Let'sEncrypt DNS 验证模板使用 Cloudflare
大家好
我需要使用 DNS 方法来验证我的 SSL 证书所有权,以便使用 Let’s Encrypt。
我复制了 /var/discourse/templates/ 目录下的现有 web.letsencrypt.ssl.template.yml 文件,并对其进行了修改,以使用自动 DNS API 集成方法。下面是我的模板示例,如果您有任何改进建议,我将不胜感激。
我将此文件命名为 web.letsencrypt.ssl.dns.template.yml
env:
  LETSENCRYPT_DIR: "/shared/letsencrypt"
  DISCOURSE_FORCE_HTTPS: true
hooks:
  after_ssl:
    - exec:
       cmd:
         - if [ -z "$LETSENCRYPT_ACCOUNT_EMAIL" ]; then echo "LETSENCRYPT_ACCOUNT_EMAIL 环境变量是必需的,但未设置。"; exit 1; fi
         - /bin/bash -c "if [[ ! \"$LETSENCRYPT_ACCOUNT_EMAIL\" =~ ([^@]+)@([^\\.]+) ]]; then echo \"LETSENCRYPT_ACCOUNT_EMAIL 不是一个有效的电子邮件地址\"; exit 1; fi"
    - exec:
       cmd:
         - cd /root && git clone --branch 3.0.7 --depth 1 https://github.com/acmesh-official/acme.sh.git && cd /root/acme.sh
         - touch /var/spool/cron/crontabs/root
         - install -d -m 0755 -g root -o root $LETSENCRYPT_DIR
         - cd /root/acme.sh && LE_WORKING_DIR="${LETSENCRYPT_DIR}" ./acme.sh --install --log "${LETSENCRYPT_DIR}/acme.sh.log"
         - cd /root/acme.sh && LE_WORKING_DIR="${LETSENCRYPT_DIR}" ./acme.sh --upgrade --auto-upgrade
         - cd /root/acme.sh && LE_WORKING_DIR="${LETSENCRYPT_DIR}" ./acme.sh --set-default-ca  --server  letsencrypt
    - file:
       path: /etc/runit/1.d/letsencrypt
       chmod: "+x"
       contents: |
        #!/bin/bash
        issue_cert() {
          export CF_Token="$ENV_LETSENCRYPT_CF_TOKEN"
          export CF_Account_ID="$ENV_LETSENCRYPT_CF_ACCOUNT_ID"
          export CF_Zone_ID="$ENV_LETSENCRYPT_CF_ZONE_ID"
          LE_WORKING_DIR="${LETSENCRYPT_DIR}" $ENV_LETSENCRYPT_DIR/acme.sh --issue --dns $ENV_LETSENCRYPT_DNS_PROVIDER $2 -d $ENV_DISCOURSE_HOSTNAME --keylength $1 -w /var/www/discourse/public
        cert_exists() {
          [[ "$(cd ${LETSENCRYPT_DIR}/$ENV_DISCOURSE_HOSTNAME$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")"]]
        # RSA 证书
        issue_cert "4096"
        if ! cert_exists ""; then
          # 如果出现问题,尝试再次签发证书
          issue_cert "4096" "--force"
        fi
        LE_WORKING_DIR="${LETSENCRYPT_DIR}" $ENV_LETSENCRYPT_DIR/acme.sh \
          --installcert \
          -d $ENV_DISCOURSE_HOSTNAME \
          --fullchainpath /shared/ssl/$ENV_DISCOURSE_HOSTNAME.cer \
          --keypath /shared/ssl/$ENV_DISCOURSE_HOSTNAME.key \
          --reloadcmd "sv reload nginx"
        # ECDSA 证书
        issue_cert "ec-256"
        if ! cert_exists "_ecc"; then
          # 如果出现问题,尝试再次签发证书
          issue_cert "ec-256" "--force"
        fi
          --installcert --ecc \
          --fullchainpath /shared/ssl/$ENV_DISCOURSE_HOSTNAME_ecc.cer \
          --keypath /shared/ssl/$ENV_DISCOURSE_HOSTNAME_ecc.key \
        if cert_exists "" || cert_exists "_ecc"; then
          grep -q 'force_https' "/var/www/discourse/config/discourse.conf" || echo "force_https = 'true'" >> "/var/www/discourse/config/discourse.conf"
        fi
    - replace:
       filename: "/etc/nginx/conf.d/discourse.conf"
       to: |
         ssl_certificate /shared/ssl/$ENV_DISCOURSE_HOSTNAME.cer;
         ssl_certificate /shared/ssl/$ENV_DISCOURSE_HOSTNAME_ecc.cer;
    - replace:
       filename: /shared/letsencrypt/account.conf
       to: |
         ACCOUNT_EMAIL=$ENV_LETSENCRYPT_ACCOUNT_EMAIL
    - replace:
       to: |
         ssl_certificate_key /shared/ssl/$ENV_DISCOURSE_HOSTNAME.key;
         ssl_certificate_key /shared/ssl/$ENV_DISCOURSE_HOSTNAME_ecc.key;
    - replace:
       to: |
         add_header Strict-Transport-Security 'max-age=63072000';
您需要将一些额外的环境变量添加到 app.yml 中,如果您不使用 Cloudflare 作为 DNS 提供商,可能还需要进行修改。所有不同的提供商 API 设置都在这里。
这是我添加到 app.yml 中 templates 部分的内容:
templates:
  ## 取消注释下一行以启用 IPv6 监听器
  #- "templates/web.ipv6.template.yml"
  ## 如果您想添加 Let's Encrypt (https),请取消注释这两行
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.dns.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
然后在 env 部分的更下方:
## 如果您添加了 Let's Encrypt 模板,请取消注释下方内容以获取免费 SSL 证书
  LETSENCRYPT_ACCOUNT_EMAIL: me@mydomain.com
  LETSENCRYPT_CF_TOKEN: "YOUR_TOKEN"
  LETSENCRYPT_CF_ACCOUNT_ID: "YOUR_ACCOUNT_ID"
  LETSENCRYPT_CF_ZONE_ID: "YOUR_ZONE_ID"
  LETSENCRYPT_DNS_PROVIDER: "YOUR_DNS_PROVIDER" ## 例如:dns_cf
更新这些文件后,我只需运行命令来重建 docker 应用:
cd /var/discourse
./launcher rebuild app
重建完成后,您的应用应该可以通过 https:// 运行,并且应该有一个每天检查证书是否需要更新的 cron 作业。如果需要更新,它将自动为您获取新证书并进行安装。
希望这对大家有帮助。
编辑: 我刚刚达到了 letsencrypt 每周 5 个证书(每个确切域名)的限制。
您在生成 _ecc 证书时遇到问题了吗?
根据您的帖子,主要的 website.com.cer 文件已成功生成,但 website.com_ecc.cer 显示为 0 字节(_ecc.key 没问题)。
但是,两个证书都是由同一个 issue_cert 方法颁发的,所以出于某种原因,主证书有效而 _ecc 证书失败。
从 Web 服务器模式切换到 DNS 验证的方式,目前对于 Let’s Encrypt 仍然有效吗?
Hi @LotusJeff,
是的,DNS 验证仍然可用,但请不要再使用我第一篇文章中的模板。它与当前的 discourse_docker 已经不同步:
  • 其中的 cert_exists 检查在当前 Let’s Encrypt 证书链下会失败,导致每次容器启动时都会强制生成新证书,可能会触发重复证书的频率限制。
  • 其中的 nginx replace 步骤针对的行已经移动,而 add_header 步骤现在会覆盖一个无关的 ETag 标头。
你现在不再需要自定义模板。保留官方的 Let’s Encrypt 模板,并在 app.yml 中将其切换为 DNS 验证:
templates:
env:
  CF_Token: "YOUR_TOKEN"        # 具有此区域 Zone > DNS > Edit 权限的 Cloudflare API 令牌
  CF_Zone_ID: "YOUR_ZONE_ID"
run:
  - exec:
      cmd:
        - mkdir -p /opt/dnsapi
        - curl -fsSL https://raw.githubusercontent.com/acmesh-official/acme.sh/3.0.6/dnsapi/dns_cf.sh -o /opt/dnsapi/dns_cf.sh
  - replace:
      filename: /usr/local/bin/letsencrypt
      to: "--dns dns_cf"
此配置的作用:
  • 官方模板仅下载主要的 acme.sh 脚本,不包含 DNS 插件。exec 步骤添加了 Cloudflare 插件,官方启动脚本会将其复制到 /shared/letsencrypt/dnsapi/。请保持 URL 中的版本与 templates/web.letsencrypt.ssl.template.yml 中的 acme.sh 版本一致(目前是 3.0.6)。
  • run: 部分在模板之后运行,因此 replace 步骤将官方启动脚本从 HTTP 验证切换为 DNS 验证。
  • acme.sh 在验证期间从环境中读取 CF_Token 和 CF_Zone_ID,并将它们与证书一起保存。每日 cron 作业无法看到容器环境,因此续期操作会使用保存的副本。
如果你使用了我的旧模板,请从 templates: 中移除相关行,并将 LETSENCRYPT_CF_TOKEN 和 LETSENCRYPT_CF_ZONE_ID 重命名为 CF_Token 和 CF_Zone_ID。
如果你已经拥有证书(来自 HTTP 验证或我的旧模板),请在重建之前将旧的 acme.sh 文件夹移至别处:
cd /var/discourse
mv shared/standalone/letsencrypt shared/standalone/letsencrypt.old
如果不这样做,acme.sh 可能会跳过 DNS 步骤(它会保留旧方法直到需要续期,且 Let’s Encrypt 可以复用近期的验证记录)。结果导致令牌永远不会被保存,且第一次 cron 续期会失败。使用全新的文件夹后,acme.sh 将注册一个新账户并执行真正的 DNS 验证,因此首次启动大约会多花一分钟。
在新证书正常工作之前,请保留 .old 文件夹。如果 DNS 步骤失败,启动脚本仍会覆盖 shared/ssl 中的文件,nginx 将无法启动。
acme.sh 以纯文本形式将令牌存储在 shared/standalone/letsencrypt/ 下,因此请仅授予令牌所需的权限。
截至 2026 年 11 月,已在 discourse_docker 和 Discourse latest 版本上测试通过。
我按照此操作后,遇到了 CloudFlare 521 错误。该错误出现在我的 Discourse URL(forum.website.tld)以及主域名(website.tld)上。我撤销了更改并重新构建,之后一切恢复正常。
是否有办法在重新构建后强制更新证书?
这是试图创建通配符证书还是指定 URL 的证书?
你好 @LotusJeff,
Cloudflare 521 错误意味着 Cloudflare 完全无法连接到你的服务器。这不是证书错误(证书错误会返回 525 或 526)。因此,Discourse 容器中的 nginx 没有运行。我假设你的主域名也显示相同的错误,因为它指向同一台服务器。DNS 插件只添加和删除一个 TXT 记录。它不会更改任何 A 记录或 CNAME 记录。
它是在尝试创建通配符证书吗? 不是。标准脚本仅请求为 DISCOURSE_HOSTNAME 生成证书,以及 DISCOURSE_HOSTNAME_ALIASES 中的任何名称。acme.sh 会添加一个 TXT 记录 _acme-challenge.forum.website.tld,等待 Let’s Encrypt 进行验证,然后将其删除。如果你使用 DISCOURSE_HOSTNAME_ALIASES,所有这些名称都必须包含在 CF_Zone_ID 指向的区域中。
如何强制生成新证书? 在重建前将旧的 letsencrypt 文件夹移开就是强制手段。如果该文件夹为空,acme.sh 就没有可保留的证书,因此会在下次启动时执行新的 DNS 验证。请不要重复运行 --force:每次成功的运行都会签发两个证书(RSA 和 ECDSA),而 Let’s Encrypt 允许同一主机名在 7 天内最多申请 5 个证书。
为什么 nginx 没有启动。 Let’s Encrypt 脚本在容器启动时、nginx 之前运行。如果你已将文件夹移开,可能有以下两个原因:
  1. 它仍在等待。 使用 DNS 验证时,acme.sh 会等待 TXT 记录出现在公共 DNS 中。使用 Cloudflare 时,这通常不需要一分钟。但如果记录未出现,acme.sh 会为每个证书等待最多 20 分钟,在此期间 Cloudflare 将一直显示 521 错误。
  2. DNS 步骤失败。 在这种情况下,标准脚本仍会在 shared/ssl 中写入空文件,导致 nginx 无法启动。
如果你没有移开该文件夹,acme.sh 会跳过 DNS 步骤直到需要续期,因此 521 错误更可能是由重建本身引起的。请检查你是否将我的配置行添加到了 app.yml 现有的 templates:、env: 和 run: 部分中,而没有新建部分。标准的 app.yml 文件底部已经有一个 run: 部分。如果某个键在文件中出现两次,只有最后一次生效。
查找原因。 acme.sh 的日志在重建后仍保留在共享文件夹中,因此其中仍包含启动失败的错误信息:
cd /var/discourse
grep -a -i -E 'error|invalid|can not find|timed out|cert success' shared/standalone/letsencrypt*/acme.sh.log | tail -n 40
欢迎在此发布输出结果。acme.sh 在默认日志级别下不会将令牌写入此日志,但在发布前请检查之前的行。
重试前先测试。 此操作会在正在运行的容器内的临时文件夹中,针对 Let’s Encrypt 预发布(staging)服务器执行完整的 DNS 验证。它不会影响你的实际证书或生产环境的速率限制,因此你的论坛可以保持正常运行:
cd /var/discourse
./launcher enter app
mkdir -p /tmp/acme-test/dnsapi
curl -fsSL https://raw.githubusercontent.com/acmesh-official/acme.sh/3.0.6/acme.sh -o /tmp/acme-test/acme.sh
curl -fsSL https://raw.githubusercontent.com/acmesh-official/acme.sh/3.0.6/dnsapi/dns_cf.sh -o /tmp/acme-test/dnsapi/dns_cf.sh
chmod +x /tmp/acme-test/acme.sh
CF_Token="YOUR_TOKEN" CF_Zone_ID="YOUR_ZONE_ID" /tmp/acme-test/acme.sh --home /tmp/acme-test \
  --server letsencrypt_test --issue --dns dns_cf -d forum.website.tld
rm -rf /tmp/acme-test
exit
如果最后显示 Cert success.,说明你的令牌、区域 ID 和 DNS 设置都没问题,问题出在 app.yml 的更改上。如果失败,错误信息会告诉你原因。例如,invalid domain 通常意味着区域 ID 错误,或者令牌没有访问该区域的权限。
再次重建时,请使用 docker logs -f app 观察启动过程,并给它几分钟时间再考虑回滚。你应该会看到两次 Cert success.,然后 nginx 就会启动。
