מיזוג טקסט מעוצב שהודבק => בלוק קוד כאשר יש רק רווח כמפריד
סיכום מבוסס בינה מלאכותית
A user suggests that Discourse should automatically merge pasted preformatted text into a single code block when separated only by a space, to improve handling of debug information. NameLessGO notes an example where this would help, but 2 sam warns that guessing intent could backfire, as multiple code blocks are sometimes needed. Jagster provides a valid use case for multiple code blocks, such as in usage examples. renato asks for clarification and suggests checking if the issue persists on the latest version. NameLessGO acknowledges the valid use case and agrees the suggestion should be closed as won’t fix.
Saw an issue with the wrong use of preformatted text in Anki Forums, and thought if Discourse could merge them automatically in the new composer then it would help users and devs when dealing with debug informations
Actual behavior (From post below):
b2d2) (ao)Python 3.13.5 Qt 6.9.1 PyQt 6.9.1Platform: Windows-11-10.0.26100-SP0
Traceback (most recent call last):File “C:\Users\lejla\AppData\Local\AnkiProgramFiles.venv\Lib\site-packages\aqt\webview.py”, line 188, in cmdreturn json.dumps(self.onCmd(str))~~~~~~~~~~^^^^^File “C:\Users\lejla\AppData\Local\AnkiProgramFiles.venv\Lib\site-packages\aqt\webview.py”, line 275, in _onCmdreturn self._onBridgeCmd(str)~~~~~~~~~~~~~~~~~^^^^^File “C:\Users\lejla\AppData\Local\AnkiProgramFiles.venv\Lib\site-packages\aqt\webview.py”, line 800, in _onBridgeCmdhandled, result = gui_hooks.webview_did_receive_js_message(~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^(False, None), cmd, self._bridge_context^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^)^File “C:\Users\lejla\AppData\Local\AnkiProgramFiles.venv\Lib\site-packages_aqt\hooks.py”, line 5543, in callhandled = filter(handled, message, context)File “C:\Users\lejla\AppData\Roaming\Anki2\addons21\1898790263\contanki.py”, line 146, in on_receive_messagefuncsfunc~~~~~~~~~~~^^^^^^^File “C:\Users\lejla\AppData\Roaming\Anki2\addons21\1898790263\contanki.py”, line 165, in if_connected_wrapperfunc(self, *args, **kwargs)~~~~^^^^^^^^^^^^^^^^^^^^^^^File “C:\Users\lejla\AppData\Roaming\Anki2\addons21\1898790263\contanki.py”, line 177, in pollaxes = [float(axis) for axis in input_axes.split(“,”)]~~~~~^^^^^^ValueError: could not convert string to float: ‘’
===Add-ons (active)===(add-on provided name [Add-on folder, installed at, version, is config changed])Contanki - Controller Support for Anki beta [‘1898790263’, 2024-02-29T19:22, ‘v1.0.2’, mod]Image Occlusion Enhanced [‘1374772155’, 2022-04-09T02:15, ‘None’, ‘’]
===IDs of active AnkiWeb add-ons===1374772155 1898790263
===Add-ons (inactive)===(add-on provided name [Add-on folder, installed at, version, is config changed])
Expected behavior:
Anki 25.07.5 (7172b2d2) (ao)Python 3.13.5 Qt 6.9.1 PyQt 6.9.1Platform: Windows-11-10.0.26100-SP0
If there is text separating the preformatted text, then it should not be merged
Edit: There isn’t a code lenght in code block so it streches indefinitely, there should be a default value which is configurable to Admins (speaking as a user, not sure if there is a setting already present)
אני חושש שניחוש הכוונה כאן יתנקם.
אני יכול לחשוב על כמה מקרים שבהם תרצה מספר בלוקי קוד אחד אחרי השני.
2 לייקים
I did multiple code blocks just 5 minutes ago. Quite normal way to do in minimum level when giving usage examples.
Just an example
sudo nano /usr/local/bin/docker-ips
#!/bin/bash
# show IPs of containers/gateways and network ID (short form)
if [ $# -eq 0 ]; then
  containers=$(docker ps -q)
else
  containers=$(docker ps -qf "name=$1")
fi
for cid in $containers; do
  cname=$(docker inspect --format '{{.Name}}' "$cid" | sed 's|/||')
  echo "=== $cname ==="
  docker inspect -f '{{range $net,$v := .NetworkSettings.Networks}}Verkko: {{$net}}
  Kontin IP: {{$v.IPAddress}}
  Gateway:   {{$v.Gateway}}
  VerkkoID:  {{printf "%.12s" $v.NetworkID}}{{"\n"}}{{end}}' "$cid"
done
sudo chmod +x /usr/local/bin/docker-ips
I don’t use rich editor anywhere but in my phone, but normally we can’t get empty lines without <br> so then there should be meaningless text :thinking:
לייק 1
I’m not sure I follow what the problem is, exactly. We have made many improvements to inline/block code handling since then, though, can you check if the issue still persists on latest / here on Meta? Thank you!
לייק 1
it’s not an issue!, Thanks for checking out again, but Jagster gave a valid use case which did not thought when was making this suggestion
Please close this post as won’t fix or equivalent :heart:
לייק 1
