Metodo mancante durante la pubblicazione di un nuovo post
Ciao,
usando l’ultima versione, quando rispondo a un post ora ricevo:
Messaggio (2 copie riportate)
NoMethodError (metodo `embed_unlisted?' non definito per #<Class:0x00007f8dbd27d880>)
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.1/lib/active_record/dynamic_matchers.rb:22:in `method_missing'
Backtrace
/var/www/discourse/lib/post_creator.rb:419:in `make_visible'
/var/www/discourse/lib/post_creator.rb:189:in `block in create'
/var/www/discourse/lib/post_creator.rb:367:in `block (2 livelli) in transaction'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:281:in `block in transaction'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/transaction.rb:280:in `block in within_new_transaction'
/usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/transaction.rb:278:in `within_new_transaction'
activerecord-6.0.1/lib/active_record/connection_adapters/abstract/database_statements.rb:281:in `transaction'
activerecord-6.0.1/lib/active_record/transactions.rb:212:in `transaction'
Env
HTTP HOSTS: talk.remobjects.com
Qualcuno sa cosa potrebbe causare questo?
Stack completo:
/var/www/discourse/lib/post_creator.rb:366:in `block in transaction'
/var/www/discourse/lib/distributed_mutex.rb:33:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:29:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:14:in `synchronize'
/var/www/discourse/lib/post_creator.rb:365:in `transaction'
/var/www/discourse/lib/post_creator.rb:174:in `create'
/var/www/discourse/lib/new_post_manager.rb:271:in `perform_create_post'
/var/www/discourse/lib/new_post_manager.rb:206:in `perform'
/var/www/discourse/app/controllers/posts_controller.rb:179:in `create'
actionpack-6.0.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-6.0.1/lib/abstract_controller/base.rb:196:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack-6.0.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport-6.0.1/lib/active_support/callbacks.rb:135:in `run_callbacks'
actionpack-6.0.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport-6.0.1/lib/active_support/notifications.rb:180:in `block in instrument'
activesupport-6.0.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-6.0.1/lib/active_support/notifications.rb:180:in `instrument'
actionpack-6.0.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack-6.0.1/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord-6.0.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-6.0.1/lib/abstract_controller/base.rb:136:in `process'
actionview-6.0.1/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-2.0.1/lib/mini_profiler/profiling_methods.rb:104:in `block in profile_method'
actionpack-6.0.1/lib/action_controller/metal.rb:191:in `dispatch'
actionpack-6.0.1/lib/action_controller/metal.rb:252:in `dispatch'
actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:51:in `dispatch'
actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack-6.0.1/lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-6.0.1/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-6.0.1/lib/action_dispatch/routing/route_set.rb:837:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
rack-2.0.8/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.0.8/lib/rack/conditional_get.rb:38:in `call'
rack-2.0.8/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:318:in `call'
rack-2.0.8/lib/rack/session/abstract/id.rb:259:in `context'
rack-2.0.8/lib/rack/session/abstract/id.rb:253:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-6.0.1/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-6.0.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster-2.8.0/lib/logster/middleware/reporter.rb:43:in `call'
railties-6.0.1/lib/rails/rack/logger.rb:38:in `call_app'
railties-6.0.1/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:22:in `call'
rack-2.0.8/lib/rack/method_override.rb:22:in `call'
rack-2.0.8/lib/rack/sendfile.rb:111:in `call'
actionpack-6.0.1/lib/action_dispatch/middleware/host_authorization.rb:77:in `call'
rack-mini-profiler-2.0.1/lib/mini_profiler/profiler.rb:312:in `call'
message_bus-2.2.4/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:172:in `call'
rails_multisite-2.1.1/lib/rails_multisite/middleware.rb:25:in `call'
railties-6.0.1/lib/rails/engine.rb:526:in `call'
railties-6.0.1/lib/rails/railtie.rb:190:in `public_send'
railties-6.0.1/lib/rails/railtie.rb:190:in `method_missing'
rack-2.0.8/lib/rack/urlmap.rb:68:in `block in call'
rack-2.0.8/lib/rack/urlmap.rb:53:in `each'
rack-2.0.8/lib/rack/urlmap.rb:53:in `call'
unicorn-5.5.4/lib/unicorn/http_server.rb:605:in `process_client'
unicorn-5.5.4/lib/unicorn/http_server.rb:700:in `worker_loop'
unicorn-5.5.4/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
unicorn-5.5.4/lib/unicorn/http_server.rb:562:in `maintain_worker_count'
unicorn-5.5.4/lib/unicorn/http_server.rb:295:in `join'
unicorn-5.5.4/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
Penso che tu abbia uno stato strano in cui alcune cose non sono state aggiornate completamente:
sam@arch discourse % bin/rails c
Caricamento dell'ambiente di sviluppo (Rails 6.0.1)
[1] pry(main)> SiteSetting.embed_unlisted?
=> false
Puoi provare a eseguire
./launcher rebuild app
