After upgrading to latest discourse this morning, I see the following error in the JS console and my forum does not load:
Uncaught SyntaxError: missing ) after argument list
Here’s a screenshot of the issue, you can see it live on http://discourse.kohanaframework.org
fefrei
(Felix Freiberger)
Are you running any non-standard plugins?
Are you behind Cloudflare?
1 个赞
Yes, we use CloudFlare. I’ve turned off “JS minification” and that seems to have made the problem go away.
Does Discourse not test against minified files?!
Falco
(Falco)
4
The purpose of a minify is to NOT alter program behavior, while decreasing size.
Discourse already minifies the assets. Cloudfare have a broken minifier.
4 个赞
I think you meant to say:
Does Cloudflare not test their minifier?!
When functioning code is broken by a third party, that is not the code’s fault.
2 个赞
sam
(Sam Saffron)
6
Can you please raise this with cloudflare and post your issue number here?
1 个赞
Sam, I’ve raised the issue to CF, my issue number is #1067945
3 个赞
Good news! After some public shaming on my part, this is now fixed on Cloudflare’s side for everyone, worldwide.
I’m deleting all the other topics on this as ancient history.
3 个赞
此主题已在 2902 天后自动关闭。不再允许回复。
