DNS validation for Let's Encrypt?
סיכום מבוסס בינה מלאכותית
In a discussion titled “DNS validation for Let’s Encrypt?” under the Self-hosting support category, danb35 seeks to configure Discourse on a private network with Let’s Encrypt SSL using DNS validation (preferably via acme-dns or Cloudflare API). They ask whether the standard Docker container supports DNS validation or if they can manually point the container to a cert/key file and trigger a reload upon renewal. pfaffman responds that while possible, it’s unsupported and requires manual container modifications—either via ./launcher enter app or by editing app.yml. They also provide a link to a guide on manually configuring SSL certificates for Discourse Docker setups: Advanced Setup: Only Allowing SSL/HTTPS for Your Discourse Docker Setup. danb35 thanks pfaffman and notes they’ll follow up in the linked topic.
I’m wanting to install Discourse on a private network that won’t be accessible from the Internet, but I still want to set it up with Let’s Encrypt SSL. I’ve used DNS validation for a number of other hosts on this network, and it works well using either acme-dns (preferred) or Cloudflare’s DNS API. I can think of two possible ways to handle this:
  • (preferred) Can the standard Docker container installation be configured to use DNS validation with Let’s Encrypt?
  • If not, is there a way I can point the Discourse container to a cert/key somewhere in the filesystem, and cause it to reload when a new cert is generated?
Anything is possible. You should be able to make changes inside the container to have acme do that. I’m not aware of any instructions that describe the process. You can ./launcher enter app and make changes that will stay in effect until you rebuild the container. You can also add stuff to app.yml that will make those changes on rebuild, but you’re far afield from a supported installion then.
Thanks, the link you gave looks like it should do the trick. I have a follow-up question, but it’s probably better in that topic.
