Mass close topics?
Is mass close topics available?
If not, I would recommend to add this option.
To the right of the Topic header there’s a list icon. Click on that, select the topics you want to close, click the wrench on the right-hand side of the screen, and close the topics. :wink:
I mean, we have posts from 2008, and we would like to close all topics before 2015 let’s say, I won’t stay 1 day on selecting all that man! :smiley:
See here
PS: In support requests you should be a bit more specific
There is a setting to autoclose topics at a certain post count. And a warn user if topic is older than setting. An “autoclose after nnn days” wouldn’t be a bad idea.
At the Category level, there are
  • close topics after n (topic creation time)
  • close topics n after last reply (last post time)
I don’t know how it works with imported topics, but because importing topics is rarely done, IMHO there isn’t a critical need for a “close retro” Setting and a CLI command should suffice.
OUI ! Merci Joe d’avoir visualisé ce processus. J’étais perdu dans un Discourse que j’ai hérité et c’était le flux de travail manquant pour le nettoyage.
