Hi, I’m wondering how to add such things in as the right banner.
A calendar, better to have Schedule Function.
An Editable Advertisement Place for showing the sponsor’s logos.
Can that be done?
Can that be done?
Did someone make a list with widgets(plugins) created for this awesome plugin?
all widgets in the layout has disappeared after a recent update … (one of them was the profile widget e.g.).
error in the console:
Uncaught TypeError: Cannot read property 'inlineBetween' of undefined
some errors in the admin error logs:
TypeError (no implicit conversion of nil into String) /var/www/discourse/vendor/bundle/ruby/2.4.0/gems/actionpack-4.2.8/lib/action_controller/metal/data_streaming.rb:68:in `file?'
@angus
Hi Angus, may you confirm if this is related to layout plugin or the widgets?
This property does not appear anywhere in my code. Please attach the full error log so I can confirm.
I’m not seeing any errors using the layouts plugin with the latest version of Discourse.
the problems were from another plugin Angus. I’ll disable the plugin to see if the widgets come back or not. and update here.
update:
@angus after removal of mathjax, layout and widgets are working fine.
the profile widget is not working for the not-logged in users (logged in users are fine), after the common-mark updates; with this error in the browser console:
Error: Could not find module pretty-text/engines/discourse-markdown/helpers
at s (_ember_jquery-a8dcbd3….js:59258)
at require (_ember_jquery-a8dcbd3….js:59273)
at h (pretty-text-bundle-1122bc3….js:sourcemap:1)
at r (pretty-text-bundle-1122bc3….js:sourcemap:1)
at a (application-6ed9515….js:sourcemap:1)
at r (application-6ed9515….js:sourcemap:1)
at t.html (plugin-third-party-3bbfdf2….js:sourcemap:1)
at t.p [as draw] (application-6ed9515….js:sourcemap:48)
at t.value (application-6ed9515….js:sourcemap:48)
at r (_vendor-ee405da….js:7919)
u @ _ember_jquery-a8dcbd3….js:28913
I have solved this problem by using TextLib.cookAsync
You could see fixed profile widget here
My plan is to totally deprecate cook from the library, we simply can not safely use it anymore. cookAsync is the only method allowed.
Note to users of this plugin (@Pad_Pors) . I’ve changed the way widgets are enabled and positioned. Rather than listing widgets in settings, you now select the position and whether the widget is pinned in a separate admin panel.
Instead of monkey patching the SiteSetting model, i.e.
SiteSetting.class_eval do
@choices[:layouts_sidebar_left_widgets].push('profile')
You now add widgets in your plugin.rb
like so:
DiscourseLayouts::WidgetHelper.add_widget('election-list')
This will make them appear on the list of widgets in the new admin panel.
Hey Angus. Do you have this working on the current version? My app wont launch with this right now.
Also I couldnt see the other one but the profile widget also isnt working on it.
Yup, it works fine with the latest version. Can you find any relevant logs?
I don’t actually use the profile widget. I’ll take a look. Have you enabled it as described above?
Ok, I’ve updated the profile widget to use the new way of adding widgets.
0: pry (0.10.4) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/pry-0.10.4.gemspec
Using unicorn 5.3.0
0: unicorn (5.3.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/unicorn-5.3.0.gemspec
Using rbtrace 0.4.8
0: rbtrace (0.4.8) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rbtrace-0.4.8.gemspec
Using rspec-core 3.6.0
0: rspec-core (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rspec-core-3.6.0.gemspec
Using rspec-expectations 3.6.0
0: rspec-expectations (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rspec-expectations-3.6.0.gemspec
Using rspec-mocks 3.6.0
0: rspec-mocks (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rspec-mocks-3.6.0.gemspec
Using sassc 1.11.2
0: sassc (1.11.2) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/sassc-1.11.2.gemspec
Using unf 0.1.4
0: unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/unf-0.1.4.gemspec
Using fast_xor 1.1.3
0: fast_xor (1.1.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/fast_xor-1.1.3.gemspec
Fetching activesupport 4.2.9
Installing activesupport 4.2.9
0: activesupport (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/activesupport-4.2.9.gemspec
Using loofah 2.0.3
0: loofah (2.0.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/loofah-2.0.3.gemspec
Using nokogumbo 1.4.13
0: nokogumbo (1.4.13) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/nokogumbo-1.4.13.gemspec
Using ruby-readability 0.7.0
0: ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/ruby-readability-0.7.0.gemspec
Using sidekiq 5.0.3
0: sidekiq (5.0.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/sidekiq-5.0.3.gemspec
Using mail 2.6.6
0: mail (2.6.6) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/mail-2.6.6.gemspec
Using oga 2.10
0: oga (2.10) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/oga-2.10.gemspec
Using aws-sdk-resources 2.5.3
0: aws-sdk-resources (2.5.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/aws-sdk-resources-2.5.3.gemspec
Using ember-handlebars-template 0.7.5
0: ember-handlebars-template (0.7.5) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/ember-handlebars-template-0.7.5.gemspec
Using webmock 3.0.1
0: webmock (3.0.1) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/webmock-3.0.1.gemspec
Using oauth2 1.3.1
0: oauth2 (1.3.1) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/oauth2-1.3.1.gemspec
Using listen 3.1.5
0: listen (3.1.5) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/listen-3.1.5.gemspec
Using omniauth-oauth 1.1.0
0: omniauth-oauth (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-oauth-1.1.0.gemspec
Using omniauth-openid 1.0.1
0: omniauth-openid (1.0.1) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-openid-1.0.1.gemspec
Using pry-nav 0.2.4
0: pry-nav (0.2.4) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/pry-nav-0.2.4.gemspec
Using pry-rails 0.3.4
0: pry-rails (0.3.4) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/pry-rails-0.3.4.gemspec
Using rspec 3.6.0
0: rspec (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rspec-3.6.0.gemspec
Using rails-deprecated_sanitizer 1.0.3
0: rails-deprecated_sanitizer (1.0.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rails-deprecated_sanitizer-1.0.3.gemspec
Using globalid 0.4.0
0: globalid (0.4.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/globalid-0.4.0.gemspec
Fetching activemodel 4.2.9
Installing activemodel 4.2.9
0: activemodel (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/activemodel-4.2.9.gemspec
Using shoulda-matchers 2.8.0
0: shoulda-matchers (2.8.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/shoulda-matchers-2.8.0.gemspec
Using rails-html-sanitizer 1.0.3
0: rails-html-sanitizer (1.0.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rails-html-sanitizer-1.0.3.gemspec
Using sanitize 4.5.0
0: sanitize (4.5.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/sanitize-4.5.0.gemspec
Using aws-sdk 2.5.3
0: aws-sdk (2.5.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/aws-sdk-2.5.3.gemspec
Using omniauth-oauth2 1.4.0
0: omniauth-oauth2 (1.4.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-oauth2-1.4.0.gemspec
Using omniauth-twitter 1.3.0
0: omniauth-twitter (1.3.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-twitter-1.3.0.gemspec
Using rspec-html-matchers 0.9.1
0: rspec-html-matchers (0.9.1) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rspec-html-matchers-0.9.1.gemspec
Using rails-dom-testing 1.0.8
0: rails-dom-testing (1.0.8) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rails-dom-testing-1.0.8.gemspec
Fetching activejob 4.2.9
Installing activejob 4.2.9
0: activejob (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/activejob-4.2.9.gemspec
Using active_model_serializers 0.8.3
0: active_model_serializers (0.8.3) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/active_model_serializers-0.8.3.gemspec
Fetching activerecord 4.2.9
Installing activerecord 4.2.9
0: activerecord (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/activerecord-4.2.9.gemspec
Using shoulda 3.5.0
0: shoulda (3.5.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/shoulda-3.5.0.gemspec
Fetching onebox 1.8.17
Installing onebox 1.8.17
0: onebox (1.8.17) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/onebox-1.8.17.gemspec
Using omniauth-facebook 4.0.0
0: omniauth-facebook (4.0.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-facebook-4.0.0.gemspec
Fetching omniauth-github 1.3.0
Installing omniauth-github 1.3.0
0: omniauth-github (1.3.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-github-1.3.0.gemspec
Using omniauth-google-oauth2 0.3.1
0: omniauth-google-oauth2 (0.3.1) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-google-oauth2-0.3.1.gemspec
Using omniauth-instagram 1.0.2
0: omniauth-instagram (1.0.2) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/omniauth-instagram-1.0.2.gemspec
Fetching actionview 4.2.9
Installing actionview 4.2.9
0: actionview (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/actionview-4.2.9.gemspec
Using seed-fu 2.3.6
0: seed-fu (2.3.6) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/seed-fu-2.3.6.gemspec
Using test_after_commit 1.1.0
0: test_after_commit (1.1.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/test_after_commit-1.1.0.gemspec
Fetching actionpack 4.2.9
Installing actionpack 4.2.9
0: actionpack (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/actionpack-4.2.9.gemspec
Fetching actionmailer 4.2.9
Installing actionmailer 4.2.9
0: actionmailer (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/actionmailer-4.2.9.gemspec
Fetching railties 4.2.9
Installing railties 4.2.9
0: railties (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/railties-4.2.9.gemspec
Using sprockets-rails 3.2.0
0: sprockets-rails (3.2.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/sprockets-rails-3.2.0.gemspec
Using discourse-qunit-rails 0.0.9
0: discourse-qunit-rails (0.0.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/discourse-qunit-rails-0.0.9.gemspec
Using jquery-rails 4.3.1
0: jquery-rails (4.3.1) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/jquery-rails-4.3.1.gemspec
Using rspec-rails 3.6.0
0: rspec-rails (3.6.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rspec-rails-3.6.0.gemspec
Fetching rails 4.2.9
Installing rails 4.2.9
0: rails (4.2.9) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rails-4.2.9.gemspec
Using ember-rails 0.18.5
0: ember-rails (0.18.5) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/ember-rails-0.18.5.gemspec
Using rails_multisite 1.0.6
0: rails_multisite (1.0.6) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/rails_multisite-1.0.6.gemspec
Using spork-rails 4.0.0
0: spork-rails (4.0.0) from /var/www/discourse/vendor/bundle/ruby/2.3.0/specifications/spork-rails-4.0.0.gemspec
Bundle complete! 96 Gemfile dependencies, 173 gems now installed.
Gems in the group development were not installed.
Bundled gems are installed into ./vendor/bundle.
I, [2017-08-09T07:46:56.949898 #15] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
NoMethodError: undefined method `[]' for nil:NilClass
/var/www/discourse/plugins/dl-custom-content/plugin.rb:9:in `block (2 levels) in activate!'
/var/www/discourse/plugins/dl-custom-content/plugin.rb:8:in `class_eval'
/var/www/discourse/plugins/dl-custom-content/plugin.rb:8:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:208:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:206:in `each'
/var/www/discourse/lib/plugin/instance.rb:206:in `notify_after_initialize'
/var/www/discourse/config/application.rb:209:in `block (2 levels) in <class:Application>'
/var/www/discourse/config/application.rb:209:in `each'
/var/www/discourse/config/application.rb:209:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/lazy_load_hooks.rb:36:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/lazy_load_hooks.rb:45:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/lazy_load_hooks.rb:44:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/lazy_load_hooks.rb:44:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/application/finisher.rb:62:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/initializable.rb:30:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/initializable.rb:30:in `run'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/initializable.rb:55:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/initializable.rb:54:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/application.rb:352:in `initialize!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/config/environment.rb:5:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:274:in `require'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:274:in `block in require'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:240:in `load_dependency'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/application.rb:328:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/application.rb:457:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rake-12.0.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:22:in `load'
/usr/local/bin/bundle:22:in `<main>'
Tasks: TOP => db:migrate => environment
I, [2017-08-09T07:47:03.176969 #15] INFO -- :
I, [2017-08-09T07:47:03.177937 #15] INFO -- : Terminating async processes
I, [2017-08-09T07:47:03.178041 #15] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 44
I, [2017-08-09T07:47:03.178422 #15] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 157
2017-08-09 07:47:03.178 UTC [44] LOG: received fast shutdown request
2017-08-09 07:47:03.178 UTC [44] LOG: aborting any active transactions
157:signal-handler (1502264823) 2017-08-09 07:47:03.179 UTC [51] LOG: autovacuum launcher shutting down
Received SIGTERM scheduling shutdown...
2017-08-09 07:47:03.185 UTC [48] LOG: shutting down
157:M 09 Aug 07:47:03.238 # User requested shutdown...
157:M 09 Aug 07:47:03.238 * Saving the final RDB snapshot before exiting.
2017-08-09 07:47:03.261 UTC [48] LOG: database system is shut down
157:M 09 Aug 07:47:03.328 * DB saved on disk
157:M 09 Aug 07:47:03.328 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 464 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
5e2f206b07fc093adb6a40ae8494c03ec58e0c19cc9a08484356663165da3c64
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
root@server70:/var/discourse#
This is what I get. The profile widget was ok on here but even in layouts i have it saved but its not showing up on my front page.
Edit the profile widget is showing now after I rebuilt the app.
It looks like the error is coming from the dl-custom-content
plugin / widget, not the layouts plugin.
Remove that widget and try again.
Ok. Guess that’s the one I need to work. Do you have that one working yet?
I didn’t build that one.
Here’s how you can fix it if you want to use it:
Fork the dl-custom-content
repo.
Change these lines
@choices[:layouts_sidebar_right_widgets].push('dl-custom-content')
@choices[:layouts_sidebar_left_widgets].push('dl-custom-content')
to
DiscourseLayouts::WidgetHelper.add_widget('dl-custom-content')
Change the plugin url in your app.yml
to your fork.
Ah ok. Thanks Angus!
No luck. Made the changes and it still failed when ./launcher rebuild app
Never. Just removed it and made my css changes back to how it was prior. My site was live and couldn’t have it down any longer needed.
