迁移到 S3 在重新烘焙时失败
@itsbhanusharma 的帮助下,我一直在努力将旧上传文件迁移到 S3。
我按照本指南中的步骤操作:
重建后,上传文件仍未迁移到 S3,这很奇怪。Discourse-doctor 报告了一个 DNS 问题:
> Discourse version at : NOT FOUND
> Discourse version at localhost: Discourse 2.5.0.beta4
> **> ==================== DNS PROBLEM ====================**
> **> This server reports Discourse 2.5.0.beta4 , but reports NOT FOUND.**
> **> This suggests that you have a DNS problem or that an intermediate proxy is to blame.**
> **> If you are using Cloudflare, or a CDN, it may be improperly configured.**
我手动运行了迁移到 S3 的操作,结果如下:
 > root@discourse-app:/var/www/discourse# rake --trace uploads:migrate_to_s3
 > ** Invoke uploads:migrate_to_s3 (first_time)
 > ** Invoke environment (first_time)
 > ** Execute environment
 > ** Execute uploads:migrate_to_s3
 > Migrating uploads to S3 for 'default'...
 > Uploading files to S3...
 >  - Listing local files
 > .. => 2980 files
 >  - Listing S3 files
 > .... => 3156 files
 >  - Syncing files to S3
 > Updating the URLs in the database...
 > Warning: no type cast defined for type "name" with oid 19. Please cast this type explicitly to TEXT to be safe for future changes.
 > Removing old optimized images...
 > Flagging all posts containing lightboxes for rebake...
 > 781 posts were flagged for a rebake
 > rake aborted!
 > FileStore::ToS3MigrationError: 68 posts are not remapped to new S3 upload URL. S3 migration failed for db 'default'.
 > /var/www/discourse/lib/file_store/to_s3_migration.rb:131:in `raise_or_log'
 > /var/www/discourse/lib/file_store/to_s3_migration.rb:86:in `migration_successful?'
 > /var/www/discourse/lib/file_store/to_s3_migration.rb:351:in `migrate_to_s3'
 > /var/www/discourse/lib/file_store/to_s3_migration.rb:65:in `migrate'
 > /var/www/discourse/lib/tasks/uploads.rake:239:in `migrate_to_s3'
 > /var/www/discourse/lib/tasks/uploads.rake:218:in `block in migrate_to_s3_all_sites'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.1.2/lib/rails_multisite/connection_management.rb:64:in `with_connection'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rails_multisite-2.1.2/lib/rails_multisite/connection_management.rb:74:in `each_connection'
 > /var/www/discourse/lib/tasks/uploads.rake:216:in `migrate_to_s3_all_sites'
 > /var/www/discourse/lib/tasks/uploads.rake:212:in `block in <top (required)>'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `block in execute'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `each'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:281:in `execute'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
 > /usr/local/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/task.rb:188:in `invoke'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:160:in `invoke_task'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block (2 levels) in top_level'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `each'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:116:in `block in top_level'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:125:in `run_with_threads'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:110:in `top_level'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:83:in `block in run'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:186:in `standard_exception_handling'
 > /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/lib/rake/application.rb:80:in `run'
 > bin/rake:13:in `<top (required)>'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors'
 > /usr/local/lib/ruby/gems/2.6.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>'
 > /usr/local/bin/bundle:23:in `load'
 > /usr/local/bin/bundle:23:in `<main>'
 > Tasks: TOP => uploads:migrate_to_s3
@gerhard,对此有什么想法吗?
失败是因为以下检查未通过:
建议您查明这些路径为何未被正确重映射。尝试在 Rails 控制台中运行以下命令,查看这些帖子的 cooked 字段。其中某处可能包含线索…
current_db = RailsMultisite::ConnectionManagement.current_db
cdn_path = SiteSetting.cdn_path("/uploads/#{current_db}/original").sub(/https?:/, "")
Post.where("cooked LIKE '%#{cdn_path}%'").pluck(:cooked)
Here’s the output from the rails console: (this is only part of it and it is ugly)
root@discourse-app:/var/www/discourse# rails console
[1] pry(main)> current_db = RailsMultisite::ConnectionManagement.current_db
=> "default"
[2] pry(main)> cdn_path = SiteSetting.cdn_path("/uploads/#{current_db}/original").sub(/https?:/, "")
=> "/uploads/default/original"
[3] pry(main)> Post.where("cooked LIKE '%#{cdn_path}%'").pluck(:cooked)
=> ["<p>U.C. Tricolor frag $30<br>\nRed Stylocoeniella $30<br>\nBranching Cyphastrea $40<br>\nOrenji Mont frag $30</p>\n<hr>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/2/282821b1e16dce48ac11f1d607412e1bfed61534.jpeg\" data-download-href=\"/uploads/short-url/5Jf4Z7WaQqYix5IDWN12IlLoYfi.jpeg?dl=1\" title=\"DSCN0069-005.JPG\"><img src=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/2/282821b1e16dce48ac11f1d607412e1bfed61534_2_524x500.jpeg\" alt=\"DSCN0069-005.JPG\" data-base62-sha1=\"5Jf4Z7WaQqYix5IDWN12IlLoYfi\" width=\"524\" height=\"500\" srcset=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/2/282821b1e16dce48ac11f1d607412e1bfed61534_2_524x500.jpeg, https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/2/282821b1e16dce48ac11f1d607412e1bfed61534_2_786x750.jpeg 1.5x, /uploads/default/original/2X/2/282821b1e16dce48ac11f1d607412e1bfed61534.jpeg 2x\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/2/282821b1e16dce48ac11f1d607412e1bfed61534_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0069-005.JPG</span><span class=\"informations\">800×762 181 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/9/960e0f184917ad7e0bbf2d6c31cf546fa9e124f5.jpeg\" data-download-href=\"/uploads/short-url/lprJZk3t4LfijslovcQ9kgaqzcN.jpeg?dl=1\" title=\"DSCN0119-003.JPG\"><img src=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/9/960e0f184917ad7e0bbf2d6c31cf546fa9e124f5_2_513x500.jpeg\" alt=\"DSCN0119-003.JPG\" data-base62-sha1=\"lprJZk3t4LfijslovcQ9kgaqzcN\" width=\"513\" height=\"500\" srcset=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/9/960e0f184917ad7e0bbf2d6c31cf546fa9e124f5_2_513x500.jpeg, https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/9/960e0f184917ad7e0bbf2d6c31cf546fa9e124f5_2_769x750.jpeg 1.5x, /uploads/default/original/2X/9/960e0f184917ad7e0bbf2d6c31cf546fa9e124f5.jpeg 2x\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/9/960e0f184917ad7e0bbf2d6c31cf546fa9e124f5_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0119-003.JPG</span><span class=\"informations\">800×779 186 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/5/548f0324f3b0e8dd482729c1d1f5c450b5556919.jpeg\" data-download-href=\"/uploads/short-url/c42vC8e8IRT52htW2RX7YedLpaN.jpeg?dl=1\" title=\"DSCN0072-004.JPG\"><img src=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/5/548f0324f3b0e8dd482729c1d1f5c450b5556919.jpeg\" alt=\"DSCN0072-004.JPG\" data-base62-sha1=\"c42vC8e8IRT52htW2RX7YedLpaN\" width=\"468\" height=\"500\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/5/548f0324f3b0e8dd482729c1d1f5c450b5556919_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0072-004.JPG</span><span class=\"informations\">750×800 180 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/d/dc75e2b57072ff260f99cfa9a7cc1e4f39c207f8.jpeg\" data-download-href=\"/uploads/short-url/vshBXgkYrsRhRqNFakI1jgIE5Sg.jpeg?dl=1\" title=\"DSCN0060-005.JPG\"><img src=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/d/dc75e2b57072ff260f99cfa9a7cc1e4f39c207f8_2_396x500.jpeg\" alt=\"DSCN0060-005.JPG\" data-base62-sha1=\"vshBXgkYrsRhRqNFakI1jgIE5Sg\" width=\"396\" height=\"500\" srcset=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/d/dc75e2b57072ff260f99cfa9a7cc1e4f39c207f8_2_396x500.jpeg, https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/d/dc75e2b57072ff260f99cfa9a7cc1e4f39c207f8_2_594x750.jpeg 1.5x, /uploads/default/original/2X/d/dc75e2b57072ff260f99cfa9a7cc1e4f39c207f8.jpeg 2x\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/d/dc75e2b57072ff260f99cfa9a7cc1e4f39c207f8_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0060-005.JPG</span><span class=\"informations\">635×800 196 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>",
 "<p>U.C. Raspberry delight frag $39 “radion”<br>\nORA Kelly green psammacora $39 \"radion<br>\nU.C. Red Dragon Frag $30<br>\nU.C. Red dragon Smaller frag $20</p>\n<hr>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/d/deb035a3639a3a3bb8b04ebd9da2b97fb5d8652d.jpeg\" data-download-href=\"/uploads/short-url/vLZwAqgUqcslrwos7Q27gheEVSR.jpeg?dl=1\" title=\"DSCN9908-003.JPG\"><img src=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/d/deb035a3639a3a3bb8b04ebd9da2b97fb5d8652d.jpeg\" alt=\"DSCN9908-003.JPG\" data-base62-sha1=\"vLZwAqgUqcslrwos7Q27gheEVSR\" width=\"561\" height=\"500\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/d/deb035a3639a3a3bb8b04ebd9da2b97fb5d8652d_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN9908-003.JPG</span><span class=\"informations\">800×712 165 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/e/e579dab30a023f12755b22e8bb1c077b34225110.jpeg\" data-download-href=\"/uploads/short-url/wK2pz5DNtgezJhhQuxaFE52CvnO.jpeg?dl=1\" title=\"DSCN0059-005.JPG\"><img src=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e579dab30a023f12755b22e8bb1c077b34225110_2_450x500.jpeg\" alt=\"DSCN0059-005.JPG\" data-base62-sha1=\"wK2pz5DNtgezJhhQuxaFE52CvnO\" width=\"450\" height=\"500\" srcset=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e579dab30a023f12755b22e8bb1c077b34225110_2_450x500.jpeg, https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e579dab30a023f12755b22e8bb1c077b34225110_2_675x750.jpeg 1.5x, /uploads/default/original/2X/e/e579dab30a023f12755b22e8bb1c077b34225110.jpeg 2x\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e579dab30a023f12755b22e8bb1c077b34225110_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0059-005.JPG</span><span class=\"informations\">721×800 231 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/e/e5d72072aee537852120d7106522b543e6af9085.jpeg\" data-download-href=\"/uploads/short-url/wNgfm2qrVEyTWGfUV3QAc2EGKfX.jpeg?dl=1\" title=\"DSCN0066-005.JPG\"><img src=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e5d72072aee537852120d7106522b543e6af9085_2_506x500.jpeg\" alt=\"DSCN0066-005.JPG\" data-base62-sha1=\"wNgfm2qrVEyTWGfUV3QAc2EGKfX\" width=\"506\" height=\"500\" srcset=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e5d72072aee537852120d7106522b543e6af9085_2_506x500.jpeg, https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e5d72072aee537852120d7106522b543e6af9085_2_759x750.jpeg 1.5x, /uploads/default/original/2X/e/e5d72072aee537852120d7106522b543e6af9085.jpeg 2x\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/e/e5d72072aee537852120d7106522b543e6af9085_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0066-005.JPG</span><span class=\"informations\">800×790 200 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>\n<p><div class=\"lightbox-wrapper\"><a class=\"lightbox\" href=\"//brcuploads.s3.dualstack.us-east-1.amazonaws.com/original/2X/3/3cd28b0f2704180632ca5e714241b6b62f63459e.jpeg\" data-download-href=\"/uploads/short-url/8G3Jz9KwzbbXzYx3PYei4ayTmSa.jpeg?dl=1\" title=\"DSCN0068-005.JPG\"><img src=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/3/3cd28b0f2704180632ca5e714241b6b62f63459e_2_395x500.jpeg\" alt=\"DSCN0068-005.JPG\" data-base62-sha1=\"8G3Jz9KwzbbXzYx3PYei4ayTmSa\" width=\"395\" height=\"500\" srcset=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/3/3cd28b0f2704180632ca5e714241b6b62f63459e_2_395x500.jpeg, https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/3/3cd28b0f2704180632ca5e714241b6b62f63459e_2_592x750.jpeg 1.5x, /uploads/default/original/2X/3/3cd28b0f2704180632ca5e714241b6b62f63459e.jpeg 2x\" data-small-upload=\"https://d2hneyr8lp58j4.cloudfront.net/optimized/2X/3/3cd28b0f2704180632ca5e714241b6b62f63459e_2_10x10.png\"><div class=\"meta\"><svg class=\"fa d-icon d-icon-far-image svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#far-image\"></use></svg><span class=\"filename\">DSCN0068-005.JPG</span><span class=\"informations\">633×800 139 KB</span><svg class=\"fa d-icon d-icon-discourse-expand svg-icon\" aria-hidden=\"true\"><use xlink:href=\"#discourse-expand\"></use></svg></div></a></div></p>",
我想我已经修复了这个问题。我注意到无法运行备份,最终发现 app.yml 中的备份存储桶名称拼写错误。上传存储桶的名称是正确的。我修正了拼写后,备份功能恢复正常。刚才我出于好奇试了一下,结果顺利通过了。
目前正在对帖子执行重新生成操作。
我在 49595 篇帖子中仅有 17 篇数量相对较少的情况下,也遇到了相同的问题,导致重新烘焙(rebake)中止。
49595 posts were flagged for a rebake
rake aborted!
FileStore::ToS3MigrationError: 17 posts are not remapped to new S3 upload URL. S3 migration failed for db 'default'.
/var/www/discourse/lib/file_store/to_s3_migration.rb:357:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:245:in `migrate_to_s3'
/var/www/discourse/lib/tasks/uploads.rake:224:in `block in migrate_to_s3_all_sites'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:76:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-2.5.0/lib/rails_multisite/connection_management.rb:86:in `each_connection'
/var/www/discourse/lib/tasks/uploads.rake:222:in `migrate_to_s3_all_sites'
/var/www/discourse/lib/tasks/uploads.rake:218:in `block in <main>'
我不确定在上述 Rails 命令的输出中应该关注哪些内容,@gerhard,您能给我一些提示吗?
由于 3 个帖子,我遇到了相同的错误 :confused:
正在更新数据库中的 URL...
警告:未为类型 "name"(oid 19)定义类型转换。为了安全起见,请显式将此类型转换为 TEXT 以应对未来的变更。
正在移除旧的优化图片...
正在标记所有包含灯箱的帖子以重新生成...
共有 123456 个帖子被标记为需要重新生成
rake 中止!
FileStore::ToS3MigrationError: 3 个帖子未映射到新的 S3 上传 URL。S3 迁移在数据库 'default' 上失败。
任务:TOP => uploads:migrate_to_s3
(通过运行任务并添加 --trace 参数可查看完整堆栈跟踪)
@gerhard - 如果我们遇到这样的错误,您知道它的含义是“成功!——除了 3 个帖子”还是“由于 3 个帖子导致迁移严重失败”吗?
若要尝试恢复,我应该再次运行 rake posts:rebakerake posts:rebake_uncooked_posts 还是 rake uploads:migrate_to_s3
非常感谢您的帮助 :slight_smile:
运行上述命令后,我看不出它们之间有什么共同点。它们都被包裹在 <p> 标签中,这可能是唯一的共同之处,如果这有什么意义的话。
其中有一个比较奇怪,包含指向论坛表情的链接,例如:
https://www.example.com/images/emoji/twitter/slight_smile.png?v=9
在我之前帖子中提到的迁移错误之后,手动运行 rake posts:rebake_uncooked_posts(不确定是否应该执行 rebake 操作),出现了以下错误:
Failed to report error: "\x8B" from ASCII-8BIT to UTF-8 3 Job exception: 403 Error:
下面还有一堆无法阅读的文字。目前该命令仍在运行中。
@gerhard 你是否知道如何解决迁移到 S3 后所有自定义头像都显示为默认头像的问题?
除了头像之外,其他内容在 S3 上显示都非常正常:帖子图片、用户卡片、用户背景图。只有头像无法显示。看起来原始头像已经迁移成功,数据库中可以查到,S3 上也存在文件,所以问题似乎只出在优化后的头像上。我看到很多人遇到过类似问题,但我至今尚未找到解决方案。:sweat_smile:
更新/编辑:
我决定赌一把,先完成迁移,暂时让头像功能失效。新的头像上传已指向 S3,但它们同样无法显示。:confused:
希望以后能有机会修复这个问题。
查看 /logs 日志时,我发现了一些关于头像 URL 的错误记录,类似如下:
Could not find file in the store located at url: //bucketname.s3.fr-par.scw.cloud/original/2X/d/123456.JPG
不过,如果我直接访问该 URL,文件确实存在,且路径看起来也正确。我还有另一个实例,配置完全相同(唯一区别是存储桶名称),那里的头像功能运行良好。通过 Rails 查询上传记录发现,另一个实例中的路径格式也完全一致。
希望这些信息能帮助我们找到问题所在。
我手动执行了迁移到 S3 的操作,结果相同,但我发现 S3 存储桶中存在 tombstone 文件夹。这正常吗 @gerhard
为什么这些路径没有被正确重映射:
=> "default"
> 正在更新数据库中的 URL...
> 警告:未定义类型 "name"(oid 19)的类型转换。为了安全起见,请显式将此类型转换为 TEXT 以应对未来的变更。
> 正在移除旧的优化图片...
> 正在标记所有包含灯箱的帖子以重新烘焙...
> 10855 个帖子已被标记为需要重新烘焙
> rake aborted!
> FileStore::ToS3MigrationError: 6492 个上传文件中有 1889 个未迁移到 S3。数据库 'default' 的 S3 迁移失败。
> /var/www/discourse/lib/file_store/to_s3_migration.rb:78:in `migration_successful?'
> /var/www/discourse/lib/tasks/uploads.rake:123:in `migrate_to_s3'
> /var/www/discourse/lib/tasks/uploads.rake:102:in `block in migrate_to_s3_all_sites'
> /var/www/discourse/lib/tasks/uploads.rake:100:in `migrate_to_s3_all_sites'
> /var/www/discourse/lib/tasks/uploads.rake:96:in `block in <main>'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `block in execute'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `each'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:281:in `execute'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:199:in `synchronize'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:199:in `invoke_with_call_chain'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/task.rb:188:in `invoke'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:160:in `invoke_task'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `each'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:116:in `block in top_level'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:125:in `run_with_threads'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:110:in `top_level'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:83:in `block in run'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:186:in `standard_exception_handling'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/lib/rake/application.rb:80:in `run'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.3/exe/rake:27:in `<top (required)>'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `load'
> /var/www/discourse/vendor/bundle/ruby/2.7.0/bin/rake:23:in `<top (required)>'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/cli/exec.rb:63:in `load'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/cli/exec.rb:63:in `kernel_load'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/cli/exec.rb:28:in `run'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/cli.rb:494:in `exec'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/cli.rb:30:in `dispatch'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/cli.rb:24:in `start'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/exe/bundle:49:in `block in <top (required)>'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/lib/bundler/friendly_errors.rb:130:in `with_friendly_errors'
> /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.7/exe/bundle:37:in `<top (required)>'
编辑:看来你的错误和我的不同,听起来像是你的一些图片没有迁移到 S3。抱歉,我看错了。也许下面的一些信息仍然有用。你是按照这份指南设置 S3 上传的吗?Configure an S3 compatible object storage provider for uploads
@evenif - 很遗憾听到你遇到了这些问题。我原本打算为遇到同样问题的人写一份指南,因为有很多信息需要从不同的讨论串中拼凑起来。但我正在等待头像问题的修复,正如你上面所见,我在这方面仍然存在问题。
如果你在 Rails 中运行以下命令,结果是 true 还是 false
SiteSetting.migrate_to_new_scheme
如果是 false,你可以尝试将其设置为 true,例如:
SiteSetting.migrate_to_new_scheme = true
然后等待一段时间稍后再回来查看(据我所知,这每 15 分钟运行一次),或者如果你想立即运行:
Jobs::MigrateUploadScheme.new.execute(nil)
之后稍等片刻再检查 SiteSetting.migrate_to_new_scheme 是否已变为 false(这意味着应该已完成)。
然后运行:
Upload.by_users.where("url NOT LIKE '//%' AND url NOT LIKE '/uploads/default/original/_X/%'").to_a
这应该会找到那些仍有问题且无法迁移的上传记录。在我的情况下,所有这些上传在数据库中都有记录,但实际的图片文件并不存在。
根据列表的大小,你可以复制页面内容,然后通过查找和替换生成一系列命令,以便通过上传 ID 列表删除这些有问题的记录。
Upload.find(1).destroy
Upload.find(2).destroy
Upload.find(3).destroy
将 1、2、3 等替换为实际的上传 ID。将整个列表复制并粘贴到 Rails 中,然后按回车键。这应该会删除这些有问题的记录。
然后,退出 Rails(输入 exit),你只需要运行:
rake posts:rebake
或者
rebake_uncooked 允许你在失败时恢复重烘焙过程。我建议除非你有大量上传,否则直接使用普通的 rebake
之后,一切应该都能正常工作,希望如此。但你的优化头像很可能像我的那样损坏,不过原始文件应该存在于 S3 上。
你可以通过在 Rails 中为显示默认头像的用户运行以下命令,来检查头像是否成功迁移(至少对部分用户而言):
User.find_by_username('username').uploaded_avatar
此外,还可以使用以下命令检查优化版本是否存在:
OptimizedImage.where(upload_id: upload_id).where(version: 2)
@markersocial 感谢您的帮助。我想我的问题是因为我早在 2005 年就开始使用 S3 服务,之后改用本地存储,现在又重新使用 S3 存储。现在当我尝试将本地图片上传到 S3 时,遇到了很多麻烦。我的 S3 存储桶中并没有 /uploads/default 目录。
在执行 uploads:migrate_to_s3 后,我发现一些 /images/transparent.png 图片已损坏。当我运行以下命令时:
rake uploads:recover_from_tombstone
参考链接:
我收到了如下提示:
警告 /t/topic/6216/4 的校验和不正确:338c64ada8cbb0fb99bff79e833a4cc492ead00c,应为 c95e4b7c08702db4593332f29b40ca07fb1d9db1。可以通过在自定义字段中运行 rake uploads:fix_relative_upload_links 来修复此问题。
随后 rake 命令中止,并报错:
rake uploads:fix_relative_upload_links --trace
** Invoke uploads:fix_relative_upload_links (first_time)
** Execute uploads:fix_relative_upload_links
** 未找到上传文件 /uploads/files/general/111/cours-offerts.pdf,位于帖子 23033 中 - /t/certificate-technique-de-soudage-college-mathieu/11060/1**
我现在感到有些困惑。
:confused: 这个问题超出了我的理解范围,希望你能找到解决办法,或者有更懂行的人来帮忙。
关于你的存储桶中没有 /uploads/default 的情况,我认为这是正常的,不应该成为问题。我的存储桶(无论是已迁移到 S3 的实例,还是从一开始就使用 S3 的实例)也是同样的情况。你可以查看本线程中嵌入图片的路径,你会发现其中也不包含 /uploads/default
我也正遭受完全相同的问题。
你碰巧找到至少一点办法了吗!!!???
如果没有,我恳请你,如果你碰巧找到任何办法,请与我分享。我将不胜感激。
我遇到了类似的问题,可能是由于从 AWS S3 迁移到本地存储,再迁移到 DO Spaces 导致的。最终,我编写了一些 Ruby 代码,手动将旧的损坏上传 URL 替换为新的有效 URL 格式,似乎解决了我的问题。
在我的情况下,所有文件在第一次迁移时都已成功迁移到 DO Spaces,但 migrate_to_s3 却将它们记录为失败。起初这并未导致附件损坏,但执行重新生成(rebake)后,附件就出问题了。更多详情请参阅链接主题。
我在导入 smf2 数据库、启用 S3 并运行 rake --trace uploads:migrate_to_s3 后也遇到了此错误。
正在将 'default' 的上传文件迁移到 S3...
正在将文件上传到 S3...
 - 列出本地文件
.. => 2244 个文件
 - 列出 S3 文件
... => 2383 个文件
 - 将文件同步到 S3
正在更新数据库中的 URL...
正在删除旧的优化图片...
454 个帖子已被标记为需要重新生成
rake 中止!
FileStore::ToS3MigrationError: 9554 个上传文件中有 7165 个未迁移到 S3。数据库 'default' 的 S3 迁移失败。
/var/www/discourse/lib/file_store/to_s3_migration.rb:132:in `raise_or_log'
/var/www/discourse/lib/file_store/to_s3_migration.rb:79:in `migration_successful?'
/var/www/discourse/lib/file_store/to_s3_migration.rb:373:in `migrate_to_s3'
/var/www/discourse/lib/file_store/to_s3_migration.rb:66:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-3.1.0/lib/rails_multisite/connection_management.rb:80:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-3.1.0/lib/rails_multisite/connection_management.rb:90:in `each_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/cli/exec.rb:58:in `load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/cli/exec.rb:58:in `kernel_load'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/cli/exec.rb:23:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/cli.rb:477:in `exec'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/cli.rb:31:in `dispatch'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/cli.rb:25:in `start'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/exe/bundle:49:in `block in <top (required)>'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/lib/bundler/friendly_errors.rb:128:in `with_friendly_errors'
/usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.2.26/exe/bundle:37:in `<top (required)>'
markersocial,当我运行 Upload.by_users.where("url NOT LIKE '//%' AND url NOT LIKE '/uploads/default/original/_X/%'").to_a 时,输出为 []
我推测这意味着我的问题与您的不同?
ipoopfool,我想我可能遇到了与您相同的问题。您介意分享一下您用来解决此问题的 Ruby 代码吗?:blue_heart:
谢谢。
当我运行脚本时,出现以下错误:
NameError: undefined local variable or method `upload_regex' for main:Object
from /var/www/discourse/script/discourse-fix-old-broken-uploads.rb:30:in `update_post_upload_links'
有什么建议吗?
抱歉打扰了,我将删除之前分享的链接,直接将代码复制粘贴到这里
Posts from before Sept 2020 have broken uploads after migrating to object stores and rebaking. It seems like the uploads are fine, the urls in the raw were just incorrectly formatted, so I'm manually fixing them.
# 注意:以这种方式更新似乎不会为帖子添加修订历史。为以防万一,请先手动备份数据库。
# https://rubular.com/
# 捕获组:/uploads/..., sha1 文件名
upload_regex = /(\/uploads\/[\/\\w]+\/)([0-9a-f]+)\.\w+/
def to_short_name(sha1)
  # 需要先在 Discourse 的 Rails 控制台中运行
  Upload.base62_sha1(sha1)
# 一个健全性检查。您可以遍历所有帖子,统计 /uploads/ 出现的次数。
# 然后运行正则表达式匹配,看看匹配次数是否与之相等。
def count_num_broken_upload_links(posts)
  num_string_match = 0
  num_regex_match = 0
  posts.each do |post|
    num_string_match += post.raw.count("(/uploads/") # 这个是错误的。计数只对字符有效。
    num_regex_match += post.raw.scan(upload_regex).count
  puts "健全性检查:旧上传链接出现的次数"
  puts "简单字符串匹配 " + num_string_match.to_s
  puts "正则表达式匹配 " + num_regex_match.to_s
def update_post_upload_links(post)
  matches = post.raw.scan(upload_regex)
  fixed_raw = matches.reduce(post.raw) do |accumulator, match|
    prefix = match[0]
    sha1 = match[1]
    # 使用 sub 而不是 gsub,这样我们可以逐个替换附件
    accumulator.sub(prefix, "upload://").sub(sha1, to_short_name(sha1))
  if post.raw != fixed_raw
    # 更新 post.raw 似乎也会触发重新烘焙。但我仍然想稍后进行一次完整的重新烘焙以确保安全。
    post.update(raw: fixed_raw)
  puts "已更新帖子 ID #{post.id}"
# 我正在修复的问题发生在 2020-9-5 结束之前,但我会额外增加几天以确保安全。
posts = Post.where("created_at < ?", Date.new(2020,9,7))
posts.each { |post| update_post_upload_links(post) }
另一个人评论道:
在我的场景中,upload_regex 变量需要是全局的,而不是局部的。所以,upload_regex 需要更改为 $upload_regex
