Migration failure PG::UndefinedObject: ERROR: type "json" does not exist
Hi,
I’m still on a non-docker discourse. I was trying to upgrade to v1.3.0.beta9 from v1.3.0.beta3 (following this guide: https://github.com/discourse/discourse/blob/master/docs/INSTALL-ubuntu.md) and facing this error while migrating (RUBY_GC_MALLOC_LIMIT=90000000 RAILS_ENV=production bundle exec rake db:migrate --trace)
Here’s the output:
** Invoke db:migrate (first_time)
** Invoke environment (first_time)
** Execute environment
** Invoke db:load_config (first_time)
** Execute db:load_config
** Invoke set_locale (first_time)
** Execute set_locale
** Execute db:migrate
== 20150325190959 CreateQueuedPosts: migrating ================================
-- create_table(:queued_posts, {:force=>true})
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
LINE 1: ...ger NOT NULL, "raw" text NOT NULL, "post_options" json NOT N...
: CREATE TABLE "queued_posts" ("id" serial primary key, "queue" character varying(255) NOT NULL, "state" integer NOT NULL, "user_id" integer NOT NULL, "raw" text NOT NULL, "post_options" json NOT NULL, "topic_id" integer, "approved_by_id" integer, "approved_at" timestamp, "rejected_by_id" integer, "rejected_at" timestamp, "created_at" timestamp, "updated_at" timestamp) /var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql/database_statements.rb:128:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql/database_statements.rb:128:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract_adapter.rb:378:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.1.10/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract_adapter.rb:372:in `log'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/postgresql/database_statements.rb:127:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/schema_statements.rb:205:in `create_table'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:656:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:628:in `block in say_with_time'
/home/doctocat/.rvm/rubies/ruby-2.0.0-p353/lib/ruby/2.0.0/benchmark.rb:281:in `measure'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:628:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:648:in `method_missing'
/var/www/discourse/db/migrate/20150325190959_create_queued_posts.rb:3:in `change'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:602:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:586:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:585:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/connection_pool.rb:294:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:584:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:759:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:998:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:1044:in `block in ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:209:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/connection_adapters/abstract/database_statements.rb:201:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/transactions.rb:208:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:1044:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:997:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:959:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:955:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:955:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:814:in `up'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/migration.rb:792:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.1.10/lib/active_record/railties/databases.rake:34:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:240:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:240:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:235:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:235:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:179:in `block in invoke_with_call_chain'
/home/haoahaoa/.rvm/rubies/ruby-2.0.0-p353/lib/ruby/2.0.0/monitor.rb:211:in `mon_synchronize'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:172:in `invoke_with_call_chain'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/task.rb:165:in `invoke'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:150:in `invoke_task'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:106:in `block (2 levels) in top_level'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:106:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:106:in `block in top_level'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:115:in `run_with_threads'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:100:in `top_level'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:78:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:176:in `standard_exception_handling'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/lib/rake/application.rb:75:in `run'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rake-10.4.2/bin/rake:33:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/rake:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/rake:23:in `<main>'
Tasks: TOP => db:migrate
Can anyone help on what I should do next?
What version of PostgreSQL are you running?
9.1.15
You will need to upgrade to at least 9.3.
Thanks, I’ll try and post updates here.
Upgrading worked perfectly with PostgreSQL 9.3. Thanks :slight_smile:
