העדכון של ה-Launcher נכשל
The command that worked last time (Launcher rebuild app fails with "containers/app.yml does not exist" - #6 by pfaffman) is failing.
root@sfofood:/var/discourse# ./launcher bootstrap web_only && ./launcher destroy web_only && ./launcher start web_only
WARNING: Docker version 24.0.2 deprecated, recommend upgrade to 24.0.7 or newer.
x86_64 arch detected.
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
2.0.20250129-0720: Pulling from discourse/base
af302e5c37e9: Pull complete
ed49ab5c933d: Pull complete
7cb9e730d898: Pull complete
7c28a6b187b2: Pull complete
23222af7238f: Pull complete
59b87d9ed5c1: Pull complete
90d60b432298: Pull complete
d3b3135aa82b: Pull complete
94e7b594395d: Pull complete
cf15e2c89d00: Pull complete
2c0cccf9ec27: Pull complete
5d8ea2a8d564: Pull complete
020f04b42275: Pull complete
06e22604f387: Pull complete
8b0ecc579aad: Pull complete
4d577f7424c0: Pull complete
37ef4781925f: Pull complete
30d67d1af761: Pull complete
43eaf8c26af4: Pull complete
02f4cc50eabd: Pull complete
93896ee36e56: Pull complete
fadd5d615e0e: Pull complete
85f9459cb30e: Pull complete
eaddca2afacb: Pull complete
f54443d29a2d: Pull complete
ed6f0f133683: Pull complete
3d1894dc563f: Pull complete
51ca3f63c909: Pull complete
b87374db2274: Extracting [==================================================>]    197MB/197MB
failed to register layer: write /home/discourse/.local/share/pnpm/store/v3/files/46/bbd1f17921afe276ca9dee7b0df4d529a15741023c9e2ce4875e4899313fd36a6041c49c48d6f5fdd219e9be8c300acfcdbb247f53adf433ba7a88d51cebc4: no space left on device
Unable to find image 'discourse/base:2.0.20250129-0720' locally
docker: failed to register layer: write /home/discourse/.local/share/pnpm/store/v3/files/46/b64c3cb1134c3ca2a060955039748296d7f0b1671e06986feab0a1ec374939a4ade2cf740fb14fa9d9916c4194860e3bb237a417483856625c742874a1a7bd: no space left on device.
See 'docker run --help'.
Your Docker installation is not working correctly
See: https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=sam
Here’s your problem
And you’ll also need to rebuild your data container sometime as described in PostgreSQL 15 update
2 לייקים
I need to resize the droplet to a larger disk?
נראה שזה עבד.
לייק 1
@pfaffman are there PostgreSQL 15 update instructions for two-container instances? That link seems to be for single container.
Try scolling.
