Stephen
(Stephen)
19 november 2015 om 21:05
1
We’ve just upgraded to 1.5b5(33) and letter avatars aren’t working.
They link to:
/letter_avatar_proxy/v2/letter/l/a6a055/45.png
Our site setting is still:
/letter_avatar_proxy/v2/letter/{first_letter}/{color}/{size}.png
While I notice that avatars here on meta are being served from avatars.discourse.org
Any ideas?
mrosas
(mrosas)
19 november 2015 om 21:22
Ditto for us.
Looks like there were changes that went in recently impacting this code here:
committed 09:02AM - 19 Nov 15 UTC
Proxy letter avatars by default
bweissman
(Bryan Weissman)
19 november 2015 om 21:31
3
At least until they fix it, changing the external system avatars URL to “https://avatars.discourse.org/v2/letter/{first_letter}/{color}/{size}.png ” fixed the problem for me.
Stephen
(Stephen)
19 november 2015 om 21:32
4
Looks like this requires a launcher rebuild to resolve, avatars are working once again.
Presumably grabbing the latest build via rebuild either creates or grabs local copies of these images. All you’re doing above is using the versions hosted on another site.
@sam if a beta upgrade isn’t going to work correctly until a rebuild has happened, isn’t it a bit silly to prompt the user with an upgrade button in the back end?
sam
(Sam Saffron)
19 november 2015 om 21:33
5
Confirmed, you must rebuild to get the fix, I will see if I can add a big red warning on /admin/upgrade page
tgxworld
(Alan Tan)
20 november 2015 om 01:38
7
The avatars breaks in development mode though since nginx is not running on top of the rails web server.
sam
(Sam Saffron)
20 november 2015 om 01:52
8
Yeah I noticed that, maybe we should add a route for it, mainly for dev @mpalmer
mpalmer
(Matt Palmer)
20 november 2015 om 01:55
9
Would that be a route for /letter_avatar_proxy to feed back into the internal avatar generation code? I think that’d be reasonable.
sam
(Sam Saffron)
13 februari 2016 om 09:57
11
I think we sorted this out a while back, closing, flag to reopen if still an issue.
