Errore in Rake db:migrate
hello, my discourse happened something wrong; and some people can’t login.
I run rake db:migrare and get some error information below:
== Seed from /var/www/discourse/db/fixtures/007_web_hook_event_types.rb
 - WebHookEventType {:id=>1, :name=>"topic"}
 - WebHookEventType {:id=>2, :name=>"post"}
 - WebHookEventType {:id=>3, :name=>"user"}
 - WebHookEventType {:id=>4, :name=>"group"}
 - WebHookEventType {:id=>5, :name=>"category"}
 - WebHookEventType {:id=>6, :name=>"tag"}
 - WebHookEventType {:id=>7, :name=>"flag"}
 - WebHookEventType {:id=>8, :name=>"queued_post"}
== Seed from /var/www/discourse/db/fixtures/009_users.rb
 - UserEmail {:id=>-1, :email=>"no_email", :primary=>true, :user_id=>-1}
 - User {:id=>-1, :name=>"system", :username=>"system", :username_lower=>"system", :password=>"b1509cb767810e8112ae7755e7c524f7", :active=>true, :admin=>true, :moderator=>true, :approved=>true, :trust_level=>4}
 ***rake aborted! ***
***ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR:  column "email_private_messages" of relation "user_options" does not exist***
***LINE 1: UPDATE "user_options" SET "email_private_messages" = FALSE, ...***
***: UPDATE "user_options" SET "email_private_messages" = FALSE, "email_direct" = FALSE WHERE "user_options"."user_id" = -1***
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:46:in `eval'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.2/lib/patches/db/pg.rb:69:in `exec_params'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/postgresql_adapter.rb:611:in `block (2 levels) in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/postgresql_adapter.rb:610:in `block in exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract_adapter.rb:579:in `block (2 levels) in log'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract_adapter.rb:578:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.2/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract_adapter.rb:569:in `log'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/postgresql_adapter.rb:609:in `exec_no_cache'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/postgresql_adapter.rb:596:in `execute_and_clear'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/postgresql/database_statements.rb:94:in `exec_delete'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract/database_statements.rb:162:in `update'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract/query_cache.rb:21:in `update'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/relation.rb:337:in `update_all'
(eval):29:in `block (2 levels) in run_file'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:58:in `block in open'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:57:in `open'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:36:in `block in run_file'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract/database_statements.rb:259:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/connection_adapters/abstract/database_statements.rb:259:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.2/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:35:in `run_file'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:26:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:25:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu/runner.rb:25:in `run'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/seed-fu-2.3.9/lib/seed-fu.rb:29:in `seed'
/var/www/discourse/lib/tasks/db.rake:30:in `block in <top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
Tasks: TOP => db:migrate
I got a error when when to exec rake db:migrate in discourse web and the postgres log is:
'2019-05-13 03:32:35.643 UTC [43] ERROR:  column "email_private_messages" of relation "user_options" does not exist at character 27
2019-05-13 03:32:35.643 UTC [43] STATEMENT:  UPDATE "user_options" SET "email_private_messages" = FALSE, "email_direct" = FALSE WHERE "user_options"."user_id" = -1'
I don’t know how it happened?
This looks like your DB is in some intermediate step, are you running the official install here? Did you try ./launcher rebuild app
thanks for your reply, I run my discourse in k8s; I updated discourse to latest, but the docker used an older image(version) when the app was restarted
Only official installs are supported here.
My guess is that you need to make sure that only the newer image is used. The old one can’t work anymore.
