Het zou nuttig zijn om de Aan: gebruikersnaam (in PM's) te kunnen gebruiken voor Templates
The discussion revolves around the need for a pre-filled variable in Discourse Templates to address the recipient of a personal message (PM). nathank highlights that existing variables (my_username, original_poster_username, reply_to_username, etc.) do not work for this purpose. TheDarkWizard and michellefs express interest in having a variable that inserts the name of a PM recipient, with michellefs suggesting %{target_username} as a possible variable. However, JammyDodger confirms that such a variable does not currently exist in the plugin, but acknowledges its potential usefulness.
Continuing the discussion from Discourse Templates:
Unfortunately this doesn’t work for my main use-case for actually using Templates!
I want to be able to address the user I’m targeting in a new personal message, usually in relation to a post that they have made. This is in order to educate them or nudge them to better behaviour.
However, none of those variables work for this.
  • my_username
    • gives me
  • original_poster_username
    • gives me
  • reply_to_username
    • returns nothing
  • last_poster_username
    • also nothing
  • reply_to_or_last_poster_username
    • nothing
Could we please have one for a PM addressee somehow? I’ve got no idea how to do that. It would be fine if it only worked for a PM with a single participant (apart from yours truly).
Would it be possible to have use a variable that inserts the name of a PM recipient?
Would %{target_username} be the appropriate variable?
I’d also love it if this were a possibility :raised_hands:t4: as we’re most likely to use templates to start a PM thread than as a public reply. For example, when we award custom badges.
Is that a variable that exists in the plug-in or were you making a suggestion as to how it could look like?
No, that one doesn’t have a variable at the moment, though it would be very useful.
I’ve split this into a Contribute > Feature topic for consideration. I actually spotted that there was an existing topic, so have moved it over here to group the requests together. :+1: :slight_smile:
