Making filters work without reload
I’ve just done some work on discourse-solved, and added some filters. These work fine if you visit the URLs directly, but if you follow a link from within the site then it doesn’t work.
If I click on this link, it doesn’t apply the filter until I hit reload.
Support - Discourse Meta
Do I need to add it to the Ember router or something like that? How would I go about doing that?
AddDiscoveryQueryParam is your friend
https://github.com/discourse/discourse-assign/blob/master/assets/javascripts/discourse/initializers/extend-for-assigns.js.es6#L59
Well, that was easy - it’s almost like someone’s had this problem before :wink:
Thanks again, I’ve submitted another PR
Just in case someone comes across this thread in future, using “true”/“false” in the query variables can create some unexpected behaviour. Ember will consider “false” the default, which might not be what you want.
이것이 작동하나요?
필터로 solved를 선택하면 페이지를 새로고침하지 않는 한 토픽이 필터링되지 않는 것을 확인했습니다.
