I made a separate repository and made the changes proposed here.
but it seems that the plugin has caused the rebuild process to crash (when I remove it the rebuild is going ok).
I think it should be more:
contents.push(
this.attach('button', {
action: 'toggleBookmark',
title: tooltip,
label: label,
icon: 'bookmark',
className: buttonClass
contents.push(
new ComponentConnector(this,'topic-notifications-button', {
topic,
appendReason: true,
showFullTitle: false
than
contents.push(
title: tooltip,
label: label,
icon: 'bookmark',
topic: topic,
appendReason: true,
tried it but still get errors with the rebuild.
It seems to work for Angus as well, as he shows in his snapshot. but as soon as I add the repository, the rebuild fails
Iâll double check the codes with the proposed changes and test again.
Iâm almost certain this is failing because your plugin is named âbuttons-widgetâ and you are using DiscourseLayouts from plugin.rb of your plugin, which will cause a constant loading error.
ATM plugins are loaded in the alphabetical order of the folder name: https://github.com/discourse/discourse/blob/master/lib/plugin/instance.rb#L48
Iâll rename it the same as the one Angus has done (profile-widget!), as itâs the best description for the widget!
Many thanks
The problem was the naming, or as said alphabetic orders.
just a double check: the topic-timeline has disappeared from the topic page. is it a change in the layout plugin or should I look for the reason somewhere else?
we only have the left sidebar activated and there is space for the timeline.
Hi @angus
Thanks for the last update, and please take a look at the following issue
https://github.com/angusmcleod/discourse-layouts/issues/3
Fixed
https://github.com/angusmcleod/discourse-layouts/commit/dc24d1cfe04c6e60dab7bc30052801e0ace0ab9a
Is the topic-timeline removed from the topic page in the layout plugin?
@angus
Yes, this broke after the cleanup. Fixed. Thanks.
https://github.com/angusmcleod/discourse-layouts/commit/ec07ba181100843b67c2ff341b10049e4e31bd09
@angus
? Canât find it.
weâd previously developed something similar. itâs here:
https://github.com/Alavi1412/widget-bookmark
but itâs slight issues (itâs not shown as a selection in the layout admin page), and the developer is not around.
a bookmark filter (which exists in the discourse-app) would do the same job.
@exetico Yes that widget has taken various forms. Iâve cleaned it up and made it available again as layouts-topic-list.
https://github.com/angusmcleod/layouts-topic-list
You can list bookmarks and / or suggested topics (when viewing a topic). Both lists can be toggled with settings.
You can see it in action in the layouts category in my sandbox.
that layouts category link doesnât work.
My site is rebuilding. Iâm testing a sysadmin issue. Give it 30 minutes.
Thanks. Fast response as always!
Have you an overview with all known widgets/layouts (other than the ones, made by you)?
It could also definatly be a good idéa to make a new template for layouts, other people could jump on (Remember comments
) - and also recommend to put something like âdiscourse-layoutsâ as topic in their Gitâs.
Update:
I think a lot of people will appreciate an example where custom_fields for plugins is included, too (user-editable options) [1] [2].
Update2:
Just a tip - I think you need to update the code behind the Twitter-solution. The widget showing up one more time, after each page-visit (without reload). I had the same issue with $( document ).ready(function() {}); after you improved how the scripts is handled. Iâm not using the Twitter-widget feature at the moment.
Update3:
If you prefer to have the a-link in the Bookmarks-title, it would be nice if there was a call to the users bookmarks as well
Map navigation widget link is broken in original post.
I can no longer edit the original post. The map navigation widget is here if youâre interested:
