Layout issue of top header on DiscouseHub
Really new issue:
I can’t search or see what kind of funny I have waiting for, because DiscourseHub just closes connection.
I don’t know if this happends only on iPad or are every bigger screens affected — propably it is just iPad, because no one else isn’t complaining (or… DiscourseHub has very low market share).
And yes, Safari is just fine.
I’m having it too on an iPad as well (this is mobile layout!)
(However, it’s only applying to this site. When I go into any other site, the app behaves perfectly fine and does not morph the navigation into the top bar.)
Have those sites updated to 3.3.0 yet?
I don’t know about those others but what is your best bet how things are here :wink:
Mine is 3.3.0-beta1-dev and it works just fine. So did earlier 3.2-serie. This layout issue here came out really fast after recent new version announcement.
What ever, but DiacourseHub is broken with fresh Discourse, before it was not. That is all what I know.
Edit.
I upgraded mine to 969ab0fd6e and same happened.
I pushed a fix that should improve the situation. FIX: better supports ipad and hub footer nav by jjaffeux · Pull Request #25518 · discourse/discourse · GitHub
Sorry, my bad, let me know if you see anything else wrong, thanks for report :+1:
Thanks! It works again as my muscle memory wants :joy:
Thank you, but still I see a problem on an iPad:
The header is only visible when at the top of the page.
Mine works.
But:
Header of topics is peaking little. It doesn’t bother me a bit, but is different than before.
Strange. That happends only here. Mine works beautifully. Only bigger difference I see (not a clue what happens under the hood) is I’m using category navbar.
This topic was automatically closed after 24 hours. New replies are no longer allowed.
