Logging sometimes reports wrong database in multisite
The discussion revolves around an issue where Rails logs in a multisite Discourse setup sometimes report incorrect databases, likely due to a race condition in logging. Users michaeld, sam, and tgxworld acknowledge the problem and suggest that the current log format is problematic. sam proposes adopting lograge as a better, more parsable logging solution, which tgxworld has already implemented with a hidden setting. The team is considering making lograge the default, with codinghorror and pfaffman supporting this move. dscat adds that while lograge is useful, the default KeyValue formatter complicates integration with their JSON-based logging stack, and has proposed a PR to allow overriding the formatter via an environment variable.
I was investigating an issue and it seems like the lines in production.log sometimes report the wrong database.
I’ve seen this a few times before, so this is not a single incident. Here’s a good and clear example where you can see that the third line has been logged as belonging to database db3785 where it obviously is about the same request as the fourth line, which is logged as belonging to db9210.
I was unable to pinpoint the responsible code, it might be deep inside Rails, and this is probably a race condition.
v1.8.x on Unicorn.
No, we’re not using Docker, no, I don’t think that matters here, and no, I don’t expect a quick solution.
Just letting you guys know what we are seeing :slight_smile:
1 „Gefällt mir“
Rails logs are a trashfire, we plan to start using a new format in future
6 „Gefällt mir“
I’ll put this on my list first, it seems like the connection is switched even before logging is complete.
6 „Gefällt mir“
This is really unsolvable with the current log format. @tgxworld is going to investigate making GitHub - roidrage/lograge: An attempt to tame Rails' default policy to log everything. · GitHub an optional (and hopefully default) log format for rails to avoid this mess and give us properly parsable log files.
3 „Gefällt mir“
Note that lograge can now be enabled via a hidden SiteSetting.logging_provider or setting ENABLE_LOGRAGE to 1. We’ll be testing this on our servers for awhile before deciding if lograge should be the default for all Discourse users.
4 „Gefällt mir“
Is lograge the default now?
1 „Gefällt mir“
Nope but we can make it so.
3 „Gefällt mir“
Ich verschiebe dies nach Contribute > Feature, da wir bereits ein System haben, das für Multisite gut funktioniert, und Multisite sehr, sehr selten vorkommt.
Ich bin einverstanden, langfristig standardmäßig auf Lograge umzusteigen; das wird dem Discourse Doctor mehr Argumente liefern.
3 „Gefällt mir“
lograge seems like a vast improvement and it took me forever to find this topic to find how to start it.
Is it too soon to un-hide the site setting?
Would it be disastrous to change the default to lograge for new installs?
It’s not immediately clear what discourse-doctor might do, grep for “Error”, but having some logs around to look at is a first step. . .
Yeah @tgxworld let’s make lograge the default?
Hallo,
in unserer Organisation nutzen wir für alle unsere Anwendungen Lograge/Graylog und verwenden das JSON-Format, da es uns eine übersichtlichere Möglichkeit bietet, Probleme zu identifizieren.
Wir implementieren ein Forum mit Discourse, das zwar eine Lograge-Option bietet, aber den KeyValue-Formatter verwendet, was unsere Einrichtung erschweren würde.
Ich habe einen PR erstellt: adding a lograge formatter env var by dscataglini · Pull Request #12206 · discourse/discourse · GitHub. Dieser behält zwar den Standard-Formatter weiterhin auf KeyValue, ermöglicht aber eine Überschreibung durch Angabe einer Umgebungsvariable LOGRAGE_FORMATTER.
1 „Gefällt mir“
