أحاول استخدام سكريبت الاستيراد question2answer.rb لنقل موقعي إلى منصة Discourse. لكنني أواجه الخطأ التالي أثناء عملية النقل.
كيف يمكنني إصلاحه؟ أنا أستخدم حاوية Docker الافتراضية على نظام Ubuntu 18.04 نظيف.
استيراد المستخدمين
**تتبع الأخطاء** (الأحدث أولاً):
9: from script/import_scripts/question2answer.rb:560:in `\u0026lt;main\u0026gt;'
8: from /var/www/discourse/script/import_scripts/base.rb:47:in `perform'
7: from script/import_scripts/question2answer.rb:71:in `execute'
6: from script/import_scripts/question2answer.rb:85:in `import_users'
5: from script/import_scripts/question2answer.rb:555:in `mysql_query'
4: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.2/lib/patches/db/mysql2.rb:22:in `query'
3: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/mysql2-0.5.2/lib/mysql2/client.rb:130:in `query'
2: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/mysql2-0.5.2/lib/mysql2/client.rb:130:in `handle_interrupt'
1: from /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/mysql2-0.5.2/lib/mysql2/client.rb:131:in `block in query'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/mysql2-0.5.2/lib/mysql2/client.rb:131:in `_query': **جدول 'primary_db.users' غير موجود (** **خطأ Mysql2** **)**
I am sorry, Jay. I am not quite sure what you mean by that? Could you please give me some pointers here? I hope that you don’t mean by rewriting the importer script of question2answer.
If I can log in remotely to the machine where you’re running the import it’ll help, as I’ll be able to see whether it works without sending it to you, having you import, tell me what’s wrong, and trying again.
It seems the question2answer importer was written for a case where there is an additional set of tables in the database for another app that was integrated with it. That is what the MAIN_APP_DB_NAME refers to.
We have done an import for a standalone q2a site recently and we have a modified version of the script which does not depend on this extra database. @RGJ was going to clean it up and submit it back in the next few weeks.
In the recent attempt to migrate small data from my old forum resulted in the following error when I used [modified importer script](https://gist.github.com/[Communiteq](https://www.communiteq.com) (formerly DiscourseHosting)/769eff2014d5482f0ab776de03dc3349) provided by @RGJ.
Loading existing groups...
Loading existing users...
Loading existing categories...
Loading existing posts...
Loading existing topics...
importing users
**Traceback** (most recent call last):
11: from script/import_scripts/question2answer.rb:601:in `<main>'
10: from /var/www/discourse/script/import_scripts/base.rb:47:in `perform'
9: from script/import_scripts/question2answer.rb:70:in `execute'
8: from script/import_scripts/question2answer.rb:89:in `import_users'
7: from /var/www/discourse/script/import_scripts/base.rb:881:in `batches'
6: from /var/www/discourse/script/import_scripts/base.rb:881:in `loop'
5: from /var/www/discourse/script/import_scripts/base.rb:882:in `block in batches'
4: from script/import_scripts/question2answer.rb:106:in `block in import_users'
3: from /var/www/discourse/script/import_scripts/base.rb:247:in `create_users'
2: from /var/www/discourse/script/import_scripts/base.rb:247:in `each'
1: from /var/www/discourse/script/import_scripts/base.rb:278:in `block in create_users'
/var/www/discourse/script/import_scripts/base.rb:866:in `print_status': **undefined method `to_f' for #<Mysql2::Result:0x000056370b7c1f80> (** **NoMethodError** **)**
**Did you mean? to_s**
**to_a**
**to_h**
