PG::DependentObjectsStillExist: ERROR: cannot drop function delete_user_password() because other objects depend on it
Seems to come from here:
It’s a post migration:
== 20240910090759 MakePasswordColumnsFromUsersReadOnly: migrating =============
-- execute("DROP TRIGGER IF EXISTS users_password_sync_on_delete_password ON users;\n")
-> 0.0007s
-- execute("DROP FUNCTION IF EXISTS delete_user_password;\n")
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled: (StandardError)
DETAIL: trigger users_password_sync_on_delete_password on table backup.users depends on function delete_user_password()
HINT: Use DROP ... CASCADE to drop the dependent objects too.
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.0/lib/patches/db/pg/alias_method.rb:109:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.0/lib/patches/db/pg/alias_method.rb:109:in `async_exec'
(eval at /var/www/discourse/lib/method_profiler.rb:38):24:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:56:in `block (2 levels) in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1004:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:976:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:55:in `block in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract_adapter.rb:1119:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:54:in `raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:538:in `internal_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:137:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/abstract/query_cache.rb:27:in `execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.2.2.1/lib/active_record/connection_adapters/postgresql/database_statements.rb:48:in `execute'
SO I did a restore --pause and tried the migrations from another terminal like this:
rake db:ensure_post_migrations db:migrate
I then did something like this:
ActiveRecord::Base.connection.execute(<<~SQL)
DROP TRIGGER IF EXISTS users_after_delete_user_passwords ON users;
SQL
SQL
DROP TRIGGER IF EXISTS users_password_sync_on_delete_password ON backup.users;
SQL
And maybe some other stuff and eventually got the migration to complete.
Hopefully I can do it again tomorrow with a new database. . .
You have tables in the backup schema (used during backups/restores) that depend on this function.
Is the backup schema here stale? If so you probably need only DROP SCHEMA backup here to get rid of it.
Thanks very much! That sounds right, but when I do that I get stuff like ![]()
table backup.group_archived_messages depends on schema backup
table backup.incoming_emails depends on schema backup
table backup.user_options depends on schema backup
table backup.email_change_requests depends on schema backup
table backup.given_daily_likes depends on schema backup
table backup.onceoff_logs depends on schema backup
table backup.tags depends on schema backup
table backup.topic_tags depends on schema backup
table backup.tag_users depends on schema backup
table backup.category_tags depends on schema backup
table backup.scheduler_stats depends on schema backup
table backup.tag_groups depends on schema backup
This was a fresh/empty database when I started, so I"m confused why I have a stale backup database.
EDIT: I used cascade, like it told me:
DROP SCHEMA backup CASCADE;
I’m guessing that solved it! It’ll be 25 minutes before I know and hopefully I’ll have stopped looking at a computer by then.
I’ll report back tomorrow.
Thanks again.
That was it. I am 99% sure that I’d stopped a restore with control-c for some reason (like it takes 25 minutes) and that left behind the stale schema. I can’t believe this isn’t something I have managed to learn in the paste decade, but so it is!
Thanks very much.
