Gebrek aan paginering op groep admin pagina
The discussion revolves around the lack of pagination on the group admin page. reza_safaei initially raises the concern, citing a potential problem with loading the page if a large number of groups (1 million) are created. awesomerobot questions the feasibility of such a large number of groups, prompting reza_safaei to explain that the goal is to create a group for each tutorial, with 10,000 tutorials currently available.
nathank suggests an alternative solution, recommending that users ‘Watch’ specific topics instead of creating separate groups. He proposes a bespoke plugin or theme component to simplify this workflow.
Falco points out that the group page (/g) is already paginated, with 35 groups per page and infinite scrolling. He also suggests using the search function to quickly find a group, and requests API response times for the page and endpoints with a large number of groups.
Hello, why can’t the groups be paged? If I want to create 1 million groups. There is a problem loading the page
Is 1 million an exaggeration? I suspect you’d run into other issues as well with that number of groups. Can you describe the use-case a little more and perhaps the actual number of groups you’re looking to support?
The goal is to create a group for each tutorial. To solve problems, we currently have 10,000 tutorials on different topics, now we want to have a troubleshooting group for each tutorial.
If you simply get the relevant users to ‘Watch’ the topics that they should be troubleshooting you could achieve that without the impossible-to-manage group overhead.
To make that workflow easy, you might need a bespoke plugin / theme component though. But it would be a simple one. Sample spec:
  1. Specified group (staff by default) have an extra option Force (or similar) on Watching menus
  2. Force opens a modal asking for group / users and the level of watching desired
  3. This is then applied on confirmation
  4. A useful extension would be to:
    • display on the modal which people/groups have been forced to watch (and what level) that topic / category / etc in the past
Can you share API response times of the page and endpoints with the 1M groups?
The page at /g is already paged at 35 groups per page, and uses infinite scrolling to request new pages.
To quickly find a group use the search in that page.
