: block;
	width: 100px;
	height: 35px;
	cursor: pointer;
.guigui_zanzhu p:hover {
	transition: 0.8s all;
	color: rgb(247, 54, 86);
.guigui_xfkpgb {
	width: 30px;
	height: 30px;
	position: absolute;
	top: 10px;
	right: 10px;
	cursor: pointer;
.guigui_xfkpgb svg {
	width: 30px;
	height: 30px;
	transform: rotate(0deg);
	transition: transform 0.5s linear 0s;
.guigui_xfkpgb svg:hover {
	transform: rotate(-720deg);
/* 赞助box */
/* 二维码 */
.guigui_skm_box {
	/* display: none; */
	position: fixed;
	z-index: 3;
	right: 150px;
	bottom: 300px;
	width: 475px;
	height: 175px;
	padding-top: 38px;
	/* 收款码box方框 */
	background: url(https://cache.cenguigui.cn/images/ds/bg-cat-main.png) no-repeat top;
	background-size: 100% auto;
	transition: right 2s linear 0s;
	animation: guigui_skmdh 2s;
	/* --guigui_skm:-500px;
	--guigui_skm_to:150px; */
@keyframes guigui_skmdh {
	0% {
		right: var(--guigui_skm);
		opacity: 0;
	100% {
		right: var(--guigui_skm_to);
		opacity: 1;
.guigui_skm {
	width: 475px;
	height: 190px;
	display: flex;
	padding: 10px;
	border: 1px solid #FFB5C3;
	border-radius: 8px;
	box-shadow: inset 0 5px 25px 0 #FFD1D8;
.guigui_skm_img_p {
	width: 400px;
	height: 175px;
	cursor: default;
.guigui_skm_img_p img {
	width: 150px;
	height: 150px;
.guigui_skm_img_p p {
	text-align: center;
	font-weight: bold;
				/* padding-top: 10px; */
	color: #000000;
.guigui_skm svg {
	position: absolute;
	top: 20px;
	right: -20px;
	width: 30px;
	height: 30px;
	cursor: pointer;
.guigui_skm svg:hover {
	/* 手机端隐藏美化赞赏码 */
@media screen and (max-width:990px) {
	/* 隐藏悬浮的box */
	.guigui_xfkp {
		display: none;
	/* 美化赞赏码box */
	.guigui_skm_box {
		display: none;
/* 手机端打赏码 */
.guigui_reward {
	font-size: 16px;
	text-align: center;
	display:
		none;
#rewardButton {
	/* border: 1px solid#f77b83; */
	background-color:
		#00000000;
	line-height: 36px;
	text-align: center;
	cursor: pointer;
	height:
		36px;
	display: block;
	border-radius: 4px;
	transition-duration: .4s;
	color:
		#fff;
	margin: 0 auto;
	padding: 0 25px;
	outline-style: none;
#QR {
	padding-top:
		20px;
#QR img {
	width: 180px;
	max-width: 100%;
	display: inline-block;
	margin: .8em 2em 0;
	border: 1px solid #ddd;
	padding: 3px;
	background: #f8f8f8;
/* 手机端隐藏美化赞赏码 */
@media screen and (max-width:980px) {
	/* 显示简易版的打赏 */
	.guigui_reward {
		display: block;
</style>
		<script>
			// 右侧悬浮box和赞赏码
			// 赞助js
			// 打开赞赏码
			//1
			function guigui_skmkq() {
			    const xfxkp = document.getElementById('guigui_skmqk');
			    if (xfxkp) {
			        // 设置动画的开始和结束位置为正向
			        xfxkp.style.setProperty('--guigui_right', '-500px');
			        xfxkp.style.setProperty('--guigui_right_go', '120px');
			        // 确保元素是可见的
			        xfxkp.style.display = 'block';
			        // 重新触发动画
			        xfxkp.style.animation = 'none'; // 首先移除动画以重置
			        xfxkp.offsetHeight; // 触发重绘
			        xfxkp.style.animation = 'jinru 3s forwards'; // 应用新的动画
			// 关闭赞赏码
			function guigui_guanbi_skm() {
			    if (xfxkp) {
			        // 设置动画的开始和结束位置为反向
			        xfxkp.style.setProperty('--guigui_skm', '150px');
			        xfxkp.style.setProperty('--guigui_skm_to', '-500px');
			        // 重新触发动画
			        xfxkp.style.animation = 'guigui_skmdh 2s forwards'; // 应用新的动画
			        xfxkp.addEventListener('animationend',
			            function () {
			                xfxkp.style.display = 'none'; // 动画完成后隐藏元素
			                once: true //我不知道
			// 关闭右下方悬浮盒子
			function guanbi() {
			    const xfxkp = document.getElementById('guigui_xfxkp');
			    if (xfxkp) {
			        // 设置动画的开始和结束位置为反向
			        xfxkp.style.setProperty('--guigui_right', '120px');
			        xfxkp.style.setProperty('--guigui_right_go', '-500px');
			        // 重新触发动画
			            function () {
			                once: true
		</script>
		<script>
			window._iconfont_svg_string_4458810='<svg><symbol id="icon-guanbi" viewBox="0 0 1024 1024"><path d="M512 45.373397c-257.710456 0-466.626603 208.916147-466.626603 466.626603s208.915124 466.626603 466.626603 466.626603 466.626603-208.915124 466.626603-466.626603S769.710456 45.373397 512 45.373397zM754.945171 664.329361c22.561855 22.561855 22.561855 59.482743 0 82.044598l-20.511149 20.511149c-22.561855 22.561855-59.482743 22.561855-82.044598 0L506.030032 620.524692 359.670639 766.884085c-22.561855 22.561855-59.482743 22.561855-82.044598 0l-20.511149-20.511149c-22.561855-22.561855-22.561855-59.482743 0-82.044598l146.359392-146.359392L245.175979 359.670639c-22.561855-22.561855-22.561855-59.482743 0-82.044598l20.511149-20.511149c22.561855-22.561855 59.482743-22.561855 82.044598 0L506.030032 415.414221l158.298306-158.298306c22.561855-22.561855 59.482743-22.561855 82.044598 0l20.511149 20.511149c22.561855 22.561855 22.561855 59.482743 0 82.044598L608.585779 517.968945 754.945171 664.329361z" fill="#ffb5c3" ></path></symbol></svg>',function(n){var t=(t=document.getElementsByTagName("script"))[t.length-1],e=t.getAttribute("data-injectcss"),t=t.getAttribute("data-disable-injectsvg");if(!t){var i,o,c,d,s,l=function(t,e){e.parentNode.insertBefore(t,e)};if(e&&!n.__iconfont__svg__cssinject__){n.__iconfont__svg__cssinject__=!0;try{document.write("<style>.svgfont {display: inline-block;width: 1em;height: 1em;fill: currentColor;vertical-align: -0.1em;font-size:16px;}</style>")}catch(t){console&&console.log(t)}}i=function(){var t,e=document.createElement("div");e.innerHTML=n._iconfont_svg_string_4458810,(e=e.getElementsByTagName("svg")[0])&&(e.setAttribute("aria-hidden","true"),e.style.position="absolute",e.style.width=0,e.style.height=0,e.style.overflow="hidden",e=e,(t=document.body).firstChild?l(e,t.firstChild):t.appendChild(e))},document.addEventListener?~["complete","loaded","interactive"].indexOf(document.readyState)?setTimeout(i,0):(o=function(){document.removeEventListener("DOMContentLoaded",o,!1),i()},document.addEventListener("DOMContentLoaded",o,!1)):document.attachEvent&&(c=i,d=n.document,s=!1,r(),d.onreadystatechange=function(){"complete"==d.readyState&&(d.onreadystatechange=null,a())})}function a(){s||(s=!0,c())}function r(){try{d.documentElement.doScroll("left")}catch(t){return void setTimeout(r,50)}a()}}(window);
		</script>
		<script>
			  * TypeIt - The most versatile animated typing utility on the planet.
			  * Author: Alex MacArthur <alex@macarthur.me> (https://macarthur.me)
			  * Version: v7.0.4
			  * License: GPL-2.0
			  * URL: https://typeitjs.com
			!function(n,t){"object"==typeof exports&&"undefined"!=typeof module?module.exports=t():"function"==typeof define&&define.amd?define(t):(n=n||self).TypeIt=t()}(this,(function(){"use strict";function n(t){return(n="function"==typeof Symbol&&"symbol"==typeof Symbol.iterator?function(n){return typeof n}:function(n){return n&&"function"==typeof Symbol&&n.constructor===Symbol&&n!==Symbol.prototype?"symbol":typeof n})(t)}var t={strings:[],speed:100,cursor:!0,cursorChar:"|",cursorSpeed:1e3,deleteSpeed:null,lifeLike:!0,breakLines:!0,startDelay:250,startDelete:!1,nextStringDelay:750,loop:!1,loopDelay:750,html:!0,waitUntilVisible:!1,beforeString:function(){},afterString:function(){},beforeStep:function(){},afterStep:function(){},afterComplete:function(){}},e=function(n){return n.map((function(n){return void 0===n[1]&&n.push(null),void 0===n[2]&&n.push({}),n}))},r=function(n,t){return Object.assign({},n,t)},i=function(n){return Array.isArray(n)},o=function(n,t){return n[2]=r(n[2],t)||t,n},u=function(n,t){return i(n[0])?n.map((function(n){return o(n,t)})):o(n,t)},c=function(n,t,e,r){r=r||!1,e=e||{};var o=!i(n),c=n.length;return(n=o?new Array(n).fill(0):n).map((function(n,i){if(o)return t;var a=[t,n,e];return r&&(0===i&&(a=u(a,{isFirst:!0})),i+1===c&&(a=u(a,{isLast:!0}))),a}))};function a(n){this.insert=function(n,e){t.splice(n,0,e)},this.add=function(n,u,a){return n=i(n)?n:[n,null],a=a||!1,u=u||1,i(n[0])||(n=c(u,n)),n=e(n).map((function(n){return n[2]=r(n[2],{id:o}),o++,n})),t=a?n.concat(t):t.concat(n),this},this.set=function(n,e){t[n]=e},this.reset=function(){t=t.map((function(n){return n[2].executed=!1,n}))},this.getItems=function(){return(t=e(t)).filter((function(n){return!n[2].executed}))},this.setMeta=function(n,e){var i=t.findIndex((function(t){return t[2].id===n}));t[i][2]=r(t[i][2],e)};var t=[],o=0;this.add(n)}var f=function(n){return Array.from(n)},s=function(n){var t=[];return t.concat.apply(t,n)},l=function(n){var t=document.implementation.createHTMLDocument("");return t.body.innerHTML=n,t.body},d=function n(t,e,r){e=e||null,r=void 0!==r&&r;var i=f(t.childNodes).map((function(t){return 3===(e=t).nodeType||"BR"===e.tagName?t:n(t);var e}));return i=s(i),e&&(i=i.filter((function(n){return!e.contains(n)}))),r?i.reverse():i},p=function(n){return"BODY"===n.tagName},h=function(n,t){t=t||null;var e=n instanceof HTMLElement;return{node:t,isTopLevelText:(!t||p(t.parentNode))&&!e,isHTMLElement:e,content:n}};function v(n){var t,e=l(n);return t=d(e).map((function(n){return n.nodeValue?f(n.nodeValue).map((function(t){return h(t,n)})):h(n)})),s(t)}function y(n,t){return(t=void 0===t||t)?v(n):f(n).map((function(n){return h(n)}))}var m=function(n){return document.createElement(n)},g=function(n,t){var e=m("style");e.id=t||"",e.appendChild(document.createTextNode(n)),document.head.appendChild(e)},b=function(n){return i(n)||(n=[n/2,n/2]),{before:n[0],after:n[1],total:n[0]+n[1]}},S=function(n,t){return Math.abs(Math.random()*(n+t-(n-t))+(n-t))};var N=function(n){return["textarea","input"].indexOf(n.tagName.toLowerCase())>-1},T=function(n,t){var e=t.querySelectorAll("*");return[t].concat(f(e).reverse()).find((function(t){return t.cloneNode().outerHTML===n.outerHTML}))},L=function(n,t,e,r){e=e||null;var i=t.isHTMLElement,o=i?t.content:document.createTextNode(t.content);if(N(n))n.value="".concat(n.value).concat(t.content);else{if(!t.isTopLevelText&&!i){var u=t.node.parentNode,c=T(u.cloneNode(),n);if(function(n,t){if(!n)return!1;var e=n.nextSibling;return!e||e.isEqualNode(t)}(c,e))n=c;else if((o=u.cloneNode()).innerText=t.content,!p(u.parentNode)){for(var a=u.parentNode,f=a.cloneNode(),s=T(f,n);!s&&!p(a);)f.innerHTML=o.outerHTML,o=f,f=a.parentNode.cloneNode(),a=a.parentNode,s=T(f,n);n=s||n}}var l=d(n,e,!0)[r-1],h=l?l.parentNode:n;h.insertBefore(o,h.contains(e)?e:null)}},M=function(n){var t;return null==n||null===(t=n.parentNode)||void 0===t?void 0:t.removeChild(n)};var x=function(n,t,e){var r,i="string"==typeof n,o=!1,u=-1*n;return i&&(u=(r="END"===n.toUpperCase())?-1:1,o=r?t+u>0:t+u<e.length),{isString:i,numberOfSteps:u,canKeepMoving:o}},w=function(n){var t,e=["font","lineHeight","color"],r=m("SPAN"),i=(t=n,window.getComputedStyle(t,null));for(var o in i)e.indexOf(o)>-1&&i[o]&&(r.style[o]=i[o]);return r.style.cssText};function D(n,t,e){return e?t?t(n):n:(n&&n.then||(n=Promise.resolve(n)),t?n.then(t):n)}function H(n){return function(){for(var t=[],e=0;e<arguments.length;e++)t[e]=arguments[e];try{return Promise.resolve(n.apply(this,t))}catch(n){return Promise.reject(n)}}}function E(){}function C(n,t){if(!t)return n&&n.then?n.then(E):Promise.resolve()}function A(n,t){var e=n();return e&&e.then?e.then(t):t(e)}function k(n,t,e){if(!n.s){if(e instanceof O){if(!e.s)return void(e.o=k.bind(null,n,t));1&t&&(t=e.s),e=e.v}if(e&&e.then)return void e.then(k.bind(null,n,t),k.bind(null,n,2));n.s=t,n.v=e;var r=n.o;r&&r(n)}}var O=function(){function n(){}return n.prototype.then=function(t,e){var r=new n,i=this.s;if(i){var o=1&i?t:e;if(o){try{k(r,1,o(this.v))}catch(n){k(r,2,n)}return r}return this}return this.o=function(n){try{var i=n.v;1&n.s?k(r,1,t?t(i):i):e?k(r,1,e(i)):k(r,2,i)}catch(n){k(r,2,n)}},r},n}();function P(n,t){return n&&n.then?n.then(t):t(n)}return function(e,o){var u=this,s=this;o=o||{};var p=function(n,t,e){return n=i(n[0])?n:[n],an.add(n,t),function(n){var t=(n=n||{}).delay;t&&an.add([U,t])}(e),s},T=function(t){return t="object"===n(t)?t:{},[[Q,t,{force:!0}],[Q,en,{force:!0}]]},z=function(){return X?f(W.value):d(W,fn,!0)},B=function(n,t){t=t||1;var e=en.nextStringDelay;an.insert(n,[U,e.before]),an.insert(n+t+1,[U,e.after])},I=H((function(){if(fn){var n="[data-typeit-id='".concat(cn,"'] .ti-cursor");g("@keyframes blink-".concat(cn," { 0% {opacity: 0} 49% {opacity: 0} 50% {opacity: 1} } ").concat(n," { animation: blink-").concat(cn," ").concat(en.cursorSpeed/1e3,"s infinite; } ").concat(n,".with-delay { animation-delay: 500ms; } ").concat(n,".disabled { animation: none; }"),cn),W.appendChild(fn);var t="loaded"===document.fonts.status;return D(t||document.fonts.ready,(function(n){var t=fn.getBoundingClientRect().width/2;fn.style.margin="0 -".concat(t+2,"px 0 -").concat(t-2,"px")}),t)}})),R=function(n){fn&&(fn.classList.toggle("disabled",n),fn.classList.toggle("with-delay",!n))},q=H((function(n,t){return $.push(setTimeout(n,t)),D()})),j=H((function(n){var t=_;return D(t&&F(_),(function(t){return an.reset(),an.set(0,[U,n.before]),C(G(!0))}),!t)})),V=H((function(){tn.started=!0;var n,t=an.getItems();return P(function(n,t){try{var e=n()}catch(n){return t(n)}return e&&e.then?e.then(void 0,t):e}((function(){return P(function(n,t,e){var r,i,o=-1;return function u(c){try{for(;++o<n.length&&(!e||!e());)if((c=t(o))&&c.then){if(!((a=c)instanceof O&&1&a.s))return void c.then(u,i||(i=k.bind(null,r=new O,2)));c=c.v}r?k(r,1,c):r=c}catch(n){k(r||(r=new O),2,n)}var a}(),r}(t,(function(e){if(tn.frozen||tn.destroyed)throw"";var r,i,o,c,a=t[e],f=a[2];return n=[a,u],f.freezeCursor&&R(!0),r=en.speed,i=en.deleteSpeed,o=en.lifeLike,c=(i=null!==i?i:r/3)/2,Z=o?[S(r,r/2),S(i,c)]:[r,i],A((function(){var t;if(null==f?void 0:f.isFirst)return C((t=en).beforeString.apply(t,n))}),(function(){var t;return D((t=en).beforeStep.apply(t,n),(function(){return D(a[0].call(u,a[1],f),(function(){return A((function(){var t,e;if(null===(t=a[2])||void 0===t?void 0:t.isLast)return C((e=en).afterString.apply(e,n))}),(function(){var t;return D((t=en).afterStep.apply(t,n),(function(){an.setMeta(f.id,{executed:!0}),R(!1)}))}))}))}))}))}),(function(){return!1})),(function(t){var e;return tn.completed=!0,D((e=en).afterComplete.apply(e,n),(function(){if(!en.loop)throw"";var n=en.loopDelay;q((function(){return D(j(n),(function(){V()}))}),n.after)}))}))}),E),(function(n){return u}))})),U=function(n){return new Promise((function(t){q((function(){return t()}),n||0)}))},F=function n(t){var e=z(),r=x(t,_,e);return _+=r.numberOfSteps,new Promise((function(t){q(H((function(){return function(n,t,e,r){if(e){var i=r,o=t[(i=i>t.length?t.length:i)-1];(n=o?o.parentNode:n).insertBefore(e,o||null)}}(W,z(),fn,_),A((function(){if(r.isString&&r.canKeepMoving)return C(n(r.numberOfSteps>0?"START":"END"))}),(function(){return t()}))})),Z[0])}))},K=function(n){return new Promise((function(t){q((function(){return L(W,n,fn,_),t()}),Z[0])}))},Q=H((function(n){en=r(en,n)})),Y=H((function(){X?W.value="":z().forEach((function(n){M(n)}))})),G=function n(t){return t=!0===t,new Promise((function(e){q(H((function(){var r=!1,i=z();return i.length&&(X?W.value=W.value.slice(0,-1):M(i[_])),f(W.querySelectorAll("*")).forEach((function(n){if(!n.innerHTML&&"BR"!==n.tagName){for(var t=n;1===t.parentNode.childNodes.length&&t.parentNode.childNodes[0].isEqualNode(t);)t=t.parentNode;M(t)}})),A((function(){if(t&&i.length-1>0)return D(n(!0),(function(){return r=!0,e()}))}),(function(n){return r?n:e()}))})),Z[1])}))};this.break=function(n){return p([K,h(m("BR"))],1,n)},this.delete=function(n,t){var e=T(t);return p([e[0]].concat([].concat(Array(Math.abs(n)||1)).fill().map((function(){return[G,!n,nn]})),[e[1]]),1,t)},this.empty=function(){return p(Y,1,arguments)},this.exec=function(n,t){var e=T(t);return p([e[0],[n,null],e[1]],1,t)},this.move=function(n,t){var e=x(n,_,z()),r=T(t),i=e.isString?n:Math.sign(n);return p([r[0]].concat([].concat(Array(Math.abs(n)||1)).fill().map((function(){return[F,i,nn]})),[r[1]]),1,t)},this.options=function(n){return p([Q,n],1,n)},this.pause=function(n,t){return p([U,n],1,t)},this.type=function(n,t){var e=T(t),r=y(n,en.html),i=[e[0]].concat(c(r,K,nn,!0),[e[1]]);return p(i,1,t)},this.is=function(n){return tn[n]},this.destroy=function(n){n=void 0===n||n,$.forEach((function(n){clearTimeout(n)})),$=[],n&&M(fn),tn.destroyed=!0},this.freeze=function(){tn.frozen=!0},this.unfreeze=function(){tn.frozen=!1,V()},this.reset=function(){for(var n in!this.is("destroyed")&&this.destroy(),an.reset(),_=0,tn)tn[n]=!1;return X?W.value="":W.innerHTML="",this},this.go=function(){return tn.started?this:(I(),en.waitUntilVisible?(function(n,t){new IntersectionObserver((function(e,r){e.forEach((function(e){e.isIntersecting&&(t(),r.unobserve(n))}))}),{threshold:1}).observe(n)}(W,V.bind(this)),this):(V(),this))},this.getQueue=function(){return an},this.getOptions=function(){return en},this.getElement=function(){return W};var J,W="string"==typeof(J=e)?document.querySelector(J):J,X=N(W),Z=[],$=[],_=0,nn={freezeCursor:!0},tn={started:!1,completed:!1,frozen:!1,destroyed:!1},en=r(t,o);en=r(en,{html:!X&&en.html,nextStringDelay:b(en.nextStringDelay),loopDelay:b(en.loopDelay)});var rn,on,un,cn=Math.random().toString().substring(2,9),an=new a([U,en.startDelay]);W.setAttribute("data-typeit-id",cn),g("[data-typeit-id]:before {content: '.'; display: inline-block; width: 0; visibility: hidden;}[data-typeit-id]"),en.strings=(un=en.strings,rn=i(un)?un:[un],(on=function(n){return n.innerHTML.replace(/<\!--.*?-->/g,"").trim()}(W))?(W.innerHTML="",en.startDelete?(v(on).forEach((function(n){L(W,n,fn,_)})),an.add([G,!0]),B(1),rn):[on.trim()].concat(rn)):rn);var fn=function(){if(X||!en.cursor)return null;var n=m("span");return n.innerHTML=l(en.cursorChar).innerHTML,n.className="ti-cursor",n.style.cssText="display:inline;".concat(w(W)),n}();en.strings.length&&function(){var n=en.strings.filter((function(n){return!!n}));n.forEach((function(t,e){var r=y(t,en.html);an.add(c(r,K,nn,!0));var i=an.getItems().length;if(e+1!==n.length){if(en.breakLines){var o=h(m("BR"));return an.add([K,o,nn]),void B(i)}an.add(c(r,G,nn)),B(i,t.length)}}))}()}}));
		</script>
	</head>
	<body>
		<!-- 右下角卡片 -->
		<div class="guigui_xfkp" id="guigui_xfxkp" style="background-image: url(https://mms0.baidu.com/it/u=1094456095,3224255275&amp;fm=253&amp;app=138&amp;f=JPEG?w=500&amp;h=500);">
			<div class="guigui_biaoti" data-typeit-id="4846635">
				<span class="ti-cursor with-delay" style="display: inline; color: rgb(0, 0, 0); font: 700 20px GuiguiFontStyle; margin: 0px -4.67188px 0px -0.671875px;">|</span>
			</div>
			<div id="guigui_jzsc"></div>
			<div class="guigui_text" data-typeit-id="8524720">
				<span class="ti-cursor with-delay" style="display: inline; color: rgb(255, 127, 227); font: 14px GuiguiFontStyle;">|</span>
			</div>
			<div class="guigui_zanzhu" onclick="guigui_skmkq()">
				<p>
					赞助一下
				</p>
			</div>
			<div class="guigui_xfkpgb" onclick="guanbi()">
				<svg class="icon" aria-hidden="true">
					<use xlink:href="#icon-guanbi">
					</use>
				</svg>
			</div>
		</div>
		<!-- 右下角卡片 end-->
		<!-- 赞赏码 -->
		<div class="guigui_skm_box" id="guigui_skmqk" style="display: none;">
			<div class="guigui_skm">
				<div class="guigui_skm_img_p">
					<!-- QQ收款码 -->
					<img data-src="https://cache.cenguigui.cn/images/ds/qqskm.jpg" alt="" src="./笒鬼鬼api_files/qqskm.jpg">
					<p>
						QQ收款码
					</p>
				</div>
					<!-- 微信收款码 -->
					<img data-src="https://cache.cenguigui.cn/images/ds/wxskm.jpg" alt="" src="./笒鬼鬼api_files/wxskm.jpg">
					<p>
						微信收款码
					</p>
				</div>
					<!-- 支付宝收款码 -->
					<img data-src="https://cache.cenguigui.cn/images/ds/zfbskm.jpg" alt="" src="./笒鬼鬼api_files/zfbskm.jpg">
					<p>
						支付宝收款码
					</p>
				</div>
				<span onclick="guigui_guanbi_skm()">
					<svg class="guigui_icon" aria-hidden="true">
						</use>
					</svg>
				</span>
			</div>
		</div>
		<!-- 手机端赞赏码 -->
		<div class="guigui_reward">
			<button id="rewardButton" disable="enable" onclick="var qr = document.getElementById(&#39;QR&#39;); if (qr.style.display === &#39;none&#39;) {qr.style.display=&#39;block&#39;;} else {qr.style.display=&#39;none&#39;}">
				<span>
					打赏
				</span>
			</button>
			<div id="QR" style="display: none;">
				<div id="wechat" style="display: inline-block">
					<a class="fancybox" rel="group">
						<img id="wechat_qr" src="./笒鬼鬼api_files/wxskm.jpg" alt="微信打赏">
					</a>
					<p>
						微信
					</p>
				</div>
				<div id="alipay" style="display: inline-block">
						<img id="alipay_qr" src="./笒鬼鬼api_files/zfbskm.jpg" alt="还是支付宝打赏">
					</a>
					<p>
						支付宝
					</p>
				</div>
			</div>
		</div>
		<!-- 加载打字js -->
		<script type="text/javascript">
			// 计算本站安全运行时长的函数
					    // 获取id为guigui_jzsc的div元素
					    var div = document.getElementById('guigui_jzsc');
					    function getRunningTime() {
					        var now = new Date();
					        var startDate = new Date('2022-08-15'); // 假设站点开始运行的日期
					        var diff = now - startDate; // 相差的毫秒数
					        // 计算完整年份
					        var years = now.getFullYear() - startDate.getFullYear();
					        // 检查是否需要调整年份(如果今年的当前日期还没到开始日期,则减去一年)
					        if (now.getMonth() < startDate.getMonth() || (now.getMonth() === startDate.getMonth() && now.getDate() < startDate.getDate())) {
					            years--;
					        // 调整startDate到当前年份的相同月日,以计算剩余的天数
					        startDate.setFullYear(now.getFullYear());
					        // 如果经过调整后的startDate大于当前日期,则需要将startDate再往前调整一年
					        if (startDate > now) {
					            startDate.setFullYear(now.getFullYear() - 1);
					        diff = now - startDate; // 重新计算相差的毫秒数
					        var days = Math.floor(diff / (1000 * 60 * 60 * 24)); // 计算天数
					        var hours = Math.floor((diff % (1000 * 60 * 60 * 24)) / (1000 * 60 * 60)); // 计算小时数
					        var minutes = Math.floor((diff % (1000 * 60 * 60)) / (1000 * 60)); // 计算分钟数
					        var seconds = Math.floor((diff % (1000 * 60)) / 1000); // 计算秒数
					        // 将结果赋值给div的innerText属性
					        div.innerText = "本站已安全运行" + years + "年" + days + "天" + hours + "时" + minutes + "分" + seconds + "秒";
					    // 每秒更新一次运行时长
					    setInterval(getRunningTime, 1000);
					    // 初始显示一次
					    getRunningTime();
					    // 打字机
					    // 打印标题
					    new TypeIt(".guigui_biaoti", {
					            speed: 100,
					            waitUntilVisible: true
					        }).type("笒鬼鬼api")
					        // .pause(500) // 在两段文本之间暂停500毫秒。
					        // .type("欢迎来到我的api接口站!")
					        .go();
					    // 打印欢迎
					    new TypeIt(".guigui_text", {
					        loop: true,
					        cursorSpeed: 1000,
					        speed: 100
					    }).type("你好陌生人").pause(2000).delete(null, {
					        delay: 500
					    }).type("欢迎来到笒鬼鬼api!").pause(3000).go();
		</script>
	</body>
</html>
Error on the website
Ex.js:1333 version: 12
Ex.js:3847 before all_funcdisable
/?preview_theme_id=212:380
        GET https://www.justnainai.com/%E7%AC%92%E9%AC%BC%E9%AC%BCapi_files/qqskm.jpg 404 (Not Found)
/?preview_theme_id=212:387
        GET https://www.justnainai.com/%E7%AC%92%E9%AC%BC%E9%AC%BCapi_files/wxskm.jpg 404 (Not Found)
/?preview_theme_id=212:394
        GET https://www.justnainai.com/%E7%AC%92%E9%AC%BC%E9%AC%BCapi_files/zfbskm.jpg 404 (Not Found)
Ex.js:3850 undefined
Ex.js:3858 all_funcdisable
FingerPrint.js:19 has get the FIngerPrintSwitch
FingerPrint.js:20 false
/?preview_theme_id=212:437
i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js:1  Uncaught ReferenceError: require is not defined
    at i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js:1:1
(匿名) @ i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js:1
tags?v=43de2bf2704ed56ba600b37987a93e19:1  Uncaught ReferenceError: I18n is not defined
    at tags?v=43de2bf2704ed56ba600b37987a93e19:1:1
(匿名) @ tags?v=43de2bf2704ed56ba600b37987a93e19:1
deprecated.js:54  Deprecation notice: Using 'on' from 'discourse-common/utils/decorators' as a class property decorator is deprecated. You should import it from '@ember-decorators/object' instead. [deprecation id: discourse.utils-decorators-on]
deprecated @ deprecated.js:54
(匿名) @ decorators.js:85
(匿名) @ applyDecoratedDescriptor.js:12
_applyDecoratedDescriptor @ applyDecoratedDescriptor.js:11
18034 @ user-posts-stream.js:63
__webpack_require__ @ bootstrap:19
56215 @ user-stream.js:138
61372 @ badge.js:74
36633 @ topic-tracking-state.js:1149
46828 @ category-list.js:116
52623 @ session.js:12
78553 @ ajax-error.js:102
83765 @ group-history.js:10
32274 @ create-invite-bulk.js:3
34190 @ second-factor-edit.js:7
6475 @ post-user-tip-shim.js:8
(匿名) @ discourse.js:497
s.exports @ loader.js:106
requireModule @ loader.js:27
58048 @ post:2
16273 @ watched-words.js:11
43347 @ users.js:122
48948 @ topic.js:12
(匿名) @ discourse.js:28
(匿名) @ start-app.js:4
(匿名) @ discourse-boot.js:13
app.js:239 ℹ️ Discourse v3.3.0.beta3-dev — https://github.com/discourse/discourse/commits/625c715856 — Ember v5.5.0
runtime.js:3551 [Intervention]Images loaded lazily and replaced with placeholders. Load events are deferred. See https://go.microsoft.com/fwlink/?linkid=2048113
deprecated.js:54  [PLUGIN discourse-multilingual-7b09ee8f71769eae6d165b6e9ce8db2649342ec4557f214a04e0add4c7be6211] Deprecation notice: Importing getOwner from `discourse-common/lib/get-owner` is deprecated. See the alternatives on meta. [deprecated since Discourse 3.2] [deprecation id: discourse.get-owner-with-fallback] [info: https://meta.discourse.org/t/292080]
getOwner @ get-owner.js:23
r @ multilingual-route.js:19
c @ multilingual-route.js:33
d @ multilingual-route.js:38
e.removeParam @ multilingual-route.js:81
(匿名) @ multilingual-initializer.js:30
(匿名) @ plugin-api.js:126
(匿名) @ plugin-api.js:674
m @ index.js:200
trigger @ evented.js:27
(匿名) @ page-tracker.js:41
invoke @ backburner.js.js:282
flush @ backburner.js.js:197
flush @ backburner.js.js:358
_end @ backburner.js.js:798
end @ backburner.js.js:589
_runExpiredTimers @ backburner.js.js:905
setTimeout(异步)
setTimeout @ backburner.js.js:47
_installTimerTimeout @ backburner.js.js:948
_reinstallTimerTimeout @ backburner.js.js:932
_later @ backburner.js.js:865
throttle @ backburner.js.js:696
e.throttle @ index.js:273
_checkSize @ chat-drawer.js:142
_join @ backburner.js.js:824
join @ backburner.js.js:629
l @ index.js:81
(匿名) @ index.js:118
didInsertElement @ chat-drawer.js:61
r @ index.js:361
_trigger @ core_view.js:55
r @ index.js:361
_trigger @ ember-events.js:143
r @ index.js:361
didCreate @ index.js:2102
commit @ runtime.js:3965
commit @ runtime.js:4062
Nt @ runtime.js:4082
_renderRoots @ index.js:4916
_renderRootsTransaction @ index.js:4960
_renderRoot @ index.js:4905
_appendDefinition @ index.js:4830
appendOutletView @ index.js:4820
B._boundAutorunEnd @ backburner.js.js:523
Promise.then(异步)
n @ backburner.js.js:26
flush @ index.js:40
_scheduleAutorun @ backburner.js.js:964
_end @ backburner.js.js:804
Promise.then(异步)
flush @ index.js:40
Promise.then(异步)
flush @ index.js:40
Promise.then(异步)
flush @ index.js:40
Promise.then(异步)
flush @ index.js:40
Promise.then(异步)
flush @ index.js:40
Promise.then(异步)
flush @ index.js:40
Promise.then(异步)
flush @ index.js:40
_ensureInstance @ backburner.js.js:955
schedule @ backburner.js.js:648
e.schedule @ index.js:167
waitForDOMReady @ index.js:343
init @ index.js:251
b @ core.js:77
create @ core.js:401
