Gemeenschapscultuur behouden zonder geïnteresseerde gebruikers teleur te stellen - alleen-lezen toegang geven aan gebruikers die wachten op goedkeuring
In a discussion titled Maintain community culture without disappointing interested users - give read-only access to users pending approval, Himanshu_Singh seeks advice on balancing community quality with user access. He requires users to register via SSO and request approval before accessing the forum, aiming to filter for serious, interested members ahead of potential monetization. However, he wants to grant read-only access to high-intent applicants still awaiting approval — a feature not natively supported when approval is mandatory.
Ed_S challenges the gatekeeping approach, suggesting that overly restricting entry may hinder growth and engagement. Instead, he recommends leveraging Discourse’s trust levels — particularly keeping new users at Trust Level 0, which restricts posting and private messaging. He suggests manually promoting users after evaluating their behavior, and using settings like “Posts for users below this trust level must be approved” to moderate content. He also advises ensuring adequate moderation to manage community tone.
Himanshu_Singh responds appreciatively, acknowledging he underestimated trust levels. He clarifies his need to collect user backgrounds for personalized education content, and considers approving users more generously while using trust levels to control permissions — effectively achieving his goal of read-only access for pending users without compromising community culture.
Hey all
I am trying to do right by users while maintaining the culture in the community. I have the following scenario and would appreciate insights from folks here -
  1. I have login_required enabled to access the community as I want to give access to only people with a certain level of interest and seriousness. I also plan to charge for community access later on once I have some traction.
  2. I have setting enabled - user must be approved before accessing the community.
  3. I am using SSO for login and users are automatically activated on registration in WordPress
  4. Any user who wants to access the community has to fill a request access form - (either they are registered or not registered on the parent site). This allows me to check their profile before giving them access to the community.
  5. Having said that, there are some users who have registered and have requested access to the community but have not been approved yet. These users have shown strong intent to be part of the platform but I still need to filter out some applicants to maintain the quality of the forum and build a culture.
  6. I don’t want to shut these high intent users out fully and at least enable them to read the topics in the forum. Currently, this is not possible when user approval is required.
Is there a workaround to make this happen?
Are you sure you want to gatekeep the entrance to your community? You make a barrier to enter and this will limit the growth and the member contributions. Maybe your community is already very lively, but perhaps you are also concerned about not having enough participants?
Which is to say, instead of looking at who is in, perhaps consider looking at what people say. You’ll probably need to do that anyway, even if you are very careful about who joins: people change, people have moods, people react to other people.
I think in your position I would make joining up relatively low-friction, but I would take steps to keep people at trust level 0. Search site settings for ‘promotion’ and you’ll see the criteria for promotion to level 1: for example, time spent, or number of topics read. You can make those very large, and then there will be no automatic promotions. You can then promote people manually.
While the new member is stuck at level 0, they can’t create topics or use private messages. You can use ‘approve unless trust level’ to stop them posting at all, I think: “Posts for users below this trust level must be approved.”
If you are concerned about the wrong kinds of posts, I recommend you have a proportionate number of moderaters for your membership and volume of posts.
Long story short, I think you can arrange for trust level 0 to do most of what you want.
@Ed_S Thanks for the insight. I have been underestimating the power of trust levels on Discourse.
I still want users to tell me who they are when they join so that I can serve them better. I have an education tech product that requires me to create project prompts and serve learning resources based on user backgrounds. May be I need to be very generous in approving users so that they can start using the tool right away and I use trust levels to manage access.
Super helpful post! Thank you.
