Issues with upload files with complex names in Safari
A user, peternlewis, reported issues with uploading files in Safari when the file names include quotes or non-ASCII characters. The file names get mangled, potentially causing security implications. justin confirmed the issue on Firefox and Safari, noting that Chrome handles quotes differently by replacing them with underscores.
gerhard identified the root cause: the send_file method in Rails not using the filename* parameter in the Content-Disposition header. This will be fixed in Rails 6. As a temporary solution, gerhard committed a fix to the tests-passed branch, which users can try by upgrading or switching to this branch. zogstrip and codinghorror recommended applying a monkey patch until the Rails 6 update.
There appears to be an issue with uploaded files in Safari when the file names include quotes (particularly bad) or non-ASCII characters. The file names in question are:
Create New "Open File" Macro and Copy Macro URL 1.1.kmmacros
Create New “Open File” Macro and Copy Macro URL 1.1.kmmacros
The first has regular double quotes and behaves very badly, the second has curly quotes and they get mangled.
See this forum topic:
In Chrome/Mac, both files download normally as:
Create New _Open File_ Macro and Copy Macro URL 1.1.kmmacros
The double quotes in the first file are replaced with underscores, but that is acceptable, presumably a deliberate choice somewhere.
However in Safari, the files downloads as:
Create New .dms
The first is particularly concerning, since the file name has been completely mangled, including the extension. There are potentially security implications with this as who knows how the quotes are being processed.
The second one appears to be a UTF conversion issue.
I suspect this is a regression, either in Discourse (my server is on 2.3.2) or in Safari, as I think we would have seen it earlier, but I could not find any specific older cases where the macros clearly had quotes in their names to check. There are definitely older files that have non-ASCII characters (eg here), and I have never noticed them to not work before.
It is particularly strange that it works in Chrome and not in Safari, so presumably it is some sort of client-side code issue.
I can repro this locally on latest uploading and downloading a file via Firefox. Safari also truncates the download name at the quotes. Chrome must handle quotes in file names differently by replacing them with underscores.
@gerhard can you have a look?
send_file from Rails currently doesn’t use the filename* parameter in the Content-Disposition header. That’s why those filenames are mangled in most browsers.
Rails 6 will fix it: Encode Content-Disposition filenames on send_data and send_file · rails/rails@890485c · GitHub
Should I apply a monkey patch for now? And it looks like the S3 store should set the filename* as well.
Probably, not sure when we’ll get to Rails 6?
Yes please. Looks like this code is already 1 year old so it should be pretty safe (make sure you look for bugfixes though)
I just commited a fix. You can give it a try by upgrading / switching to the tests-passed branch.
https://github.com/discourse/discourse/commit/24877a7b8c3aa445f0969b298ba8a34ac57c7bd6
