Lightboxed afbeeldingen hebben geen `vertical-align` ingesteld, waardoor ze niet uitgelijnd zijn met kale `img`s
The discussion revolves around an issue with lightboxed images not having the vertical-align property set, causing misalignment with non-lightboxed images. Obskyr reported the issue, providing reproducible steps and screenshots. They proposed a simple fix: adding vertical-align: middle to .lightbox-wrapper. awesomerobot confirmed the fix and applied it in a GitHub pull request, which will be available in future Discourse updates. Obskyr expressed gratitude for the quick resolution.
Priority/Severity: Low.
Platform: Confirmed in Firefox 127.0 on Windows 10 and Chrome 125.0.6422.165 on Android 14.
Description: See below.
Reproducible steps: Place two images, one with a resolution of above 690×500 pixels (in either dimension) and one with a resolution below, on the same line.
Expected behavior
Lightboxed images and naked imgs should be treated the same way by CSS, bar all the extra bells and whistles of a lightbox.
The issue
Discourse’s built-in CSS has vertical-align: middle set for img, but not for .lightbox-wrapper, resulting in lightboxed and non-lightboxed images on the same line being out of alignment and taking up unnecessary vertical space:
The solution
The fix is simple: Add vertical-align: middle to .lightbox-wrapper as well.
Thanks for the detailed report! A fix has been applied here:
https://github.com/discourse/discourse/pull/27520
and will be available in Discourse updates soon
Wonderful! Thanks a bundle and a half! :blush:
This topic was automatically closed after 3 days. New replies are no longer allowed.
