בעיית הגירה סביב כפילויות של הצבעות בסקר
סיכום מבוסס בינה מלאכותית
Migration Issue Around De-duping Poll Votes
A migration issue was discovered where poll votes were being deduped, even for polls that allowed multiple votes. This issue was caused by a migration file (DeleteDuplicatePollVotes) that was intended to delete duplicate poll votes, but it ended up deleting all duplicate votes, including those from polls that allowed multiple votes.
sweetbeems noticed the issue and reported it, and nat confirmed that there was a huge problem with the migration. A fix was merged (github.com/discourse/discourse/pull/22297), but some data had already been deleted.
nat provided a preliminary set of commands to help restore the lost poll votes from a backup. sweetbeems successfully restored their poll votes using the provided commands, but encountered an issue with the date formats in the dump file.
sweetbeems identified the issue as being caused by the assumption that the number of decimals in the seconds would be 6 digits, and provided examples of dates that were affected.
We noticed an issue where our polls where we allowed multiple votes seemed to dedupe recently and another forum site also experienced the issue. I briefly took a look at this recent migration and I can’t help but think it deduped all poll votes:
class DeleteDuplicatePollVotes < ActiveRecord::Migration[7.0]
  def up
    execute <<~SQL
      DELETE FROM poll_votes
      WHERE (poll_id, user_id, updated_at) NOT IN (
        SELECT poll_id, user_id, MAX(updated_at)
        FROM poll_votes
        GROUP BY poll_id, user_id
    SQL
  def down
    raise ActiveRecord::IrreversibleMigration
I’ll do more investigation tomorrow (it’s late here), but since the sql seemed pretty clear to wipe all duplicates, just wanted to note. I did confirm I have that migration file in my docker app, so I’m assuming it ran. Would love second opinions on this.
UPDATE
So, I’ve confirmed that there are no multi votes that were created before I last updated to 3.1.0.beta5, indicating that it was most likely the update that wiped the multi-votes. You can check for multi-votes yourself by entering the discourse app and running the query below.
# enter discourse app
sudo ./launcher enter app
# enter postgres console
sudo -u postgres psql discourse
Query for multi votes ordered by creation date:
SELECT poll_id, user_id, created_at
FROM poll_votes
WHERE (poll_id, user_id, created_at) NOT IN (
  SELECT poll_id, user_id, MAX(created_at)
  FROM poll_votes
ORDER BY created_at;
You should see that the oldest created_at occurred after the last time you updated.
Aside - Should I not have this migration file?
I’m a little confused how I have this migration file… it appears to have been committed after beta5? How would I have this file?
I did confirm the migration ran by checking the schema_migrations_details table in postgres:
SELECT name, created_at
FROM schema_migration_details
WHERE name = 'DeleteDuplicatePollVotes';
In conclusion, I’m very confident there’s a bug here and that we should remove that migration file before others upgrade. I’m not very experienced in rails or discourse, so I’m not sure how to resolve the issue or if we could retrieve those past votes, but it’s a been a bit of a bummer for our users who lost those votes.
4 לייקים
Hey @sweetbeems, thanks for your report.
Indeed there was a huge problem with that migration. A fix is just merged, and as you said some data would have been deleted. :face_exhaling: I wrote that migration, I’m going to admit that I hadn’t considered Post.where(type: "multiple") at all (basically, polls that allow multiple votes).
I’m looking to see if I can create a rake task or script which can help folks restore the lost poll votes from backup.
6 לייקים
Thanks so much @nat!
If you do write that rake script, it would definitely make a lot of users happy on my site. I’d say almost all our polls are multiple votes, so it’s completely changed past poll results :sweat_smile:.
3 לייקים
Hey @nat - just curious, do you think you’ll create a backfill at some point? Or is it not in the plans at the moment? Thanks.
לייק 1
@sweetbeems here’s a preliminary set of commands which should help restore your data, and I’ve tested out on my site.
I am making an assumption that you are using our docker install and are somewhat familiar with the command line.
You should identify a backup file from <site>/admin/backups. It should be one that was done before the data was deleted.
This guide assumes your backups include uploads. The difference is that the backup file would be .tar.gz (data+uploads) vs .sql.gz (data only)
# enter the app using the default user
docker exec -it app bash
# identify the backup you want is there
ls /var/www/discourse/public/backups/default/
# extract the dump.sql file from compressed backup
cd /var/www/discourse/public/backups
mkdir site-backup-to-restore
tar xfz ./default/=SITE_BACKUP_FILENAME= -C site-backup-to-restore/
cd site-backup-to-restore
gunzip dump.sql.gz
# get the data
# this finds the start of the poll votes data
# to the end of the data (which would be an empty line)
start=$(grep -n "COPY public.poll_votes (poll_id, poll_option_id, user_id, created_at, updated_at) FROM stdin;" dump.sql | sed  's/\([0-9]*\).*/\1/')
end=$(tail -n +$start dump.sql | grep -m 1 -n ^$ | sed  's/\([0-9]*\).*/\1/')
end=$((end-2))
tail -n +$start dump.sql | head -n $end > poll_votes_dump.sql
# here you would want to eyeball poll_votes_dump.sql
cat poll_votes_dump.sql
# change the COPY to an INSERT so that
# we can still add ON CONFLICT
sed -i 's/[0-9]\{4\}-[0-9]\{2\}-[0-9]\{2\} [0-9]\{2\}:[0-9]\{2\}:[0-9]\{2\}\.[0-9]\{6\}/'\''&'\''/g' poll_votes_dump.sql
sed -i '2,$s/\t/,/g' poll_votes_dump.sql
sed -i '2,$s/^/(/; 2,$s/$/),/' poll_votes_dump.sql
sed -i '$ s/,$//' poll_votes_dump.sql
sed -i 's/COPY public.poll_votes (poll_id, poll_option_id, user_id, created_at, updated_at) FROM stdin;/INSERT INTO public.poll_votes (poll_id, poll_option_id, user_id, created_at, updated_at)\nVALUES/' poll_votes_dump.sql
echo "ON CONFLICT DO NOTHING;" >> poll_votes_dump.sql
These are what the results of the `cat` commands should look like
The first one should look like this
1       1       1       2023-07-04 05:49:17.031031      2023-07-04 05:49:17.031031
1       4       1       2023-07-04 05:54:01.281801      2023-07-04 05:54:01.281801
and the second one should look like this
VALUES
(1,1,1,'2023-07-04 05:49:17.031031','2023-07-04 05:49:17.031031'),
(1,4,1,'2023-07-04 05:54:01.281801','2023-07-04 05:54:01.281801')
Exit out of the docker instance and into the postgres user – There is a deeper problem which I won’t be addressing here which requires this additional hoop jumping
# from your host, access the app via the postgres user
docker exec --user postgres -it app bash
# insert
psql -U postgres -d discourse -f /var/www/discourse/public/backups/site-backup-to-restore/poll_votes_dump.sql
# you should see `INSERT 0 3928` or the number of poll votes that were restored
4 לייקים
Hey @nat - I just realized I never updated you. I went through with your migration and it went great thank you!! Really appreciate it :slight_smile:
The only issue I encountered was the step converting the dump to an insert statement. For some reason, a few lines didn’t get the string markers (') around the dates. I’m guessing there was a slight bug in your sed statements, but my sed knowledge is… very limited.
Anyway, I was able to hand edit them quick and it worked beautifully!
2 לייקים
Thanks for the update, glad it worked out.
Oof.. sorry about that. As you can imagine the date strings I had were only a handful and to be honest I’m not sure why the date formats would differ across records. :thinking:
Any chance you still remember which dates those are? (If not, it’s fine)
3 לייקים
So, looking at it again, I think it’s because you assumed the number of decimals in the seconds would be 6 digits. Here’s all of my bad data and it looks like it’s all less than 6 decimals:
Bad rows
VALUES
(110,501,54,2023-01-17 08:07:13.09231,2023-01-17 08:07:13.09231),
(8,24,502,2022-06-23 19:09:54.01825,2022-06-23 19:09:54.01825),
(15,40,30,2022-06-24 03:38:58.16703,2022-06-24 03:38:58.16703),
(15,40,222,2022-06-24 21:11:39.76273,2022-06-24 21:11:39.76273),
(15,39,411,2022-06-26 21:32:31.26611,2022-06-26 21:32:31.26611),
(19,49,58,2022-06-27 01:44:29.70736,2022-06-27 01:44:29.70736),
(15,39,241,2022-07-01 14:27:59.6967,2022-07-01 14:27:59.6967),
(32,74,49,2022-07-09 17:29:10.65377,2022-07-09 17:29:10.65377),
(32,74,82,2022-07-09 19:14:00.5514,2022-07-09 19:14:00.5514),
(32,75,11,2022-07-09 22:41:14.95369,2022-07-09 22:41:14.95369),
(35,87,43,2022-07-13 00:29:29.70338,2022-07-13 00:29:29.70338),
(35,87,9,2022-07-13 01:09:07.43221,2022-07-13 01:09:07.43221),
(35,85,37,2022-07-13 04:47:24.1375,2022-07-13 04:47:24.1375),
(35,88,127,2022-07-13 21:50:52.19039,2022-07-13 21:50:52.19039),
(37,91,18,2022-07-17 13:38:45.12448,2022-07-17 13:38:45.12448),
(39,120,30,2022-07-21 05:16:23.22116,2022-07-21 05:16:23.22116),
(39,122,82,2022-07-21 11:27:14.96521,2022-07-21 11:27:14.96521),
(39,112,54,2022-07-21 15:57:17.56429,2022-07-21 15:57:17.56429),
(39,116,14,2022-07-21 18:45:04.31259,2022-07-21 18:45:04.31259),
(39,127,14,2022-07-21 18:45:04.31369,2022-07-21 18:45:04.31369),
(39,122,125,2022-07-21 23:50:35.2962,2022-07-21 23:50:35.2962),
(39,116,771,2022-07-22 07:12:12.63778,2022-07-22 07:12:12.63778),
(39,130,494,2022-07-26 09:27:45.32077,2022-07-26 09:27:45.32077),
(39,124,62,2022-07-26 12:30:12.46385,2022-07-26 12:30:12.46385),
(45,155,67,2022-08-04 08:41:49.96341,2022-08-04 08:41:49.96341),
(46,161,82,2022-08-05 11:47:12.31443,2022-08-05 11:47:12.31443),
(46,161,35,2022-08-06 13:18:00.99911,2022-08-06 13:18:00.99911),
(48,164,54,2022-08-08 21:56:14.14143,2022-08-08 21:56:14.14143),
(47,163,54,2022-08-08 21:57:04.54601,2022-08-08 21:57:04.54601),
(49,166,82,2022-08-13 00:30:34.97762,2022-08-13 00:30:34.97762),
(49,167,51,2022-08-14 05:22:23.57594,2022-08-14 05:22:23.57594),
(49,167,14,2022-08-14 07:35:27.97993,2022-08-14 07:35:27.97993),
(49,166,75,2022-08-19 22:19:38.2656,2022-08-19 22:19:38.2656),
(51,173,76,2022-08-22 17:54:17.34982,2022-08-22 17:54:17.34982),
(52,181,54,2022-08-23 15:37:38.47042,2022-08-23 15:37:38.47042),
(51,174,30,2022-08-28 03:02:15.34373,2022-08-28 03:02:15.34373),
(53,182,577,2022-08-29 10:02:30.50115,2022-08-29 10:02:30.50115),
(57,208,8,2022-09-02 20:29:40.12981,2022-09-02 20:29:40.12981),
(57,209,9,2022-09-03 02:50:22.35697,2022-09-03 02:50:22.35697),
(60,217,8,2022-09-04 13:02:46.92852,2022-09-04 13:02:46.92852),
(60,216,577,2022-09-04 13:34:07.45246,2022-09-04 13:34:07.45246),
(60,217,105,2022-09-04 22:49:24.39502,2022-09-04 22:49:24.39502),
(60,216,411,2022-09-04 22:53:34.70586,2022-09-04 22:53:34.70586),
(61,219,30,2022-09-07 05:05:01.82435,2022-09-07 05:05:01.82435),
(61,223,18,2022-09-09 11:44:43.2807,2022-09-09 11:44:43.2807),
(60,216,1033,2022-09-15 13:37:12.0177,2022-09-15 13:37:12.0177),
(60,216,959,2022-09-15 18:52:10.34721,2022-09-15 18:52:10.34721),
(66,240,411,2022-09-17 22:19:12.0275,2022-09-17 22:19:12.0275),
(66,240,37,2022-09-19 09:33:41.28032,2022-09-19 09:33:41.28032),
(67,249,9,2022-09-19 12:21:47.25329,2022-09-19 12:21:47.25329),
(67,247,37,2022-09-20 12:52:21.50543,2022-09-20 12:52:21.50543),
(68,250,54,2022-09-20 15:01:45.95643,2022-09-20 15:01:45.95643),
(68,251,577,2022-09-21 10:40:56.42414,2022-09-21 10:40:56.42414),
(61,220,5,2022-09-22 01:08:33.95198,2022-09-22 01:08:33.95198),
(69,257,92,2022-09-26 05:18:16.92423,2022-09-26 05:18:16.92423),
(70,267,54,2022-09-26 09:08:28.10639,2022-09-26 09:08:28.10639),
(71,268,9,2022-09-28 03:18:03.1252,2022-09-28 03:18:03.1252),
(69,257,30,2022-09-28 04:43:16.49851,2022-09-28 04:43:16.49851),
(72,273,30,2022-10-05 20:56:44.74037,2022-10-05 20:56:44.74037),
(73,283,104,2022-10-10 07:54:50.91248,2022-10-10 07:54:50.91248),
(73,278,54,2022-10-10 08:51:23.83813,2022-10-10 08:51:23.83813),
(73,292,82,2022-10-10 12:19:52.31188,2022-10-10 12:19:52.31188),
(73,279,351,2022-10-10 13:18:39.72019,2022-10-10 13:18:39.72019),
(73,288,661,2022-10-10 16:38:10.11372,2022-10-10 16:38:10.11372),
(73,289,661,2022-10-10 16:38:10.11469,2022-10-10 16:38:10.11469),
(73,279,127,2022-10-12 11:00:33.12802,2022-10-12 11:00:33.12802),
(75,301,82,2022-10-12 19:03:33.58176,2022-10-12 19:03:33.58176),
(75,302,104,2022-10-12 19:57:29.9634,2022-10-12 19:57:29.9634),
(76,306,82,2022-10-15 13:10:32.84764,2022-10-15 13:10:32.84764),
(73,285,125,2022-10-16 19:52:57.65115,2022-10-16 19:52:57.65115),
(77,308,30,2022-10-16 20:48:14.6183,2022-10-16 20:48:14.6183),
(77,308,18,2022-10-16 23:04:30.89369,2022-10-16 23:04:30.89369),
(79,313,92,2022-10-19 05:17:21.06009,2022-10-19 05:17:21.06009),
(60,217,425,2022-10-19 10:52:06.17367,2022-10-19 10:52:06.17367),
(60,216,1358,2022-10-20 14:50:25.09089,2022-10-20 14:50:25.09089),
(60,216,1363,2022-10-21 07:47:08.79396,2022-10-21 07:47:08.79396),
(84,329,43,2022-10-30 16:01:20.68959,2022-10-30 16:01:20.68959),
(84,329,18,2022-10-30 16:30:59.49903,2022-10-30 16:30:59.49903),
(85,340,51,2022-10-30 21:40:28.30536,2022-10-30 21:40:28.30536),
(84,328,51,2022-10-30 23:17:48.62015,2022-10-30 23:17:48.62015),
(84,330,127,2022-10-31 00:03:10.54385,2022-10-31 00:03:10.54385),
(86,343,928,2022-10-31 08:32:06.81807,2022-10-31 08:32:06.81807),
(86,343,384,2022-10-31 10:59:18.72836,2022-10-31 10:59:18.72836),
(87,346,928,2022-11-07 13:47:25.68637,2022-11-07 13:47:25.68637),
(88,349,92,2022-11-07 14:38:15.06785,2022-11-07 14:38:15.06785),
(88,351,928,2022-11-08 15:26:06.92257,2022-11-08 15:26:06.92257),
(89,354,75,2022-11-09 20:57:46.85531,2022-11-09 20:57:46.85531),
(93,371,76,2022-11-21 09:43:29.16922,2022-11-21 09:43:29.16922),
(93,370,543,2022-11-21 21:23:21.04009,2022-11-21 21:23:21.04009),
(94,373,948,2022-11-28 18:11:42.61035,2022-11-28 18:11:42.61035),
(94,373,54,2022-11-29 07:15:21.09078,2022-11-29 07:15:21.09078),
(97,394,82,2022-12-12 13:46:46.06457,2022-12-12 13:46:46.06457),
(84,330,772,2022-12-13 03:04:26.20321,2022-12-13 03:04:26.20321),
(98,397,661,2022-12-15 19:37:02.36834,2022-12-15 19:37:02.36834),
(98,397,127,2022-12-16 00:59:19.5534,2022-12-16 00:59:19.5534),
(98,398,76,2022-12-16 12:46:17.11838,2022-12-16 12:46:17.11838),
(97,394,928,2022-12-18 13:38:01.11894,2022-12-18 13:38:01.11894),
(99,400,661,2022-12-19 18:15:35.83366,2022-12-19 18:15:35.83366),
(100,436,8,2022-12-21 12:42:55.98193,2022-12-21 12:42:55.98193),
(100,437,30,2022-12-21 14:32:21.01328,2022-12-21 14:32:21.01328),
(101,442,127,2022-12-22 12:34:49.31806,2022-12-22 12:34:49.31806),
(101,443,9,2022-12-22 23:24:09.08744,2022-12-22 23:24:09.08744),
(102,453,92,2022-12-25 08:42:02.29173,2022-12-25 08:42:02.29173),
(102,454,75,2022-12-25 09:25:48.1103,2022-12-25 09:25:48.1103),
(102,453,54,2022-12-25 16:23:26.87095,2022-12-25 16:23:26.87095),
(102,451,82,2022-12-25 23:27:21.92964,2022-12-25 23:27:21.92964),
(103,458,661,2022-12-26 19:45:24.7954,2022-12-26 19:45:24.7954),
(106,469,30,2023-01-05 06:16:00.67561,2023-01-05 06:16:00.67561),
(106,470,76,2023-01-05 08:38:41.19777,2023-01-05 08:38:41.19777),
(96,392,52,2023-01-07 19:58:12.33829,2023-01-07 19:58:12.33829),
(107,478,92,2023-01-09 06:10:43.89593,2023-01-09 06:10:43.89593),
(107,488,948,2023-01-09 06:23:32.7513,2023-01-09 06:23:32.7513),
(107,479,76,2023-01-09 17:36:25.65736,2023-01-09 17:36:25.65736),
(108,496,54,2023-01-11 07:09:43.02946,2023-01-11 07:09:43.02946),
(102,455,20,2023-01-11 14:00:02.7016,2023-01-11 14:00:02.7016),
(108,495,661,2023-01-11 17:19:29.8957,2023-01-11 17:19:29.8957),
(110,501,82,2023-01-16 12:51:31.18923,2023-01-16 12:51:31.18923),
(109,498,5,2023-01-22 12:03:35.72396,2023-01-22 12:03:35.72396),
(116,513,76,2023-02-05 18:43:35.82283,2023-02-05 18:43:35.82283),
(121,532,5,2023-02-10 21:33:16.29764,2023-02-10 21:33:16.29764),
(121,536,5,2023-02-10 21:33:16.29857,2023-02-10 21:33:16.29857),
(121,532,30,2023-02-10 23:35:15.57073,2023-02-10 23:35:15.57073),
(117,516,82,2023-02-13 13:02:36.44077,2023-02-13 13:02:36.44077),
(121,533,1782,2023-02-15 07:30:42.40247,2023-02-15 07:30:42.40247),
(121,531,956,2023-02-17 03:12:52.07589,2023-02-17 03:12:52.07589),
(123,543,9,2023-02-20 15:18:28.30422,2023-02-20 15:18:28.30422),
(124,544,928,2023-02-21 22:29:58.14729,2023-02-21 22:29:58.14729),
(124,545,51,2023-02-21 23:45:29.49985,2023-02-21 23:45:29.49985),
(124,544,1,2023-02-22 00:54:54.75649,2023-02-22 00:54:54.75649),
(125,546,30,2023-02-27 04:49:40.45303,2023-02-27 04:49:40.45303),
(130,561,9,2023-03-14 09:07:21.00302,2023-03-14 09:07:21.00302),
(60,215,1759,2023-03-16 22:20:35.63149,2023-03-16 22:20:35.63149),
(60,217,2332,2023-03-20 00:55:01.75396,2023-03-20 00:55:01.75396),
(133,574,76,2023-04-03 14:14:13.00556,2023-04-03 14:14:13.00556),
(133,581,76,2023-04-03 14:14:13.00753,2023-04-03 14:14:13.00753),
(133,583,771,2023-04-06 11:26:29.85958,2023-04-06 11:26:29.85958),
(84,329,832,2023-04-06 15:37:15.71112,2023-04-06 15:37:15.71112),
(133,570,82,2023-04-06 17:01:40.21826,2023-04-06 17:01:40.21826),
(133,580,82,2023-04-06 17:01:40.22184,2023-04-06 17:01:40.22184),
(84,328,2415,2023-04-07 12:28:24.26717,2023-04-07 12:28:24.26717),
(136,593,928,2023-04-11 08:29:03.77339,2023-04-11 08:29:03.77339),
(137,598,8,2023-04-12 03:54:33.94742,2023-04-12 03:54:33.94742),
(138,601,30,2023-04-13 10:59:08.41804,2023-04-13 10:59:08.41804),
(134,588,54,2023-04-14 10:07:28.10895,2023-04-14 10:07:28.10895),
(135,589,494,2023-04-23 21:08:22.70938,2023-04-23 21:08:22.70938),
(141,614,1757,2023-04-24 12:12:58.19186,2023-04-24 12:12:58.19186),
(141,614,82,2023-04-24 13:27:17.76336,2023-04-24 13:27:17.76336),
(141,614,2395,2023-04-25 09:19:07.9266,2023-04-25 09:19:07.9266),
(141,615,494,2023-04-26 17:53:36.20522,2023-04-26 17:53:36.20522),
(141,615,76,2023-04-27 19:10:23.49874,2023-04-27 19:10:23.49874),
(142,619,51,2023-04-28 18:13:23.2794,2023-04-28 18:13:23.2794),
(142,619,8,2023-04-28 21:12:53.00285,2023-04-28 21:12:53.00285),
(142,618,2623,2023-04-30 12:09:22.47944,2023-04-30 12:09:22.47944),
(147,635,9,2023-05-08 08:06:15.48853,2023-05-08 08:06:15.48853),
(147,636,9,2023-05-08 08:06:15.48992,2023-05-08 08:06:15.48992),
(147,637,1290,2023-05-08 16:43:14.40516,2023-05-08 16:43:14.40516),
(148,638,2101,2023-05-15 08:09:10.41929,2023-05-15 08:09:10.41929),
(149,640,30,2023-05-15 12:53:54.59127,2023-05-15 12:53:54.59127),
(150,643,2623,2023-05-19 14:21:09.25022,2023-05-19 14:21:09.25022),
(153,651,928,2023-05-23 11:56:16.18164,2023-05-23 11:56:16.18164),
(155,657,82,2023-05-31 11:51:49.55158,2023-05-31 11:51:49.55158),
(154,654,36,2023-05-31 19:05:22.05666,2023-05-31 19:05:22.05666),
(155,657,931,2023-06-01 16:57:01.61211,2023-06-01 16:57:01.61211),
(154,653,2536,2023-06-02 09:31:40.07913,2023-06-02 09:31:40.07913),
(153,651,75,2023-06-03 13:13:34.4858,2023-06-03 13:13:34.4858),
(157,664,82,2023-06-04 00:23:04.28684,2023-06-04 00:23:04.28684),
(157,662,9,2023-06-04 00:52:21.13032,2023-06-04 00:52:21.13032),
(156,660,9,2023-06-04 00:52:32.24659,2023-06-04 00:52:32.24659),
(157,663,931,2023-06-04 03:13:55.87343,2023-06-04 03:13:55.87343),
(157,662,2536,2023-06-04 07:42:58.20324,2023-06-04 07:42:58.20324),
(157,662,1514,2023-06-05 20:45:21.96931,2023-06-05 20:45:21.96931),
(159,673,51,2023-06-07 17:14:47.03704,2023-06-07 17:14:47.03704),
(160,676,82,2023-06-07 17:47:04.90143,2023-06-07 17:47:04.90143),
(160,674,30,2023-06-07 18:26:46.82036,2023-06-07 18:26:46.82036),
(162,690,82,2023-06-09 21:32:10.10917,2023-06-09 21:32:10.10917),
(163,694,82,2023-06-09 21:32:30.15343,2023-06-09 21:32:30.15343),
(163,692,1514,2023-06-09 22:17:04.06222,2023-06-09 22:17:04.06222),
(162,685,67,2023-06-10 06:24:28.56428,2023-06-10 06:24:28.56428),
(162,688,2536,2023-06-10 08:46:32.26975,2023-06-10 08:46:32.26975),
(163,693,771,2023-06-10 14:16:21.58241,2023-06-10 14:16:21.58241),
(157,663,771,2023-06-10 14:17:37.84028,2023-06-10 14:17:37.84028),
(157,661,526,2023-06-10 18:47:07.09595,2023-06-10 18:47:07.09595),
(162,685,577,2023-06-11 08:20:02.62867,2023-06-11 08:20:02.62867),
(142,618,1308,2023-06-12 01:47:34.17946,2023-06-12 01:47:34.17946),
(166,702,30,2023-06-12 04:20:36.18735,2023-06-12 04:20:36.18735),
(164,695,54,2023-06-12 06:46:15.29079,2023-06-12 06:46:15.29079),
(167,705,316,2023-06-12 16:39:06.99862,2023-06-12 16:39:06.99862),
(167,705,76,2023-06-12 16:50:50.58035,2023-06-12 16:50:50.58035),
(163,692,35,2023-06-12 20:37:07.78765,2023-06-12 20:37:07.78765),
(170,714,30,2023-06-13 17:21:27.74588,2023-06-13 17:21:27.74588),
(169,713,127,2023-06-14 02:56:03.56288,2023-06-14 02:56:03.56288),
(162,689,661,2023-06-15 22:38:21.78981,2023-06-15 22:38:21.78981),
(172,721,54,2023-06-16 13:32:07.49379,2023-06-16 13:32:07.49379),
(173,725,67,2023-06-16 16:22:05.15942,2023-06-16 16:22:05.15942),
(172,721,771,2023-06-16 21:59:16.12283,2023-06-16 21:59:16.12283),
2 לייקים
This topic was automatically closed after 4 days. New replies are no longer allowed.
