Problema di rilevamento della lingua [valore %{language} mancante]
Hi team:
Thanks for the great plugin which helps me a lot.
Recently I found there’s an issue about the language detect, the new posts always couldn’t be detected the original language.
Message
RuntimeError (The translator is unable to translate this language.) /var/www/discourse/plugins/discourse-translator/services/discourse_translator/google.rb:70:in `translate’
Backtrace
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/google.rb:70:in translate' /var/www/discourse/plugins/discourse-translator/plugin.rb:40:in translate’
Env
hostname flutter101-app
process_id 180
application_version 9a3dd6b59af0a5fc22045f376b421cb4fd074aad
Is there anyone who faced the same situation?
Thanks!
Is this 100% reproducible?
Can you paste the problem text here?
thanks to Sam, for your quick reply, yes, 100% reproducible, the Chinese text is:
还真是,新发布的帖子调用 MS 翻译都是报错,老的就没问题,为何内。
I have recorded a screen for this, you may see from that the new text had this issue, but the former post is OK.
I am using the MS translate.
Please check it out here, thanks!
I have tried rebuild app, not working :pleading_face:
Today I’ve upgraded to the lastest version and stil not work, FYI, thanks :sweat_smile:
@Luke_Cheng Puoi provare ad aggiornare all’ultima versione? @pmusaraj potrebbe aver risolto il problema in
poiché non riesco a riprodurre l’errore.
Ottimo, grazie a @tgxworld e @pmusaraj!
