1
vs.
- a
- b
foo
- c
123 is rendered as 3 individual lists, abc as 2 lists.
(Although this might also be a Markdown “feature”, please close if this is the case)
1
vs.
foo
123 is rendered as one unordered list, just with spacing. ab and c are two lists, as you added a non-list element.
Here’s your markdown:
- 1
- 2
- 3
vs.
- a
- b
foo
- c
Note the raw HTML:
<div class="cooked">
<ul>
<li>
<p>1</p>
</li>
<li>
<p>2</p>
</li>
<li>
<p>3</p>
</li>
</ul>
<p>vs.</p>
<ul>
<li>a</li>
<li>b</li>
</ul>
<p>foo</p>
<ul>
<li>c</li>
</ul>
</div>
So everything appears to be working as I’d expect. What did you expect to happen?
To 1 and 2 not having any spacing, optionally also for 3 to be in its own list.
Basically:
<ul>
<li>
1
</li>
<li>
</li>
</ul>
<ul>
<li>
3
</li>
</ul>
That’s not how Commonmark works. You need something between the lists, not just a blank line.
You are right, this is really an eample in the spec:
http://spec.commonmark.org/0.28/#example-275
What a …strange… thing.
The only solution for my problem seems to be this:
- foo
- bar
<br>
- baz
