Meta Topic en Mijn Posts onder Community lijken gemengd in Safari op iOS (ipad)
A user, Lilly, reported an issue on Meta where the “Topics” and “My Posts” links under the Community section in the navigation menu are mixed up when using Safari on an iPad. Lilly provided a video to demonstrate the issue and mentioned that it only occurs on the iPad, as the links work fine on Chrome in Windows and Android. Canapin was able to reproduce the issue on their iPad and in Chrome’s mobile/touch mode, and found the problem to be caused by a CSS override in the Discourse code. However, with the removal of the “My Posts” link, JammyDodger suggested closing the issue, but asked to be notified if the problem persists.
on Meta, the Topics and My Posts under Community in the navigation menu seem mixed up and i think those links need to be fixed or switched. iOS Safari desktop
repro:
go to latest or main category page. tap My Posts. tap Topics, etc.
FWIW, they seem to work fine for me
Android/Chrome
yea they seem ok in chrome windows desktop. i was having the issue all day with them on my ipad.
you can also see in the video that i had to tap more than couple times to get the links to work. at one point i tapped the logo and it went to one of my own custom links when i had the community section collapsed.
I can repro on my ipad (and Chrome in mobile/touch mode). I’ll investigate a bit :slight_smile:
It seems this line overrides the .active class highlight of the current section:
this is still happening regularly on Meta for me. i can’t seem to repro on my site though. i suspect it is because i have navigation menu sidebar mods in place for the community section.
I think this one is no longer applicable now we don’t have a ‘My Posts’ link?
I’ll close it off, but give me a ping if it’s still a thing. :slight_smile:
