Marker element being striped out from uploaded SVG
When uploading an SVG the resulting SVG has removed marker elements. Is there a way to stop this from happening?
Example:
dex-unauthenticated
The raw image can be found here:
https://raw.githubusercontent.com/juju-solutions/bundle-kubeflow/1c76d8a0292f0a969f1ce416767ff3d5847508ca/docs/img/dex-unauthenticated.svg
I guess we can add the <marker> element to the allowlist. I don’t see any attributes that affect security.
Thank you, filed a PR to have marker added to the allowlist when uploading an SVG.
For reference WebKit has had security problems with the marker element. The last issue was an RCE in December.
Thanks for the fix @anthonydillon !
