Looking to self-host with Vercel. Possible?
After forking the open-source version of Discourse on GitHub, I proceeded to deploy my website using Vercel.
However, I encountered an error, depicted in the image below. Is there a straightforward solution to this problem, or is it simply not possible to utilize Discourse with Vercel?
According to Does Vercel support Docker deployments?, it does not appear to support Docker, a requirement for Discourse:
Vercel is a serverless platform with support for 35+ frontend frameworks and does not support running docker instances.
The one and only! :discourse:
Thank you! I’ve submitted an application and I’m eagerly awaiting the acceptance. If I don’t get approved, I’ll consider self-hosting! :heart:
