Into Topic, when inbound link added then It will generate “ItemList” schema structured data. There is error found in URL schema tag.
Please check below image for reference.
The errors I’m seeing when I enter https://meta.discourse.org/t/developer-s-guide-to-discourse-themes/93648 into https://search.google.com/test/rich-results are Two or more mutually-exclusive properties used in a single structured data item and Missing field "url".
Thank you for your reply.
Can you confirm that this is bug or not? or is there any solution for remove that error?
Sorry for the late reply to this. I’m not sure if it qualifies as a bug, but it affects a lot of topics on Meta, including the topic that defines what a bug is: About the bug category.
We’ll get this fixed.
https://github.com/discourse/discourse/commit/ea423b471a03fcbee6c4d105ed0eb7b615684057
This is now fixed in the above commit. @PoojaPatel check the page again after upgrade using the Google’s new test tool which Simon mentioned above.
