As it can be seen, when the toolbar is collapsed, the message counter is hidden behind the avatar.
Hope I’m not duplicating an existing UX issue report.
I’m not able to reproduce this; which operating system and browser are you using?
MacOS latest, Google Chrome
Ah ok, I couldn’t reproduce it because it was being caused by the discourse-locations plugin.
I submitted a PR to fix the plugin:
https://github.com/angusmcleod/discourse-locations/pull/13
but if you want to fix it immediately, you can also add this to your site’s custom CSS:
.topic-map .avatars .post-count {
z-index: 99;
Oh thank you!
Didn’t event think it might be affect by a plugin like that.
This occurred due to conflicting use of the class .map
. Thanks @awesomerobot. Fixed.
https://github.com/angusmcleod/discourse-locations/commit/f54d1367b6d16fa8fc0506534696fc4b06b0c611
